Question about Whirlpool GR673LXSS - Stainless Steel Electric Kitchen Range
Whirlpool Gold GR673LXSS - stove and oven elements not heating up
Oven was working, but then it just stopped heating up. The stove top elements, as well as the oven, will not work. I tried it on bake and broil.
  • Tim Willroth
    Tim Willroth Mar 26, 2014
    The "warm zone" element on the stove top works, but none of burners. Lights above knobs come on, but no heat.
  • Tim Willroth
    Nevermind. I had a breaker that was acting up. I was getting anywhere from 121 all the way down to 36 volts. It's all good now.
  • 1462 Answers
SOURCE: Electric Oven doesn't cook evenly
back plate inside oven may be distorted or some of the vents blocked with crud
Posted on Apr 03, 2007
  • 126 Answers
SOURCE: Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Posted on Dec 10, 2007
jsrock516
  • 5911 Answers
SOURCE: baking element not working
If you have already replaced the bake element (which would have been MY first logical choice) and it still does not work, the problem is more likely with the Electronic Clock Control. The control has two separate circuits that will select and turn on either the bake of the broil elements. It is usually a defective relay that causes the particular mode of choice to stop working. The part number for the ECC is 1166040 and costs about $128. It's not a cheap fix, but it would cost you much more if you had a service man fix it for you. Unless...of course, you still have a warranty. Most manufacturers cover all parts from defects for the 1st year. Some parts are covered longer than the initial warranty, however. It may be worth you while to double check your purchase date and appliance paperwork. This repair is not difficult and can be accomplished by the average do-it-yourselfer. If you decide you want to repair the appliance on your own, let me know and I can give you step-by-step instructions on how to do it.
PS Double check the wiring from the ECC to the bake element as well. You could have a broken wire causing the same symptoms too. Also, don't be alarmed by the failure of the ECC. Although they are generally reliable for quite a number of years, they have been known to fail during electrical storms and/or power surges. Something else you may consider: check your home owner's insurance policy to see if it covers the loss of appliances in the event of such incidents. I hope you find this information helpful.
Posted on Jan 24, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool electric range model # RF261PXSQ oven not heating
I'm afraid you may have a blown Electronic Oven Control (EOC) board. The EOC controls all the functions of the oven. The surface elements are controlled by individual infinite switches behind each control knob.. That's why the surface elements all work, but the oven does not. A replacement EOC can be purchased on line at searspartsdirect.com. Just type in your COMPLETE model number and you will find it under the "Control Panel Parts" heading as item number 12. There are several listed, based upon the color you need (White, Biscuit, and Black). This is a very simple repair that any do-it-yourselfer can accomplish if you wish to perform this on your own. All you have to do is UNPLUG the appliance and remove the back panel of the console to access.
Before assuming the EOC is defective, however, inspect the board to see if it has a fuse on it. I do not have a wiring diagram to confirm. Some of these boards do have fuses and that's all that it may take to repair it. However, if the board shows signs of burned components, replace it. NOTE: Check for any loose connectors to the board as well.
I hope you find this information helpful. Let me know if you have questions and/or require additional assistance.
Posted on Sep 25, 2008
  • 31 Answers
SOURCE: stove top works, display unit and oven does not
I would have to say that u need to remove the back painl and look for a ground wirer that is broken or burnt in half. make sur that u unplug the oven first.when u find the problem just replace the wirers
Posted on Feb 08, 2009
Whirlpool Gold Series stove. When turning on the oven to pre-heat, the broiler came on and we got a fault saying FAULT - PRESS ENTER TO RETRY.
Appears the burner is faulty, check connection at burner receptical first then check with meter for opens. Here is the Whirlpool link for parts repair manual etc. https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.whirlpool.com/services/replacement-parts.html&ved=0ahUKEwiCvdH97rDTAhVk7IMKHX4gAtMQFghZMAA&usg=AFQjCNEsdfUwvP3qyVcDj7qJikAtiHTfUQ
Apr 18, 2017 | Whirlpool Kitchen Ranges
Gr673lxss 1 how to find hidden bake element
Kyle,
Usually what they mean by "hidden" element means that the bake element sits in a recessed part of the oven cavity. You only have one bake element and one broil element in the oven. Hope this helps.
Mar 13, 2015 | Whirlpool Electric Range
Whirlpool Gold Double Wall Oven will not heat
check the heating element for opening or cracks
Mar 17, 2014 | Ovens
There was a big pop sound and the oven does not heat up but stove top works
sounds like your oven heating element has blown with the power turned off run your hand around the element and you should feel a small hole or burn on the rod have it replaced
best of luck
Dec 08, 2010 | Whirlpool Ovens
Whirlpool electric oven not heating (has a functional stove top)
Hello Daniellel583! We are terribly sorry to hear of your concern with your Whirlpool Range. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, reviewer name (Daniellel583), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 18, 2017 | Whirlpool RF111PXS Electric Range
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
Whirlpool Gold Range Mod GLP84900
Hi I have a whirlpool gold range mdl GJSP 84902 and had replaced the bottom hidden element after finding out it wasn't getting any heat. So replacement took a little figuring out. it ws easy after a removal of screws and pulling out the whole oven casing out fron the front. Anyhow I still don't get enough heat generate from the bottom element, what other cause are there. checked fuses wiring all is connected HELP ME PLEASE !!!!! thank you Paul
Nov 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool oven heating element
Are you trying to replace the stove top element, or oven element? For the stove top element, just lift up the side opposite where it plugs in and pull straight out.
The oven element usually have one or two screws holding a plate in near where the elements go into the back of the oven. Remove the screws and pull straight out. Reverse the procedure to install a new element. The top broil element will be secured in with a couple brackets to hold it up, these must be unscrewed, removed, and then pull the broil element out.
Remember to turn off power to the range before replacing any of the elements.
Aug 27, 2008 | Whirlpool RBS305PD Electric Single Oven
Older Whirlpool RB170PBX both ovens out
these ovens have a fuse in them called a tco thermal cut out switch if the ovens over heat for a varity of reasons it cuts the power and must be replaced most are on the back of the ovens and are metel disc with two wires on them
Jan 31, 2008 | Whirlpool RBD305PD Electric Double Oven
Whirlpool GR673LXSS - Stainless Steel Electric Kitchen Range Logo
53 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
