Question about Panasonic UF-8200 Panafax Panafax UF-8200 Laser Multifunction Pri
Loading software for network asking for IP address
How do I get the IP address?
  • 3 Answers
Usually you can run a report on the printer that will show you the IP address it is using.
Posted on Mar 26, 2014
After loading the software for the notebook camera, the camera works but the IP address is messed up and I cannot access the internet - HELP!
ur IP address has got nothing to do with ur camera...
what was ur IP address before u loaded the camera software...do u remember...re type the IP in the TCP/IP setting in Network setup in Control Panel....else let me know...we can work out
Dec 25, 2009 | Creative Labs Live! Cam Notebook Pro...
Where is my printer IP address
The printer IP address is something you have to add. You can go to Xerox.com and go to support, type in your model number and then to support again.
Then enter IP in the search box and it will tell you step by step how to set it up.
You can set the printer up with a USB cable and it will skip that all together.
The reason it is asking you for the IP address is so it can find the printer and automatically add it.
If you need help. e-mail me at rak458@aol.com I will try and help you that way.
Dec 22, 2009 | Xerox Phaser 6125 Laser Printer
My ip address should be 192.168.1.1 in the setup tab inlynksis but isn;t how do i change it manually
The default IP address of the Linksys router is 192.168.1.1.
First check the IP address of your computer.
START ==> RUN ==> type cme and hit OK==> you will find the command prompt. Type " ipconfig " in the command prompt and hit ENTER.
Now you will find the IP address and the Default.
Default Gateway is the IP address of your router. with this number you can open the set up interface of the router. and change the IP address of your router.
For more info about networking Click Here
Oct 07, 2009 | Linksys Wireless-G WRT54G Router
Scanner installation
I WANT T INSTALL SCANNER SOFTWARE IN MY SYSTEM
Dec 09, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Network
Follow these steps
example
int serial0
ip address 192.168.1.1 255.255.255.252 ( give 1.2 to other end)
ip address 192.168.2.1 255.255.255.252 secondary ( give 2.2. to other end)
ip load-sharing per-packet
ip route destination network destination mask 192.168.1.2
ip route destination network destination mask 192.168.2.2
GOOD LUCK
Jan 07, 2008 | Cisco Catalyst 2950 24x10/100 Mbps...
Ip Address 169.x.x.x Wireless Internet Connection Problems 6400/E1505 Dell Laptop
when you renewed the ip address, windows assigns an ip address of 169.xxx.x.x, this your router will not be able to see. if you have enabled dhcp in the router, check that the wireless card is set to obtain an ip address automatically. If you have no luck that way, go to another pc and in the network card properties, look at the assigned ip address number that the router has given the pc, eg 192.168.2.2, if you have more than two pc you can bet that the other number assign wil be 192.168.2.3, so go to the problem pc's network card problem and and set the ip address manually to eg 192.168.2.4 and set the dns address to 255.255.255.0, save settings and try connecting again. the only other thing stopping a conection would be if the security, eg wep or wpa is enabled and the number has not been entered correctly into the network card properties.
Jul 26, 2007 | Dell Inspiron 6400 Notebook
Toshiba E350
Do you have the print option ? If not, you can configure everything, print jobs will show up on the cue, but they will just disappear into space. The print option looks like a USB key attached near where the network attaches to the copier.
May 01, 2007 | Toshiba e-Studio 350 Copier
Can't find printserver on the network
Most Print Servers are by default on DHCP and if the PS is still on its factory defaults, it won't get an IP address because your computer won't have a DHCP server (unless u have set up one). Now, you can ask the person you got it from if he had ever assigned a static IP Address to the PS. Also, one of the reasons why your laptop won't detect the PS might be a software firewall installed. Please revert back with any other questions or observations. good luck
Mar 23, 2007 | Extended Systems Pocket Print Server
Webramp finder can not find Webramp
Careful with that firmware loading! If you load too new a firmware, the webramp will ask for an "UpgradeKey", which you can't obtain because the company's out of business. Then you just have a pretty brick.
Jul 29, 2006 | Ramp Networks WebRamp 310e Bridge/Router
Panasonic UF-8200 Panafax Panafax UF-8200 Laser Multifunction Pri Logo
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
