Question about Frigidaire Affinity ATF7000E Front Load Washer
It freezes on the cycles
Error message 11
  • Official Brand Answer
  • 2,267 Answers
Good Morning Juan,
I see that you are having trouble with your Frigidaire Affinity washer, model# ATF7000E, freezing on the cycles and giving you an Error message 11. The E11 states that fill time is too long. There are a couple of things to check in this case. First, you will want to reset your appliance by either unplugging it or cutting the power at the circuit breaker for at least 2-3 minutes. When you restore power you can start a cycle and see if it works. If it does, there just might have been some miscommunication between the different boards inside the washer. If it is still giving you the E11, you will want to make sure that the water pressure is at least 30 PSI. Make sure you're not using any other water sources while using the washer. Also make sure that the faucets are fully opened going into the appliance and that the hoses are not kinked in any way. If you are still having trouble receiving that E11, I suggest contacting the manufacturer for further assistance. Hope this has helped.
-Best Regards-
WP
Posted on Mar 27, 2014
WHAT IS THE F1 ERROR MESSAGE
F1 error code is a miscommunication between the control board and the rest of the machine. Check for any loose or damaged wires. If no loose or damaged wires are found, replace the control board and this should clear up your problem.
Oct 22, 2015 | Whirlpool Cabrio 7.6 Cu. Ft. 11-Cycle...
Train Sentry 11-9200 won't advance Eunr error message
Try first removing battery and putting it back in, to see if it reset the camera
Apr 06, 2008 | Bushnell Trail Sentry 11-9200 Digital...
Scotsman ice maker cme 506 makes ice and turns off and blinks refrigeration
First check to make sure condenser fan is running during freeze cycle. Now check to make sure condenser coil is clean. Her is all the specks on the machine.
1. Ice production ( 500 at 70/50
2. BTUs per hour ( 7000)
3. Maximum times in Minutes. ( 50 freeze, 14 harvest.
4. Refrigerant charge ( R-404A ) ( A-D series: AC 32oz, WC 20 oz. E series AC 23 oz, WC 14 oz, F series AC 23 oz, WC 13 oz
5. Suction pressure ( PSIG ) 35-37 - end of freeze, 120-125-Peak in harvest.
6. Discharge pressure ( PSIG ) 240-260- 5 min in freeze.
165-175- minimum in harvest.
7. Metering device.( TXV plus distributor, E series and higher have two TXVs. superheat 3 to 15 deg F.
8. Average comp.amps. 10-11 during freeze, 11-12 during harvest.
9. Batch Weight. 6.5-7 lb
10. cycle time, 23 minutes @ 90/70. 19 minutes @ 70/50
Feb 24, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
When i start my fifa 11 then it can't start its writting E0001,what shoul i do?
Lol just change your resolution and then change back....worked for me
Dec 10, 2010 | Computers & Internet
F 11 error code on whirlpool duet washer.
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
this is for error code f 11
thanks.
May 02, 2009 | Whirlpool GHW9400 Front Load Washer
Error message F 11
Potential causes: • Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU) (its the
usual thing)
• Check MCU
• Check CCU
• Check Motor
Replace failed component. Check for sharp edges in wash basket of machine. Companies want you to dump your machine & go for a new one, keeps their factories running.
Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore he4t washer shows f-11 error
F-11 // WILL THEN APPEAR FDL CODE DOOR LOCK LOCK FAILURE, F-11 COMMUNICATION ERROR REPLACE MAIN CONTROL,, JUST REPL 3 TODAY ....
Nov 28, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
