Question about KitchenAid Smoke and odors are no problem for this wall mount 48-inch, two-speed hood with a 600/1,200 CFM rating. Its stainless-steel construction gives it a contemporary look. in Stainless Steel
I have 5 years old KitchenAid range hood. Model # KWCU405SSS; Serial # FJY0801041. It has 10 levels of speed, but when switched on, instead of starting to work with lowest speed (#1), it goes to highe
Is there easy fix. I don't want to replace motor control (this part cost over $500)
  • 184 Answers
SOURCE: Kitchen Aid KESC 307 hbs4 electric range control
CESAR, THE OVEN CONTROL IS THE CLOCK,HOWEVER, ON MANY KITCHEN AID RANGES, THERE IS AN INLINE FUSE 15AMP, THAT IS IN THE OVEN CIRCUIT. I WOULD SUGGEST THAT THE INLINE FUSE BE CHECKED FIRST BEFORE CONDEMNING THE CONTROL.
DAVID, THE GLASS TOP ELEMENTS ARE CONTROLLED BY THE SURFACE SWITCH FOR REGULATING TEMPS. THE SWITCH WILL TURN THE ELEMENT ON AND OFF TO REGULATE TEMP. I WOULD SUSPECT THE SURFACE SWITCH(WHAT THE KNOB IS ATTACHED TO) AS THE DEFECTIVE COMPONENT. THERE IS A HIGH LIMIT SWITCH THAT IS PART OF THE ELEMENT. IF IT WAS BAD, THE HOT SURFACE INDICATOR LAMP WOULD BE LIT ALL THE TIME.
THE ELEMENT IS NOTHING MORE THAN A COIL OF WIRE THAT HEATS WHEN CURRENT IS PASSED THROUGH IT.
IF IT WAS BAD, IT WOULDN'T DO ANYTHING AT ALL.
Posted on Apr 04, 2008
SOURCE: KitchenAid KWVU265YBA
had same problem. microcomputer part # 4360092 and micro switch part # 4360362 needed to be replaced. cost 255.95 and 23.59 for parts respectively.
Posted on Apr 30, 2008
  • 171 Answers
SOURCE: light and blower speeds malfunctioning
Hi mutt750,
I'm Harvey the Master Plumber.
I agree. It sounds like your neighbor is doing well. I would replace the control board too. Sounds like a nice guy. Time to invite him over for a bbq?
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
  • 718 Answers
SOURCE: Finding a replacement night light bulb for kitchenaid superba
KitchenAid KESC307
The bulb inside the oven is 40 watts appliance
You did not indicate which bulb you need but you can go to
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=251681
and click on the diagrams in the left-hand side to locate the bulb you need.
Posted on May 09, 2009
Kitchenaid 5kpm5
The repair could be as simple as replacing the speed control switch but given the lack of response from KitchenAid you might not be able to obtain a replacement switch. Eight years can be a lifetime in appliance years.
May 01, 2014 | Food Mixers
OVEN GLASS INSTALLATION
MODEL #TES356TD SERIAL RWO0415338 ESTATE
Jan 17, 2014 | KitchenAid KDRP407HSS Dual Fuel (Electric...
KWCU405SSS fan motor high speed only
Agreed! It totally works. Our fan and lights were stuck on high. Flipped the hood circuit breaker off for 30 seconds then back on again and all controls are working normally again. Thanks!
Jan 15, 2013 | KitchenAid Architect® II KWCU405SSS...
Our Kitchenaid Range Hood model KWCU405SSS has a code "C" in the display. What does that mean?
I just did this and it works.
1.) Make sure to turn off both the fan and the lights. If you skip this step the next step won't work.
2.) Press and hold the + button for 4 seconds until the "C" disappears.
Repeat in another 100hrs of use.
Mar 19, 2011 | KitchenAid Architect® II KWCU405SSS...
The range hood display is showing a "C". We had
Press and hold 'H' for 4 seconds - then press '+' which will reset the 'C' until the next cleaning reminder
Jan 01, 2011 | KitchenAid Architect® II KWCU405SSS...
I have a Whirlpool range hood model #RH4930XD81 approx. 10 years old. A few months ago, the light and vent fan just quit working. They were both working fine and just would not turn on one day. Any...
probably need new replacement parts......... new hoods these days start out at like 60 dollars,,, i would probably replace the unit with the age of it, because the parts needed for that will exceed prob 150 dollars
Feb 05, 2010 | Kitchen Ranges
KitchenAid Smoke and odors are no problem for this wall mount 48-inch, two-speed hood with a 600/1,200 CFM rating. Its stainless-steel construction gives it a contemporary look. in Stainless Steel Logo
93 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
