Question about Pride Go-Go Ultra X 3-Wheel Travel Scooter
Where does one get the wiring diagram
Won't run need diagram, to learn why
  • 280 Answers
Http://www.icare-jmb.com/Documents%20partages/eclates/pride/scooters/BASE-GOGO.pdf
This illustrated parts breakdown will allow you to follow the wiring harnesses and check and test all the interconnects. This manual will allow you to remove covers and locate parts. Some basic problems can be solved by checking for loose, disconnected, burnt or damaged wiring and connectors. This manual will also give you part numbers. It is best to check with customer service before ordering parts since there are parts changes based on Model and serial number.
Just as a point of reference, most issues for this model can be found in the electronics assembly console, the plugs at the controller and the battery box connections and HIDDEN fuses. B7 page 30 is a good example of a hidden fuse on the battery box that is sometimes burnt out. E3 page 28 is another hidden fuse. Hope this helps.
Posted on Mar 26, 2014
Wire diag fuel pump 2002 s10
Just run a jumper wire to test it. If it dont work you got a bad new pump. It happens, i have got new junk name brand parts out of the box. You will learn to keep your receipts in your glovebox.
Jul 04, 2017 | Cars & Trucks
Rear running lights not working
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Jul 31, 2016 | Cars & Trucks
Engine stalls when turn on headlights
You probably have a ground issue , looking at a wiring diagram or ground distribution diagram to see if these share a commom ground point or share power from same fuse,https://www.youtube.com/watch?v=WoN1nou5t1Q&t=224s circuit with a high resistance problem . Do you know how to test automotive electrical circuits with a DMM - digital multi-meter , how to read an use a wiring diagram to pin point test spots in a circuit . Free wiring diagrams at http://www.bbbind.com/free_tsb.html . Check out these videos on voltage drop testing an basic electrical testing . This is the way to find electrical problems .
Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia YouTube
Electric Testing Techniques You Need to Know
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
good luck !
Jul 30, 2017 | 2003 Chevrolet Silverado 1500
99 f150 6cyl- the problem started with the pickup cutting out when I would try to give it gas and speed up. I changed the fuel filter but that didn't help, I changed the spark plugs and that...
Rather then guessing as to what the problem is learn to test ! Check the electrical circuit , hook up a fuel pressure gauge , use a spark tester to see if it has spark . Do you like buying parts you don't need ? Other wise your better off having a qualified repair shop check it out .
Testing Electric Fuel Pump Problems with Voltage Drop Test
Fuel Pump Electrical Circuits Description and Operation
Test the fuel pump relay ,do you know what a relay is and how it works ? Ford fuel pump electrical analysis begins at 8 mins into the video .
Do you know what a wiring diagram is ? Free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model and engine size. Under system click on engine ,then under subsystem click on fuel controls . Click the search button ,then the blue link . scroll down to diagram # 7 ,this fuel pump electrical circuit .
Test don't guess
Aug 14, 2017 | Cars & Trucks
I have a 1994 olds cutles cierra runs and stalls randomly tried to jump the fuel pump relay theres no power to the fuel pump i dont know if i jumped the relay right and there is a inline fuse dont know...
For all you don't know,you will need a wiring diagram
before you attempt to diagnose any electrical issues
You have no idea what is in any system or where to start
testing
No wiring diagrams you run the risk of damaging things &
are wasting your time & you are learning nothing
What you learn is the key ,even if you never fix a single car
Oct 21, 2012 | Cars & Trucks
What's the best diagnostic machine to check faults
A professional scan tool,you can not afford or
or professional software,for a computer
You will only be able to afford a code reader & they
only read generic codes,not ALL info, as you suggested.
If you have no factory service manuals,you won't know
how your vehicles systems work
Then without the powertrain/emissions diagnostic manuals,
and possibly wiring diagrams,you won't have the reference
material necessary, to learn where to start any testing,once
you get codes
May 30, 2012 | 2002 Toyota Camry
My ignition switch needs to be replaced, how do i know what wire is what? and how can i find a wiring diagram to learn how to do it myself. without having to pay ?
You shouldnt need a wiring diagram. The ignition switch should just unplug and and your new one should plug in.
Sep 04, 2011 | 1990 Mazda 626
Need electrical wiring diagram for 1991 lumina car, 3.1 engine
Check out auto zone parts. They have all the diagrams for free. Ps Is your car no taking a charge cause mines not damit!! LOL
Dec 27, 2008 | 1991 Chevrolet Lumina
Pride Go-Go Ultra X 3-Wheel Travel Scooter Logo
257 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
