Question about Whirlpool Washing Machines
Whirlpool Cabrio washer model WTW5610XW0 type 588-02 will not drain and spin. Now will not sense and start up. Lid lock functi
  • 82 Answers
SOURCE: Washing Machine wont spin/agitate
The most common problem is the lid switch. with a screw driver in hand open the lid and press down on the lid switch. sometimes the mounting screws will crack the switch housing and the striker can't move the actuator far enough. I am interested in the clicking noise, as this could indicate a pump issue or a sock seizing up the tub.
Posted on Jun 14, 2009
  • 39 Answers
SOURCE: Whirlpool washer grinding noise when draining
there could be something in your pump.....remove the pump and see if there is not something inside...
Posted on Jul 04, 2009
  • 1531 Answers
SOURCE: whirlpool washer model #LSQ8520JQ1 won't spin or drain
there is a possibilty the drain pump maybe locked up by a small foreign object such as a small nail tooth pick drill bit or even a coin check that.if that does not solve them problem then the timer or control board may need to be replaced
Posted on Sep 17, 2009
  • 572 Answers
SOURCE: The lid will not lock on my Whirlpool Cabrio
id change the door switch
Posted on Feb 06, 2010
My Whirlpool Cabrio washer wtw555oxwo turns on, lid locks, then the lid lock light starts flashing and the machine does nothing. Just replaced the lid lock, but nothing has changed. Any suggestions?
adjust the lid lock switch?? seems to me that lid lock mech is not moving far enough to properly be sensed by switch
if machine is over 8 months old id suspect rust in lock arm as cause
Jul 22, 2015 | Whirlpool Washing Machines
I have a Whirlpool Cbrio top load washer. it won't start it's cycle. Once it senses the load, the lock lid light flashes and it does nothing. can this be fixed?
I would say that the lock has failed. Either the lock itself or maybe the pin or latch that fits into it when you close the door may have cracked / broken. If the machine thinks the door / lid is still open, it wont let you start it.
Jan 03, 2015 | Whirlpool Washing Machines
My Whirlpool Cabrio washer model WTW5610XW0 type 588-02 spins then stops and clothes still come out wet.
The washer is unbalanced, make sure it is level and the clothes are distributed even, if this have been check. put the unit on cold water and see how fast it comes in. Safety programmed into the unit if it takes longer then 10 minutes to fill it will just drain. This is to keep the washer from flooding out. Check the water inlet where the hose screws on, it could be plugged up with grit
Dec 12, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio washer stops spinning and doesn't restart
it sounds like the water pump is not emptying properly, blow down the water outlet pipe to see if is clear if not go to the water pump and clean it out there is probably a button , paper clip or other debris preventing it from doing its job eric
Dec 25, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
Washes but locks on spin cycle does not spin or dran
Does the lid lock when it gets to the drain cycle? If not then you need a new locking mechanism. The tab in the mechanism breaks off and it tries to lock the lid but cant. If it hums when it gets to the drain cycle, you have something caught in the pump or a bad pump
Aug 24, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio wtw5500xw1 will not spin
This is caused by a major design flaw in this washer. I have the same washer and am having the same problem. If you take the back cover off by removing the small metal cover over the tube coming from the controls and all the screws around the large lower metal cover, you can gain access to the back of the washer. Take the foam noise reduction pad out of the bottom of the washer. There is a white opaque plastic shroud on the bottom of all the motors covering the belt. Remove it by taking out the screw in the front bottom and back bottom of the shroud. You will most likely see that the belt fell off. This is because the drive pulley for this washer has no ridge on it to keep the belt on and most likely rubbed on the shroud and cut a perfect groove in the shroud, allowing the belt to fall off. SHORT STORY: This washer is a piece and you are probably out of warranty. There is no actual way to fix this problem unless Whirlpool has made a new drive pulley that has a ridge on it to keep the belt on the two pulleys. Good luck. I bought mine for $700 and it worked for two years before this happened.
Mar 04, 2012 | Whirlpool Cabrio Washing Machines
The lid will not lock, therefore the washer will not drain or spin
Hi.
Replace the door lock.
If the door lock is not at fault, then replace wiring harness between door latch and control board.
Enter model number here to find parts and diagrams.
Nov 14, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Open Questions:
Washing Machines Logo
476 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
