Question about Sub-Zero Refrigerators
Sub zero 700 br
It just turns off every 1-4 days. I press start then it goes for another 1-4 days and shuts off. It stays cold and the thermostat can be set up warmer or colder. No water in tray in back of condenser and condenser blades are clean.
  • Sub-Zero Master
  • 842 Answers
Thank you for your information, are you getting a flashing display showing service on the screen? I the past I have found the service light has shown before the unit shuts down. Your unit has thermistors that need information from the compartment to continue to run. The computer defaults when the information is not present and then shuts down. With this being said, the thermistors could be the cause of this issue you have. There are two in each compartment, one on the evaporator other in the compartment itself. If you have a broken wire or corroded, the computer can't detect the compartment is running and will shut done. Normally will flash service within 20 mins of start up. Look into this and get back to me if you need more information.
Good luck,
Posted on Mar 28, 2014
  • Kevin933k Apr 01, 2014
    Ron, no flashing display, just turns off. I did turn off the circuit breaker today for 10 minutes then turned it back on. This was suggested by Subzero technician, so far it has not turned off. He suggested changing the circuit breaker. By the way all "sealed" components
    Are covered under warranty. He feels it is probably the thermostat.
  • 2427 Answers
SOURCE: Sub Zero bottom freezer condensation
Your regrigator may need regassing or there is a fan that pushes the cold air, it may need servicing, the problem is condensation, it cloud also be a small leak, call an AC specialest
Posted on Jul 12, 2008
freetek
  • 5568 Answers
SOURCE: FRIGIDAIRE NOT KEEPING FOOD COLD OR COOL
Higher settings always equal 'colder.' I've never seen a refrigerator/freezer that was in good condition and didn't perform well with the control set to only half of the scale available.
I don't know how old your unit is, or if it has ever been moved, but you may have lost coolant over time or the fan that forces air through the condenser coils under the cabinet may not be running.
You should feel some warm air coming through the front grill while the compressor is running. If you don't, then the coils are unable to dispose of the heat collected from inside the cabinet. These coils do gather a ton of dust over time that reduces their efficiency so you might want to check behind that grill to see how much has accumulated there and carefully remove as much as you can without disturbing the coils too much since they are kind of fragile.
Removing the grill for access is always kind of a challenge but most are held in place by spring clips.
Posted on Sep 25, 2008
  • 56 Answers
SOURCE: sub-zero 601 fridge won't get below 42 degrees
You both sound like you need a qualified factory repairman out there. If there is a blockk of ice on the back wall you have a low charge in the refrigerant system. It is most likely the evaporator or cooling element as you call it which has a five year parts and labor warranty, then parts only for years 6-12. Here is the link to the factory locator site. http://www.subzero.com/locator/locator.aspx?type=0&zip=02030 or call 800-222-7820.
Posted on Dec 06, 2008
  • 59 Answers
SOURCE: my sub - zero 700 br will not cool
It has a refrigerant charge port on it. I sounds as though it has a small leak and has lost freon. I recommend that you call an expert. If you have a good friend in the heat and air business, sometimes they can help you. Otherwise call a refrigerator expert. hope this helps.
Posted on Nov 08, 2009
Testimonial: "this was very helpful now i will know what to ask the repairman about thanks"
  • 71 Answers
SOURCE: Sub-Zero 650 freezer (bottom) too cold. Tried to
probably bad control board. check this. push the on/of key. the whole ref and freezer nedd to stop. if you hear the compressor in the upper part of the unit or the fan. your contol board need replace.
Posted on Apr 01, 2010
40 ec fix sub zero
check on top of subzero with it shut off and you will see a fan pulling air through some fins. those need to be clean and free of dirt if not your system will not get cold enough to meet the thermostat requirements. or you could have a bad thermostat.
May 26, 2012 | Sub-Zero 632 / S
Subzero 695. The freezer is fine, the fridge is getting warm because the lights are staying on when the door is shut. I have taken the bulbs out for now to save my food in there. Any suggestions as to...
Hello Parnn,
I understand thating you are having to problems with you refrigerator one the lights are staying on, second the fridge is not getting cold.
The lights are not turning off because of the light switch. The switch needs replaced it is located on the door jamb so that when the door closes the light goes off.
The secound problem is usually the fan located with the evaperator coil. This fan pulls the air thru the coil and pushes it into the fridge section. When the unit is running you should be able to hear the fan running in the back of the freezer. If the fan is not running the freezer will stay cold but the fridge will not recieve any cool air.
In order to get parts for Sub-Zero Refridgerators you must contact them at 1-800-222-7820 and they will send you to their authorized parts distrubitors.
Thank you for choosing FIxYa.com
Justin
Apr 16, 2011 | Sub-Zero 695/O Side by Side Refrigerator
My sub - zero 700 br will not cool stays at 54 i have cleand it but still will not cool runs all the time as well
Nov 08, 2009 | Sub-Zero 700TR
I replaced the light switch on the subzero 550 and now the frig isn't staying cold. When door is open and I press the switch light goes off so light switch is working.
On sub Zero's this has been a common problem. Pressing with your finger to test isn't good enough. You have to test the switch function, by slowly closing the door to see if the DOOR turns off the lights.
There are so many lights in the food compartment producing so much heat that if the lights are on with the door closed, it will not cool.
When I run into this problem, which is common, I take a thin plastic shim
and tape it on the part of the door that hits the switch. 2" x 3" shim will
work well. If that solves the problem, I put a few drops of crazy glue on the shim and remove the tape a day later.
If the switch has 4 wires to it, the second 2 wires run the fan in the fresh food compartment. You can test that by pressing the switch and listening to see if you can hear the fan in the fresh food compartment start up.
Oct 24, 2009 | Sub-Zero 650 / O Bottom Freezer...
Sub zero freezer compressor wont shut off. Had the thermostat replaced, the warmer replaced, and the compressor tested.
Is the freezer getting cold enough so that it should cut off.
Will it cut off when you turn the thermostat all the way to zero (warmest setting)? If it's cold enough and it does cut off you still have a thermostat problem.
I don't know what a warmer is.
Aug 15, 2009 | Refrigerators
Hello. We moved into a house a year ago that had a sub-zero fridge/freezer. When we go on vacation, the freezer unit sometimes shuts off (from not being used??). To get it working again, we have to turn...
It sounds like it may be the thermostat. turn it down to a normal level and give it a good tap to see if it starts. you may need to leave the door open so it warms up bit so it will start, it wont start if its cold as the thermostat would be satisfied. If it does start the thermostat should be replaced. I hope this helps
Apr 18, 2009 | Sub-Zero Bottom Freezer Refrigerator
Sub zero fridge doesnt turn off
If your temperatures are OK, then you have a bad thermostat control.
Feb 22, 2009 | Sub-Zero 650 / O Bottom Freezer...
Temperature goes up
do you hear any fans running?  by the temp staying cold on the drawers whih are in the lower area of the freezer it indiates to me that the fans are inoperable. to test open freezer door then push in light switch by hand and listen for the fans to come on. if it turns out you have bad motor you most likely will have to call a sub zero dealer to have repaired. messge me back with any questions peyton
Jan 28, 2009 | Sub-Zero Freezers
Refrigerators Logo
53 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
