Question about Western Digital Computers & Internet
My Western Digital 1.5TB hard drive USB connection fell off, so the guys in my IT department at my school took off the case and put it into one of those docking stations, but it did not work. Can I ju
WD 1.5TB HD removed from case, how do I get a new one?
    New Friend:
  • 4 Answers
The case can be replaced by any generic replacement case. If your schools IT guys hooked it up to an hard drive bay and saw nothing then chances are the disk is damaged and needs to be recovered using recovery software such as Recouva
Rosewill RX35 AT SU BLK Aluminum 3 5 Black USB 2 0 External Enclosure... Recuva Undelete Unerase File and Disk Recovery Free Download
Posted on Mar 26, 2014
2 Suggested Answers
afterhourspc
  • 106 Answers
SOURCE: I have 1tb western digital
these have software in them for the board in the factory case ...you will have to use a data recovery software to recover contents then reformat the drive OR try installing it as a second drive inside the pc directly to the sata/ide cables not usb. good luck
Posted on May 08, 2011
I have 1tb western digital external hard drive. It fell at the usb port got broken, so I went ahead and took it out of it's orginial casing. Placed it in a docking station and all i get is a blinking...
May 08, 2011 | Western Digital My Book Essential 1TB...
My WD 500g external storage unit started to fail me. The USB connection broke off into the actaul WD outer case. I opened the case and took everything apart except the actual drive. I am wondering what...
Buy a new "empty" external disk-drive case for $30.
Pick one that has "data" and "power" connectors that are compatible with your current disk-drive.
Put the disk-drive into the new case. Done.
Apr 18, 2010 | Western Digital My Book Essential Edition...
Hi i have this "Western Digital WD Passport 250GB Portable" Problem Now! broken one of that pin where usb connect to hard dirve .
I did this once had to solder an interconnect to the other side of the connection of the PCB then use a small croc clip to make the other connection worked just fine just not aesthetic
Mar 21, 2010 | Western Digital WD Passport 250GB Portable...
WD 1tb hard drive mini usb broke off
if you damaged the controler card then you will have to see if someone has a dead drive that you can install your hard drive in there case or (little chance) ask western digital to send you a new controler card or just buy another one
Jan 15, 2010 | Western Digital My Book Essential 1TB...
I dropped my Western digital 1TB hard drive.
The case maybe damage, so could the hard disk.
First try connecting to your computer or to an USB hard drive adapter, if it works then you know the hard drive is OK and you only need to buy a new USB hard drive adapter case.
WinHex is a edit program that allows to you see and modify the data files on the hard disk in ASCII and HEX format. If the hard disk is faulty no programs can access the data on the hard disk.
There are data recovery companies that can recover data from damages/faulty hard disk BUT it will cost you an arm and a leg for their services.
Sep 20, 2009 | Western Digital My Book Essential Edition...
External Hard Drive not operating normally
sounds like you droped your drive or shook the poop out of it
eithor way it's time 4 surgery
first open the case and make sure the plugs are ann pushed in my ide cable fell out 1 time and it did the same thing
if a cable fell out then u might get her back
i asume you have checked your fuse and used a dfferent usb cable first right be cause somtimes as we all know usb cables break and die so we would have tried a different cable b4 you posted this question
Sep 16, 2009 | Western Digital Computers & Internet
USB connector for Western Digital My Book fell off inside
its some difficult to repair. you should purchase a newer case for your Hard disk
Aug 16, 2009 | Western Digital (WD3200JS) 320 GB Hard...
No power on WDelements WD5000
It's not a new hard drive casing that you need, rr_atl, it's a replacement power supply. Western Digital is well know for selling very poorly manufactured power supplies with this hard drive series. The problem you described is a bad power brick.
Jul 31, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
Usb connection failure
ok" take a small needle , streighten the pin very carefully.
Jan 21, 2008 | Western Digital 320GB MyBook External USB...
Computers & Internet Logo
47 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
