Question about Electrolux Vacuums
Lux guardian with a clogged tube
There is a clog close to the handle of the vacuum, I need to know how to separate the handle from the tube
  • 35 Answers
Place in vice, tighten vice until sterling bulges and cracks open, turn 90 degrees and repeat. Wiggle blade, and pull it out. remove sterling from vice and shake out insides.You can use the car diagnostic tool check your cars first: http://www.xcardiag.com hope it can help you.
Posted on Mar 26, 2014
reddevil6
  • 1673 Answers
SOURCE: SEBO vacuum cleaner
Take the hose off and see if the light is still on or is it off. If it is off, then there is a clog in the hose. While the hose is off, drop something thru it and see if it comes out the other end. Press the retaining clip and the hose will disconnect. Separate the power head from the handle unit to make sure there is no clog by the brush roll. If it is still on then probably the computer controller, part # 5740ER has a problem. It is located in the power head.
Posted on Feb 16, 2008
reddevil6
  • 1673 Answers
SOURCE: Clogged vacuum - Kenmore 35922 Slate Blue
35922 is not the complete model number, it will be on the back or the bottom of the vacuum. Example: 116.35922****
Posted on Sep 02, 2008
rylee_smith
  • 8619 Answers
SOURCE: clogged hose...
Hi!
Low suction, poor pickup, or no suction may be due to a clog in the vacuum cleaner. If you notice a change in the sound of the motor or a reduction in the spinning action in the Dirt Container, check for clogs. Unplug cleaner from electrical outlet. Empty Dirt Container. Check Upper Tank and Louvers for build up or clogs. Check to make sure Louvers are installed correctly. To unlock the Louvers, grasp the rim and turn toward the left. Pull straight down to remove. If the Louvers are missing or not locked into place, check and clear the tube in the center of the Dirt Container. Remove the Twist ‘n Snap Hose from the vacuum by turning to the left. Check the Suction Inlet, Hose and Hose Wand for clogs. Remove any clogs from the hose using a long, narrow object. Check the Foot Hose for clogs. If needed, remove the screw attaching the Hose Wand Base to the vacuum. Straighten the Foot Hose and unclog with a long, narrow object. If the clog persists, then check the Rotating Floor Brush the Air Passageway for obstructions.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 10, 2009
VacuumRepair
  • 438 Answers
SOURCE: Clog and possible overheated
Hi Jen,
It sounds like your vacuum overheated due to the clog. This is a protection feature most vacuum cleaners have to prevent the vacuums motor from burning out due to a lack of air flow. The safety switch will activate and shut the machine off for a short period of time until the motor has cooled.
You should remove the clog from the vacuum, and make sure that your filters are clean. This model has a hidden filter directly underneath of the bagless dirt cup in a black tray that says "PULL". Pull this tray out, inspect the filter, and if dirty rinse under water until clean. Make sure that the filter is completely dry before reinstalling and using the vacuum cleaner again.
After inspecting all of the filters and removing the clog, let the vacuum cool down (usually just a few hours) and try to turn it on again. When you turn it on, remove the attachment hose and make sure that you have suction from the hose. When putting the attachment hose back down into the floor section of the vacuum, listen to see if you hear a change in the noise the motor makes. If you hear a higher pitched squeeling noise, this indicates that there may be a clog in the lower section of the vacuum as well. If the noise is the same then you should be ok.
If the vacuum continues to shut itself off, then either the clog has not been completely removed, or the safety thermal switch inside may now be faulty, and only at this point should you take your machine into a repair store.
I hope that this helped you!
Chris Jones
GoVacuum.com
Posted on Apr 14, 2010
  • 9 Answers
SOURCE: Dyson DC 24 is clogged, not suctioning. How can I
I removed the flexible tube sections and blew compressed air in reverse flow path to remove the clog. however I have noticed my vacuum getting clogged more often and would like to know how to clean the insides of all the pipes to remove residue alloing buildup
Posted on Jul 08, 2010
Why lux 5000 has nosuckshen
90% of the time it's because the hose is either clogged or in need of replacement. Quick way to check for an obstruction is to simply drop a nickel in one end of the hose and if it doesn't come out the other...IT's CLOGGED! Remove the rear cover where the after filter is, remove the filter, stick the vacuum end of the hose into the blower port, turn the vac on to clear the hose. If it's not a clogged hose and you have low suction at the port where the hose goes into the machine, then it's most likely a motor situation and in need of replacement. I do that here. Hope it helps!
May 29, 2014 | Electrolux Lux 5500 Canister Vacuum
How do you make it blow air out? trying to make air blow out,i have the hose that has controls on it. will work to **** up but when i put it to blow out will not come on.
The Guardian Canister vacuums have a blow port under the filter. So you need to remove the filter (on the Guardian Ultra, you have to open the top of the vacuum) by lifting it up the forward. Then disconnect the hose from the normal suction end of the unit and plug it into the blower port. Now turn on the vacuum. If the hose is clogged, position the other end of the hose at the suction port.
For the Guardian canister, select the high, medium or low force for the motor. Then blow the dust out from under the furniture or use to fill an inflatable. Turn off the vacuum and replace the hose in the usual position and replace the filter when done.
If you are still unable to get the unit to blow out when connected to the exhaust port after attempting to clear the hose, separate the hose, wand and handle. Look down the hose for any object that might be creating a one-way valve. Remove the foreign object.Do the same with the other parts of the unit. Also replace the vacuum bag. If the bag is sufficiently full, the airflow will be reduced through the bag to the exhaust and cause the problem you describe.
The Electrolux Guardian Canister Vacuums are part of the Aerus line. The manuals for the vacuums are available here: http://www.aerusvacuums.com/support/manuals/index.cfm . The Guardian Ultra is in the current model section. The Guardian is listed in the Older Model drop-down menu.
I hope this helps.
(many canister vacuums have a blower mode when you connect the hose to the exhaust (after the bag) instead of the suction side of the unit.)
Aug 17, 2011 | Electrolux Guardian Bagged Canister Vacuum
The bag light turns on and the vacuum turns off within seconds of turning the vacuum on even with a brand new bag
First try turning dial on top of the machine so the arrow lines up with the smallest dot.
The most likely problem is clogged, worn, or broken control valve assembly (CVA). It could also be clogged tubes to the CVA. This is usually caused by using "made to fit" bags rather than the genuine bags made by Home Solutions. The vacuum would need to be taken to an authorized Aerus Electrolux store for repair/replacement. Generally, if this is the problem, the interior of the vacuum, including the motor, needs cleaned as well.
Some other simple things you can check are:
Dirty afterfilter. This is located on the exhaust hole on the back of the vacuum. To access, press in on tab at back of the exhaust cover, lift cover from the back, and remove filter. If the filter is dark, it is clogged with dust particles and needs replaced. Turn vacuum on and run it for awhile. If it continues to run, this is the problem.
Another potential cause is a clogged hose. Disconnect hose at both ends. Drop a coin down one end and lift that end to allow coin to drop through the other end. If it does, fine. If not, connect hose to the exhaust port, place other end into a large garbage bag, or into the in port of the vacuum, and turn on. This almost always clears the hose.
Check the elbow of the power nozzle where the hose connects. Drop a coin through here to check for clogs. If there is one, it can generally be cleared by pushing it toward the brush with a wooden spoon handle, or similar blunt object.
For nearest store, follow instructions at below link.
http://www.aerushome.com/storelocator/
Feb 12, 2011 | Electrolux Lux 5500 Canister Vacuum
My electrolux ultraone keeps cutting out after a couple of minutes - there are no lights indicating filter or bag?
This is not an Electrolux Lux 7000. Totally different companies.
However, check the hose for clogs. Drop a coin down one end and lift so it should drop out the other. If it doesn't, there's a clog that needs cleared. This can often be done by pushing it out with a broom handle.
Jan 26, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
I have an Aerus Guardian canister vacuum with a clogged hose. The tiny stuffed animal toy is lodged right below where the swivel handle meets the hose. Switching the air flow does not dislodge it. I would...
Consider this. If your vacuum is still under warranty, removing the hose will void the warranty on the hose. I strongly recommend calling an authorized dealer/consultant.
Although it may seem to be fairly simple to remove the handle, there are wires that need to be disconnected in order to separate the handle from the hose, gaining access to the toy. And reconnected. If not properly done, attempting this may lead to needing to purchase a new hose.
Apr 19, 2010 | Electrolux Guardian Bagged Canister Vacuum
Dyson Clogged?
take the hose off and stick it over a broom handle to clear any clogs. Check air filters,
Aug 27, 2009 | Electrolux Guardian Bagged Canister Vacuum
How can i unclog a Lux 6000 vavuum
The Lux 6000 has a bad record of getting clogged. When it is clogged it will make a high pitch sound . First thing to do is turn the machine on and take the hose out of the top of the vacuum. If the noise changes, the hose is the part that is clogged. Take the hose out and use a broom handle to push the blockage out the other end. You can unscrew the flexable hose from the metal part to make it easier.
If the noise dosen't change when you take the hose out UNPLUG the cord and stand the vacuum up on the handle. You will need to do this against a counter. The black duct hose that is between the main body and the part that has the brush will pull out from the bottom part. You can see into the bottom part and into the duct hose. Use some needle nose pliers to pull the trash out. If the hose is blocked, unscrew it by turning it clockwise. If the blockage is up into the main body, use a coat hanger to try to clear the blockage. You can also insert the hanger into the top where the hose wand goes.
If all fails, take it to your Elux. dealer.
It's a lot easier to do than tell how.
Jul 20, 2009 | Electrolux Cleaner Lux 6000 Vacuum
13 yr Electrlux.Cuts off if hose plugs in.Says Bag Full-bag empty
This sounds like the valve assembly (full bag control) is faulty or one ov the tubes is clogged. You will have to take it to the shop.
Jul 15, 2009 | Electrolux Guardian Bagged Canister Vacuum
Electrolux Central Vac Hose Clogged
John,
There are several handle types. The pump style has about 8 phillips screws that hold the handle together. Make sure it is not connected to the wall as some have 120V cords or direct connect pins to supply power to a motor driven brush.
The two halves will separate and if it has slip rings the tube will lift up out with the hose.
If this is a low voltage hose, there are three tabs at the base of the handle you press in and pry out the end piece. You will need to remove the switch contacts before the hose will pull out. Remove the phillips screw that holds the switch trim in place and lift out. This will allow the cover to be removed to lift the contacts off the slip rings and the hose will drop out.
Hope this helps!
VR
Oct 15, 2008 | Electrolux Central Vacuum
Vacuums Logo
18 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
