Question about Haier HLP21N Washer
My Portable Washer Machine Haier HLP21N, no turn on again.
I used my Haier HLP21N Washer a couple times, and the thirst it no worked again. Before the first, it taked a pair of minutes for star and turn on. At the second it worked very good, but at the thirst no turn again after I left the top opened, turn on and I listened a alarm and I turned off. After It no turn again.
aborcass
  • 2651 Answers
SOURCE: Haier HWD1000 washer/drye
please repost for i have no knowledge of the haier productline
Posted on Jan 31, 2009
GodBlessU
  • 3513 Answers
SOURCE: Haier Top Load Washer doesn't spin
Hi
There can be two possibilities,one if it has a belt, it is either stretched or slipping or if it doesnt have a belt then there is a clutch like device between the motor and the basket, which is either broke or cracked.
Or follow this easy steps...
Unplug the washer and turn off the water faucets.
Disconnect the water hoses and the drain hose and pull the washer away from the wall, leaving yourself enough room to work behind the appliance.
Lay an old towel down to kneel on and soak up any water that leaks from the hoses.
Remove the rear access panel.
Locate the motor. The rubber drive belt goes around a pulley wheel attached to the motor.
Press on the belt. If it gives more than ¾ inch or so, it needs to be tightened.
Loosen the mounting nut for the motor and push the entire motor to increase the tension on the belt.
Hold the motor in place and tighten the mounting nut.
Make sure you don't tighten the belt too much or it will break. You should be able to press on it and feel it give just slightly.
Replace the drive belt if it shows signs of wear.
Thanks for contacting fixya.com
Posted on Oct 13, 2009
Testimonial: "Thanks! I guess you're right. The belt seems to be too loose and shows signs of wearing. Already ordered new one. Thanks again!"
localwonder
  • 6784 Answers
SOURCE: haier washer machine HLP23E makes a noise
A washing machine may wiggle, rattle or move across the floor. It is often accompanied by excessive, or loud noise. There can be several causes and the problem is worse with some units more than others.The most common cause is an unbalanced wash load. Open the lid/door, and attempt to redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit. A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See your manual on how to level your washing machine.The outer tub/basket, is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons/shock absorbers, may begin to wear out and not support as much weigh as needed.
Unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be the best action.Another common cause for excessive movement, or clunking, is the floor on which the washer rests. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
NOTE_ Verify That the shipping system including shipping bolts, spacers and cables are removed. This is a common issue when a new washer is installed.
Posted on Jan 04, 2010
  • 5 Answers
SOURCE: how do i replace belt on Haier HLP021WM portable washer
I have the same issue. Upon removing the back access panel I can see the motor spinning but the belt has become stretched and is not spinning the drum. I ordered my belt, I assume it will fix it. Probably needs done once a year if used regularly.
Posted on Sep 05, 2010
  • 3 Answers
SOURCE: spin cycle doesn't work
bad drain pump or clogged drain line. some units have drain trap you can clean,if so you can clean it out yourself but will make a huge mess if you don't pinch close the drain hose between the tub and pump.
Posted on Nov 18, 2011
Haier hlp21n washer valve inlet - Water is not coming properly very less water then usual
Hi, if you turn off water to machine, remove flexable feed pipe to it and look into inlet hole, you should see a filter, this should pull out, maybe with plyers carefully, if blocked, clean with bleach, or descaler, ours (on a bosh machine, is in the actual tap on the wall, most odd that.) & replace.
If this is the cause, I would do it maybe every 6 months or yearly, depends on age of machine.
Hope this helps.
Nov 27, 2017 | Haier Washing Machines
Haier HLP21N Washer will not Wash or spin cycle not working is this a level problem?
main suspects are lid switch or fill level gage 25331493-xrysbksmd4oe40lchygmaasz-3-0.jpglid switch
pressure sensor switch
Dec 21, 2014 | Haier HLP21N Washer
Haier HLP21n blinking light error code.. Rinse and Spin lights blink...what does it mean?
This washer is a sanyo on the inside. When panasonic bought out sanyo and all its daughter brands, they started making parts not available for repairs. The service manual is here---> https://panasonic.encompass.com/shop/research_new/HAI/sm/HLP21N.pdf
This is also known as a sears proflex among other names.... haier-hlp21n-blinking-light-error-code-eqln1e0r5dvuapuxoxy4lmrd-1-0.jpg
Dec 09, 2014 | Haier HLP21N Washer
Haier hlp21n won't start.
Need more information.
Is the water turned on? Press the water level needed.
Low, Medium, Maximum press start
Aug 04, 2013 | Haier HLP21N Washer
Haier HLP21N washer will not spin or drain water.
ihe clutch is not grabing in1 needs replacing clutch assembly.
Nov 28, 2017 | Haier HLP21N Washer
How to replace washer lid on haier model hlp21n
You can buy the lid at encompassparts use p/n:WD-4250-11
but replacing it will be difficult. You have to remove the entire top but I have seen one replaced without going to all the trouble. It's hard to explain but you have to angle it a certain way and get the pins installed but if you don't want to risk breaking it, buy an aftermarket warranty from Sears and have them break it. For 80. dollars they will cover all the machine repairs for one year any problems.
Mar 10, 2013 | Haier HLP21E Top Load Washer
Spin cycle doesn't work
Nov 12, 2011 | Haier HLP21N Washer
Haier HLP21N Washer Logo
150 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
