Question about Rockford Fosgate Car Audio & Video
Looking for a box for under the back seat in my 2004 dodge ram
Will ROCKFORD FOSGATE P3D4-12 12" PUNCH P3 DUAL 4-OHM SUBS WOOFERS 1200W SUB fit in a box under the seat in a 2004 dodge ram qaud cab?
  • 45 Answers
SOURCE: Need specs to build box for my truck
I do design sub enclosures for a living and I give free specs on basic setups, so you are in luck. As a starting point I'll start by saying that fitting them under the seat may not work that well. Each sub will need about .75 cu.ft. sealed and probably double or triple that for a good ported box. I can get more specific If you e-mail me (dynami28@charter.net) the specs on those subs. Specifically I will need the Theile Small parameters ( these numbers-VAS, QES, QMS, FS, etc,) and then I can give you a better idea of where they will fit. If they do go under the seat they will probably not produce really low bass because smaller boxes generally produce higher bass tones. This decision should be based on what you listen too and what you expect them to sound like. They most likely will be more thump than boom and some people like that, so figure that out as well and let me know. Also my father has the same truck and there is a lot of room under the back seat. You can also gain some extra space by using fiberglass to conform the enclosure to the contour of the truck.
-Dynami
Posted on Apr 05, 2009
Zackd9184
  • 56 Answers
SOURCE: wiring
The two seperate wire terminals on the sub are for dual voice coils which means. If You hook up the first terminal to the second terminal then run speaker wire from the second terminal to the amp.It should then increase the subs frequency response and sound better which also means it will be able to handle more bass. As to just having one voice coil hooked up. The two terminals is pretty much the bridge for the sub.
Posted on Dec 21, 2007
duby1990
  • 367 Answers
SOURCE: Rockford Punch HE2 wiring question.
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
Posted on Feb 06, 2009
  • 1126 Answers
SOURCE: Ohm calculations; 4 and 8 ohm sub woofer?
+ output from amp to + input of 4 ohm to + input of 8 ohm AND - output from amp to - input of 4 ohm to - input of 8 ohm is a parallel circuit = 2.66 ohm impedance load for amp
+ output from amp to + on 4 ohm - on 4 ohm to + on 8 ohm - on 8 ohm to - of power amp is a series circuit = 12 ohm impedance load for amp. Clear as mud??
Clear as mud?
Posted on Jun 11, 2009
  • 8 Answers
SOURCE: What sizes of wires do I use to hook up a 10
must be higher than a 12 or your not getting enough amp or watts as you can je
Posted on Nov 17, 2009
Wireing 12inch dvc 4 ohm subs
well rockford has a simple site to wire up your subs shows you how to configure them go to rockford fosgate woofer wiring wizard. and itll show you what you want to know..
Jan 03, 2013 | Rockford Fosgate Car Audio & Video
Wiring configuration
Ryan Sandy to better answer your question. Please clarify your question.
If you are asking how many ohm this subs has...then the answer is that the Rockford Fosgate Punch HX2 RFD1215 is a dual 4 ohm sub. One can be wired down to 2 ohm or up to 8 ohm. Heres a link that will show a diagram on how to do that:
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=42#results
If you have two of these subs you can wire them down to 1 ohm or 4 ohm. Here is a link that illustrates how to do so: http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42#results
Oct 15, 2012 | Rockford Fosgate Punch HX2 RFD1215 Car...
Which subs to use with the rf punch 8002
You should get the dual 4 ohm version of subs and wire them both in parrallel and series for a 4 ohm load to that amp, Bridge the amp and your subs should be seeing about 960 watts true rms.
May 29, 2010 | Rockford Fosgate Punch 800a2 Car Audio...
Wiring for 2 subs for max performance
This amp is rated at 500 watts into a 4 ohm load bridged mono or 250 watts x 2 into 2 ohm load stereo. Do not go below that impedance in either case. The amp was meant to dissipate a certain amount of power, driving it to hard will lead to damage. Your speakers look like they are dual voice coils @ 4 ohms each. To get the max power while still saving your subs would be to parallel the voice coils on each woofer then run them in stereo with your amp. Stereo 2 ohm is 250 watts per speaker.
Dec 14, 2009 | Rockford Fosgate Punch 501S Car Audio...
-Dynami
Apr 02, 2009 | Rockford Fosgate Car Audio & Video
Feb 05, 2009 | Rockford Fosgate HE2 RFP4212 Car Subwoofer
Sub hook ups
There's a lot more factors involved than that.
  • Power capability of the subs
  • Type/size of the sub box
  • Allotted space in the vehicle for the sub box
  • Voice coil impedance of the subs versus the capability of the amp
  • Etc.
Jun 19, 2008 | Rockford Fosgate Punch 500a2 Car Audio...
Sub woofer wiring
If you have a 500a2 and two 4 ohm single voice coil speakers, you have only one option. Connect one speaker to each channel.
Dec 30, 2007 | Rockford Fosgate Punch 500a2 Car Audio...
Car Audio & Video Logo
48 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
