Question about Gateway MT3705 Notebook
I have a Gateway labtop, it uses Windows Vista. The computer connects fine with wireless and dsl/cable. But when it is connected to DSL, the browser (Internet explorer does not work, but programs such as Windows Live Messenger do work. I have checked my firewall, and I also checked to see if I had a faulty IP address but they both were fine. I would greatly appreciate any suggestions.
  • miss_misti_b Jun 16, 2009
    Well I would have done that previously but I can't get online using any browser so it would impossible for me to download firefox, because I can't connect to the browser.
    President:
  • 2,653 Answers
Firefox.
Download it and see what happens.
That will cut down on the possibilities and guide us toward the actual cause.
Posted on Jun 15, 2009
  • RescueTechLA
    RescueTechLA Jun 17, 2009
    Oh yeah. ;P
    OK well then just download it to another computer. Copy the file to a thumb drive or burn it to cd.
    It's only about 15-22mb (small).
When i connect the dsl cable to it the dsl light starts flashing green then red
Put tinfoil over your splice connectors and filters as they leak signals that totally confuse your modem. Never leave any bare wires, I tinfoil the entire modem to prevent the neighbors from hacking me. I don't use wireless, only CAT5 ethernet cable.
Jan 02, 2013 | Gateway 2wire 2701hg Wireless Dsl Modem
Can I set this up this wireless router if I have cable internet and not DSL?
You CAN do this if you have access to the firmware of the ADSL gateway.
Connect cat5 cable from ethernet port on cable modem to ethernet port 1 on ADSL Gateway. (Must be port 1)
-Connect cat5 cable from computer NIC to other port on ADSL Gateway.
-(You may need to) Start->Run->cmd
ipconfig -release all
ipconfig -renew
Here's the trick...
-Open web browser, go to ADSL Gateway homepage (likely 192.168.0.1)
-Configuration tab, Advanced WAN->WAN
-Change WAN PORT drop down from DSL ATM PORT to ETHERNET PORT 1
-Click Edit button. Change Protocol from PPPoE to ROUTED.
-Radio button for DHCP Client to Enable.
-Click Set button.
-(You may need to) Power cycle both Cable Modem and ADSL Gateway device
Now this was done on a Westell ADSL gateway from verizon, yours may differ and you may need to look up the instructions for your specific gateway.
Aug 08, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
Can I use AT&T 2701HG-B 2W Wireless Gateway DSL
yes, you can use them together. they'll find each other at protocol layer 2 (bridge) and layer 3 (router),
and route packets appropriately. Check their manuals to make sure that their HTTP management page ip addresses are different - say 192.168.0.0 for one router and 192.168.1.1 for the other - so that you
can manage them separately without disconnecting them.
You'll want to manage them separately to assign them different wireless-N channels. Channel 6 is
the default, and allowing both to compete on the same channel is a bad idea - give each its own
wi-fi channel. There are 11 wireles 802.11n channels, labeled 1-11.
Diagram: DSL === AT&T 2701HG-B ---------- NetGear router --------------- desktop computer
Each link in the diagram above is an ethernet (802.3 10baseT) cable (except the DSL cable,
which is twisted pairs), and wireless devices can
hop onto the Internet by wirelessly connecting to either the AT&T 2701 or the NetGear router.
Jul 08, 2011 | Gateway Computers & Internet
Can i use a wireless cable modem gateway (netgear) to make my current dsl modem connection wireless.
If your DSL-modem has one Ethernet port, then use an Ethernet cable to connect from that port to the WAN port on your NetGear router. Then, the router will provide both "wired" and "wireless" connections to your computers & devices.
Feb 13, 2011 | Computers & Internet
I am installing with my Sony VPCZ1 PC but cannot get past the first task which says my wireless adapter is still turned on when in fact it is turned off? I am running Windows7. Can you please help?
First;I think you need to use W7 to configure your connection with the router.
But try :
Use the PING command to test the communication between the computer and the gateway.
Goto Start > Run and enter COMMAND.
From the Command Prompt, enter PING 192.168.0.1.
The gateway should reply.
Verify that the residential gateway is getting power. With the broadband modem connected to the WAN port on the gateway, you should have a soild WAN link light. You should use the same cable that connected the modem to the PC to connect the modem to the WAN port on the gateway. Any port on the gateway that has a computer connected to it should have the corresponding LAN link light lit. If you do not get the appropriate link lights, try using different cables.
Minimum System Requirements• Cable or DSL Modem
• Computer with:
• Windows® Vista*, Windows® XP SP2*, or Windows® 2000 SP4*, or Mac OS® X (v10.4)**
• Internet Explorer v6 or Mozilla Firefox v1.5
• CD-ROM Drive
• Network Interface Card
• For Internet Access:
• Subscription with an Internet Service Provider (ISP)
Nov 11, 2010 | D-Link DIR-615 Wireless Router
Can't connect work laptop to router (wireless or
Your work laptop probably has proxy settings in the browser. If yes, please remove it adn try. That should help .
Thanks
Ranjit
Jan 05, 2010 | Actiontec Electronics (GT724WGR) Retail...
Can I setup a cable modem with a router
You can if the router is wireless and you have a wireless card in your computers. If not, then you will have to upgrade the router to a wireless and get wireless cards in the computers or run a cable to the 2nd floor
Oct 26, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Says dsl has no connection, but yet on network it says connected. red light flashing on gateway unit
Your computer sees its connection to the gateway - that's your "connected" - without being connected to the internet. First check that all cables are securely plugged in, especially the cable from the phone jack to the gateway device. You may need to cycle power on the gateway device to restore the DSL connection, and you may need to reboot the computer afterward to reconnect to the Internet (depending on your OS).
Jul 29, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Connection using DSL-2640T
Try diagnose and repaire the connection if that does not work Reset your modem it should go back to default manufacture setup.Then turn modem off and connect any computer or laptop to the modem with ethernet wire turn the modem on go back to your computer that you are connected to modem with wire go to network connections and disable the wireless Network connection and enable local area connection once you see you have connected and have internet working go to start menu you can do this on the start search bar with vista or run with any other windows version type cmd and press enter, it should bring a DOS command menu and then type in ipconfig and enter scroll up and down to where you see default gateway type that ip address to your internet browser it should take you to login screen username should be administrator password admin setup your WEB key make the wireless access available DO NOT FORGET to write the web key down, give a name to the connection and change the default password from admin to something you can remember. save the settings and turn that off keep the laptop on. Then unplug the ethernet cable and switch the network connectiion again enable wireless disable local area also you need to scan the available wireless internet and pick the one you just named use the webkey to access and save when the connection in made.
Feb 18, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
How do I connect a MaxG wireless router into a SmartAX MT880 DSL modem
  • Connect cable from router to computer ...
  • Connect cable from router (internet port) to the modem ....
  • U will be able to go online ....
  • And after it is done ...u can do the wireless settings ....
  • then connect to network and u will be perfectly able to go online ....
Oct 24, 2008 | U.S. Robotics (USR8054) Router
Gateway MT3705 Notebook Logo
43 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
