Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
GFCI in primary power cord keeps going off turning off the hot tub.
I have Dream Maker Big EZ Spa. I turn it on and wait a few seconds I can get jets going but then a minute or so later the GFCI on the main cord will go off and turn the hot tub off. Any suggestions? I have no idea even where to go for support. I bought the tub through Spa Depot about 1 1/2 years ago. It's worked perfectly up until now. Help?
  • Mike Tellegen Mar 04, 2015
    As mentioned: Many things could be the problem. You need to have diagnostics performed by someone who is knowledgeable about tripping GFCI's. If your GFCI is tripping, or consistently tripping, don't assume that the GFCI is bad, as MANY do!!! It may be just fine and is ONLY doing its JOB!! If it is doing its job, you have a short. Not necessarily do you have a impeded water flow problem. GFCI means Ground Fault Circuit Interrupter. It reads, and constantly monitors for Leakage of Voltage to Ground. If sensed, it will trip, immediately. Not that common for GFCI's to go bad in such a short time. Look for the short to ground, first. 2nd - a GFCI will also work as a regular breaker, tripping when there is an Overload. Most people make a mistake that think that a pump overworks or labors when the filter is dirty or pressure side water flow is impeded, this is not the case, the pump actually does not work as hard, so although this is a problem that needs corrected, it is most likely not your problem. Again, look for a the circuit that is shorted. The unplugging suggestion is a good one. With all unplugged or disconnected, plug them back in one at a time.But instead of replacing the fuse only, replace that item that the fuse is supposed to protect! That is the culprit. Most likely, as history has shown in my experience, the most likely culprit will be the heater element, then the blower, Ozonator, pumps. That is the order of problematic items when GFCI's trip. Good Luck
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Scholar:
  • 64 Answers
This could be a number of things. First make sure your water flow is not impeded. Clean your filters or replace them check that there is no debris in the intakes or returns. There are fuses for each item from your power pack, you can unplug everything, lights, blower, pumps etc.. plug them in one at a time and when the GFCI trips that is the fuse you need to replace. Lastly, you could have a siezed motor or a bad GFCI for this you may want to call out a professional hot tub service company in your area.
Posted on Oct 26, 2014
5 Suggested Answers
SOURCE: my dream maker spa does not work. there is
I have the same problem with a one week old x400. It was working fine last night but about 8 hours later water temp has dropped 4 degrees and the pump will not turn on, I can hear the relay in the control box make a ticking sound when I press the pump icon on the control center but the pump does not start. Is there a fuse in the control box?
Posted on Nov 01, 2009
SOURCE: I have a Dream Maker x-spa Dition 4 person spa. i
hi i am having the same problem have you managed to fix it and how any help would be much appreciated thanks joe joeathome2009@hotmail.com
Posted on Aug 06, 2010
  • 760 Answers
SOURCE: Dream Maker spa GFCI plug was all corroded. I cut
Did you make sure you observed the correct polaity on the cord? The white wire should go to the silver screw on the cord cap. The black wire should go to the gold terminal (brass) and the Green wire should go to the Green screw. If the plug was corroded, is it possible that the GFCI is also corroded? They aren't that expensive and you could replace the GFCI yourself if you're sure you can locate the circuit breaker and turn it off.
Posted on Nov 22, 2010
  • 111 Answers
SOURCE: My dream maker big eze hot tub the jet light on the upper control panel just keeps blinking what does that mean
Are the jets coming on when you press the button?
Try unplug the control from the board and plug it back in.
Posted on Dec 02, 2012
Why does my Dream Maker Eclipse motor shut off a second after it goes on...plug new, power OK
either shorted heater element or pump motor bad unplug one at a time turn on see which one makes it blow
Jul 06, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dec 01, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
I received my brand new ez spa today and once I got the water in and pushed test on the gfci the spa came on and so did the jets. I understand that the motor needs to run to heat the water but does the...
Yes, the jets will run anytime the heater is operational. This is neccessary to keep the plumbing from melting, and also to evenly distribute the heated water. Most hot tubs only take 4-5 hours to heat up, but the easy spa takes very long because they use a very small heating element. Usually only 1.5KW.
Jul 26, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
Power is on but jets arnt going and pumps not pumping
I was looking for an answer to your question. I have the same problem with my Dream Maker X-400 and it is less than 2 months old. The power is on but the tub is not heating now, its down to like 82 degrees and the pump is not working but it has power. It just stopped yesterday.
Dec 18, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker spa GFCI plug was all corroded. I cut off the standard plug that was corroded and installed an industrial grade 120VAC plug with the proper polarity. Plugged the spa back into the GFCI outlet....
Nov 22, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Hot tub has power but nothing else works
MY control panel was replaced ,it cycles but, no lights ,no jets,no heat works..What's the problem .
Oct 01, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
My dream maker hot tub keeps needing to be reset at the plug i have to keep resetting it all the time is there another fuse or something i can do
Your heating element is going to ground and 'leaking' current. The GFCI is picking it up and you will need a new element.
Aug 19, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
385 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
