Question about pch.com
Where do i enter my activivation code ?
I can not locate the space ?
How to enter activation code Go 510
Although the code is 2 blocks of characters on the activation card just enter it into the device as 1 continuous code and it will sort itself out
Apr 12, 2014 | Tomtom GO 300 GPS Receiver
When I reach the end of the line and press enter, it goes to the next line but not to the beggining. Instead it jus come back a few cm. When I try to accent a word, it jumps a space. Pedro
Not returning is likely lubrication. Put a shot of WD40 on both sides of the silver shaft that the carrier slides on, and s a shot on the front and rear bearings of the carrier motor located under the case at the R. rear corner. You can reach the front one from inside the case the rear one you must fish nthe straw thru the case or remove it. The jumping a space I don't know if you are talking a vertical space or a Horz. space. You can put it a language mode (CODE "L") that eliminates spaces on "P" & "L".
Go to http://support.lexmark.com/index?page=content&id=SO4998&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT for a manual. I suggest you copy and paste this address.
DickyO
Sep 08, 2011 | IBM Office Equipment & Supplies
I need to know the code to program a jvc av-32432 tv to a direct tv remote
Hello
The code for JVC with Direct TV Universal remote is:
10053
Programming DIRECTV Remote
[1] Locate the DIRECTV Receiver's brand and model number
(on the back or bottom panel) and write it in the
spaces below.
[2] Enter the 5-digit code for your DIRECTV Receiver
[3] Power on the DIRECTV Receiver
[4] Move the slide switch to DIRECTV icon
[5] Press and hold in the MUTE and SELECT keys until the
green light under the DIRECTV icon flashes twice and
then release both keys.
[6] Using the number keys enter the 5-digit code. If performed
correctly the green light under the DIRECTV icon
will flash twice.
[7] Aim the remote at your DIRECTV Receiver and press
that the power key once. The DIRECTV Receiver should
turn off. If it does not turn off, repeat steps 3 and 4, trying
each code for your brand until you find the correct
code.
OK.
Jul 06, 2011 | Televison & Video
How do I activivate my MP3 to I can play music?
Its very easy...here is a link to a user manual.
It isnt the exact brand but all mp3 players are the same basic instructions:
http://mp3support.sandisk.com/downloads/um/c200v2-um-eng.pdf
Jun 22, 2011 | Audio Players & Recorders
I want to fax from new zealand to australia. how about i do it...........
In the setup you should enter your the fax number in the internationally standardised format, i.e.
in accordance with the following strict sequence:
??  The "+" (plus) character (by pressing
key)
??  Your Country Code( "64" for New Zealand)
??  Your local area code minus any leading "0"
??  A space
??  Your number on the local exchange, using spaces to aid readability as appropriate.
1 Press Menu/Set, 0, 3.
2 Enter your fax number (up to 20 characters).
Press Menu/Set.
3 Enter your telephone number (up to 20 characters).
Press Menu/Set. (If the telephone number and fax number are the same, enter the same number again.)
Note
??  You cannot enter a hyphen in the number.
To enter a space press once between numbers.
??  The telephone number you enter is only used for Cover Page features.
4 Use the dial pad to enter your name (up to 20 characters).
Press Menu/Set.
5 Press Stop/Exit.
Note
If the Station ID has already been
programmed, the LCD will ask you to press 1
to make a change or 2 to exit without
changing.
3.Station ID
??²
Now dial the fax number of australia 0061............ and send fax.
Jun 02, 2011 | Brother IntelliFax-2820 Laser Fax
I have tryed entering the code for Triople Play 2001. I keep getting an error message in the setup wizard for incorrect spacing. Is there a standard pattern for spacing. The CD code is 14103 PLAY...
you probably need to take out the spaces when entering the code. you usually need to enter the code exactly as you see it. note: it is not smart to share a install code on a public website so you should make sure that you can still use it.
Aug 10, 2010 | Triple Play 2001 for Windows
How do you reprogram the Dir button on the wheelwriter 1500 by lexmark?
The DIR key is not programable it simply gives you the location of items in memory. To delete an item pess & hold code & dir key enter address to delete, space once, correct twice, rel keys that address is cleared.
DickyO
Jul 17, 2009 | Lexmark Wheelwriter 1500 Typewriter
Kenwood kdc-mp582 enter security code
hold display and volume up then use your remote to enter kcar or 5227
Jul 07, 2009 | Kenwood KDC-MP528 CD Player
Program numbers
Storing a Number in Memory
1. Press the STORE button. ENTER TEL. NO. is displayed.
2. Use the keypad to enter the phone number. You can put spaces in the number and it will still dial correctly. To enter a space, press NEXT button.
• To scroll forward or backward, use NEXT (when the cursor is not at the end of the number) or REVIEW.
• To erase the current digit, press DELETE.
3. When finished, press STORE. ENTER NAME is displayed.
4. Use the keypad to store a name (up to 16 characters). More than one letter or character is available in each of the number keys. For example, to enter the letter "A," press the 2 key once. For a "B," press the same key twice. For a "C," press it three times.
• To add a space, press NEXT.
• To scroll forward or backward, use NEXT or REVIEW.
• To erase the current character, press DELETE.
5. When finished, press STORE. MEMORY LOCATION is displayed.
6. Press the memory location number (0-9 or A, B, C) to store the number.
Here is a link for this telephone off the GE website:
http://www.home-electronics.net/ge/pc/IB/29897GE1_IB.pdf
May 11, 2009 | GE 29897GE1 Corded Phone
pch.com Logo
19 people viewed this question
Top pch.com Computers & Internet Experts
tony wahlman
tony wahlman
rhodesworks
Are you a pch.com Computer and Internet Expert? Answer questions, earn points and help others
