Question about Fujitsu Plasmavision P42HHA30WS Television
Have no audio but have picture how do i fix the problem
I put the volume up and down no sound i hook it up to speakers it works where in the menu do i fix it
Olivia tv has no sound but see picture what does this mean?
  • Make sure that your audio cables are plugged in properly to the correct ports if your audio is distorted or noisy. Every cable should be inserted completely. If you still encounter bad audio, replace the cable and then attempt to use a different device with the old cable. This will help you pinpoint the source of the bad audio problem.
  • 2
    Use the "Volume up" button on the remote or TV buttons panel to turn up the TV audio volume if the volume is quiet. If the volume is still quiet, check to see if your audio source device has volume settings. If it does, turn the up the volume on your device (see your device documentation if you need help with this).
  • 3
    Press the "Mute" button on your remote control to disable the mute function if you can't hear any audio. Once disabled, press and hold the "Volume up" button on your remote control to turn up the volume. If there is still no audio, press the "Menu" button on your remote control, select the "Audio" menu, and ensure that the "TV Speakers" are set to "On." If you are still not having any luck and are using the built-in TV tuner, open "MTS Audio" inside the "Tuner" menu and make sure it is set to "Stereo/English." If there is still no audio, verify that all your audio cables (including the antenna cable if you are using one) are plugged securely into the proper ports on your TV and audio source device (if applicable). If you are using an antenna, reposition it to a clear, open area; preferably near a window. If your audio source device has audio settings, check to make sure they are set the way they should be (see device documentation).
  • May 07, 2014 | Vizio L32 32 in. LCD HDTV
    No Sound
    Could be a sound problem in the set but first:
    Are speakers for some reason switched off in menu?
    Is (some have this) internal/external speaker select set to external?
    Is volume on SET OR A BOX muted or turned way down?
    Does the set have sound with a DVD etc. hooked via a rear audio/video input?
    Apr 22, 2012 | Televison & Video
    Aoc 32" lcd television sound quit
    It could be a sound problem inside the set but first check the others:
    Make sure in menu speakers are not by accident turned OFF>
    Make sure volume is not turned down or muted on set OR A BOX IF ONE IS USED FOR SIGNAL TO THE SET.
    Make sure in audio menu if it has a setting for Internal/external speakers it is set to internal.
    Lastly hook a DVD etc. to a rear input to see if sound works that way--if it does something in set or a box is set wrong.
    SD TECH
    Apr 22, 2012 | ViewSonic Televison & Video
    Toshiba 36a43 i have picture but no sound. Volume control works but again still no sound.
    Things to check:
    In menu are speakers (audio area) switched on or off?
    If you put sound all the way up and listen right at speaker what if anything do you hear?
    If using a cable or sat box is sound turned down on it?
    Is sound muted on set or the box (if used)
    Do you have sound with a DVD etc hooked via the rear jacks?
    A few sets have a slide switch on the rear= internal or external speakers--is it set to internal?
    failing all of the above you have a audio circuit problem
    Mar 26, 2012 | Toshiba 36A43 36" TV
    I have no sound/ I have a picture my tv is hooked up with coax cables- i have unplugged the tv that didn't work the volume is all the way up on the tv--- we have reset the factory defaults-- no...
    Just to mention that if you have Directv or Dish hooked to the TV, you may need to unplug the satelite receiver for a minute and plug back up. I have seen this happen so many times and people think their TV is at fault. And of course is the possibility of the speakers being cut off in the Sound menu which it looks like you have checked. Lastly, the problem would be in the audio board which Ebay has currently for $18 and shipping $5. Put the model number in the search field at Ebay and scroll down to the audio board.
    May 21, 2011 | ViewSonic N2750w 27 in. HD-Ready LCD...
    I have a Quasar TV that has worked perfectly fine until the other day. Picture is fine, but no sound. The speaker volume is on.
    Check all your channels. If you are getting sound on some channels but not others it is a good possibility that your SAP setting is turned on. Simply go into your audio menu and disable the SAP. Not sure about your model tv but some Tv sets had a switch on the back to disable the speakers and some have a setting in the menu to disable the speakers. If you have a digital cable box hooked to the tv it is possible the cable box volume is turned all the way down which will override your tv volume. Check these options and hopefully one of them works for you.
    Jul 10, 2010 | Quasar SP-3235 32" TV
    I have a 42 inch Insignia plasma tv. I only hook
    If you have the audio cables hook up correctly to where the video cable from DVD is connected to, it should be RED and WHITE wires for audio. Then go to on screen audio setup menu to see if the speakers is turn off in the menu. Also try hooking up the powered PC speakers to the AUDIO LINE out RCA jacks to see if you get the sound OK there.
    Nov 03, 2009 | Insignia 15 in. Flat Panel LCD HDTV
    How can I hook up external speakers? I have
    Go to your tv menu, and make sure that your fixed audio output is selected not variable. Variable will make not work, with the television volume is turn down. When you hook the speakers, make certain that it is on a fixed audio out, not variable, as well.
    Oct 27, 2009 | Zenith C34W23 34" TV
    No Sound Issues
    Hello!
    Try the audio out. Run the audio to a receiver to see if the audio is there. If it is, then I'd leave it hooked up to the receiver and save yourself some money. If there is not any low level audio out then I'd fix the set. The only Sony set I've ever seen that was not worth fixing was a 32" model from the early 1990's that had bad picture tubes after only 5 years. I am a Sony factory trained tech. Good Luck!
    barneyluc
    Oct 13, 2008 | Sony KV-32FS13 TV
    Hdmi not working
    You need to set up the out put of your DVD player. First hook up a non hdmi output to the tv, either component or coax. You don't need to hook up the audio. You should get a picture from this connection. Then you can go into the menu and set your hdmi output to match your tv, probably 1080i. You may have to turn your volume up higher when using the hdmi cable than not. I hooked my audio up directly to a surround sound and don't use the tv's speakers.
    Dec 01, 2007 | RCA DRC-285 DVD Player
    Fujitsu Plasmavision P42HHA30WS Television Logo
    19 people viewed this question
    Top Fujitsu Televison & Video Experts
    Electro Med Services...
    Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
