Question about Husqvarna 130bt 130 Bt Gas Powered Backpack Leaf Blower 29.5cc Reb
Won't start changed spark plug, new fuel, new filter. wont start
  • 1,162 Answers
Are you getting spark on plug? Check to make sure wire is connected to plug, if still not starting. Is fuel getting to plug? Remove plug an see if its wet. If its wet it could be flooded. If not fuel lines are common on saws, tank in is a major problem it cracks an need replacing. Have you checked the on off switch? If it still wont start, carb is more than likely the problem. Remove it an get a rebuilt kit, they are cheap, carefully remove all parts clean out all orifices even small ones with a piece of brass or steel bristle from a brush, use carb cleaner to clean the parts, carefully put it all back together an it should start. That is about all there is.
Posted on Mar 26, 2014
Saw wont start, getting fuel and spark
Try starting it with the air filter removed. If it starts, clean the air filter. It could also be the fuel filter. If you replaced all the fuel lines, make sure you didn't get the oil line mixed up with a fuel line
Jan 25, 2015 | Poulan Garden
I have changed the fuel pump, fuel filter, rotor on a 1997 chevy s10 truck and still it won't start. we checked for spark and there is spark. we are now checking the fuel relay but don't know
you need 3 things, air, fuel, and spark. if u have spark coming from all plugs, then ur good there, if you have fuel, and it still wont start, it may be the maf sensor or one of the other airflow sensors such as the map sensor.
Mar 10, 2013 | 1997 Chevrolet S-10 Pickup
My 1991 honda civic runs fine going down the road, when I shut it off it wont start is there more than one relay for the fuel pump.
Not that I know of.
Are you getting spark to the plugs when it won't start, and how long do you have to wait for it to start ?
Aug 13, 2012 | 1991 Honda Civic
1995 ford contour cranks but won't start, change fuel filter, fuel pump, and spark plugs. Not getting any spark.
Have you ever heard of testing before replacing parts ? Fuel pressure an flow tesing , testing the electrical circuit for the fuel pump , amp draw testing , voltage drop testing etc... Thier are no magical fixes in auto repair . No spark ! check B+ voltage an ground circuits for the ignition system , Ignition System Designs Operation and Testing an SD Premium video
Jun 18, 2017 | 1995 Ford Contour
My Mitsubushi Space Star Car won't Start. What can I try?
spark plugs are deep in the head yet you should get all the the old fuel out first, stale fuel wont ignite and will also clogg fuel filter. you need a mix of atleast 70% new fuel even then its not good for the injecters. If its a manual gearbox a tow start is a quick fix although no go for auto's. cant be much wrong if car was fine when parked, plugs-fuel-filter and possibly fuel pump for sure. If that doesnt fix take plug out put in lead and crank engine to be sure you have spark even just put any plug you know works in lead leaving your plugs in engine just to check for spark y turning over engine looking for spark on plug good spark will be blue but any spark is good.
Jun 16, 2012 | Mitsubishi Cars & Trucks
I have an 2003 ford expedition that just stopped . i first changed fuel filter, fuel pump, cleaned injectors, changed filters, spark plugs, cleaned throtle, then had it checked further and tjhe mechanic...
Probably the inertia switch for the fuel pump..You owners manual should show you where its located..See if the button has pop up ..If it has push it back down until it clicks..If it wont stay down then hold it down and see if it will start..If it does you will have to replace it..If thats all good then check the relay for the fuel pump..
Sep 07, 2011 | 2003 Ford Expedition
14" Mac Cat gas engine won't start. Changed spark
Check tank fuel filter. safe way, put hose on end of filter blow through hose, fuel should come out of filter easily.
Sep 04, 2011 | McCulloch Garden
2005 honda element won't idle
COULD BE STOPPED UP FUEL FILTER.CHECK FUEL PRESSURE SHOULD BE 48 PSI. IF LOWER HONDA ADVISE TO REPLACE FUEL FILTER.YOU HAVE TO REMOVE FUEL PUMP THROUGH ACCESS PANEL FROM THE FLOOR.IF FUEL PRESSURE OKAY.REPLACE AIR FILTER.REPLACE SPARK PLUGS IF YOU HAVE OVER 110000 MILES ON THEM.IF SPARK PLUGS BEEN CHANGED ALREADY.IF ENGINE STILL WONT CRANK AND IDLE.CODE SCAN FOR A FAULTY IDLE AIR CONTROL VALVE.
May 12, 2011 | 2005 Honda Element
Lawn mower will not start
check gas tank with light is there dirt in tank? did you change fuel filter? is there spark at the spark plug? try a 2 second spurt of starting fluid in carburetor and crank does it fire?if it does then you most likely need to clean carburetor with carburetor cleaning spray, flush fuel lines with spray and swap fuel filter.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Husqvarna 130bt 130 Bt Gas Powered Backpack Leaf Blower 29.5cc Reb Logo
249 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
