Question about Maytag MBR2258XES Stainless Steel
Maytag model MBR2258XES4 refrigerator and freezer not cooling well d
Refrig and freezer warm. Found evaporator frozen like a iceberg. Removed food and unplugged refrigerator. Cleared evaporator drain. Restarted unit - cool in freezer and refrig after 24 hours but not cold. Have set on coldest setting. What gives?
    Problem Solver:
  • 6 Answers
I had a similiar problem with mine..it ended up being the defroster board..it seems to kak out every 3 yrs..mine was under the temperature control panel..it was in a white box inder the cover..good luck.
Posted on Apr 08, 2014
SOURCE: MZD 2766GE refrigerator: freezer side is cold but refrigerator side gradually warms after a week and then freezer side warms.
fan won't start by itself.
Posted on Aug 10, 2008
  • 22 Answers
SOURCE: Refrig not cooling Freezer has frost build up on coils
Frost on the coils won't allow air to pass to the fresh food section, thus resulting in insufficient cooling. To eliminate this problem, you will have to get a new adaptive defrost timer ( small board ), and a defrost heater assembly.
Posted on May 04, 2009
  • 351 Answers
SOURCE: Maytag side by side refrig side not working freezer side ok
is the freezer full of frost?
Posted on Jun 29, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Refrigerator won't cool less than 52 degrees
I can tell you if it can be fixed by you or if you need service. Just answer a few questions as we go through this. Pull away from wall and remove the lower panel. Feel top of compressor and see if too hot to keep your hand there or cool. Let me know if freezer fan and fan below are running. Answer those and that will help me answer your questions, Thanks Sea Breeze
Posted on Feb 16, 2010
heatman101
  • 43501 Answers
SOURCE: Maytag Plus side by side (Model MSD2356AEA)not cooling in
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
hhkgjd
Posted on Sep 29, 2010
THE FREEZER IS BLOWING WARM AIR
Hello and Welcome to Fixya,
This is one of the most common problems in most of the refrigeration appliances. What's going on here is that the condensate drain hole in the freezer gets plugged with ice. Once this happens, all the frost melted off the evaporator during subsequent defrost cycles can no longer drain and so spreads out on the freezer and dribbles down and also chokes other components. Here are the instructions that you need to follow inorder to get rid of the problem:
  • Unplug the refrigerator and pull everything outta the freezer, and I mean everything.
  • Remove the bottom panel inside the freezer so you can see the condensate trough in the back of the freezer.
  • Notice that the condensate trough is filled with ice- all that has to be cleared out.
  • Take it easy back there, delicate parts are exposed- don't start hacking at it with an ice pick because there are chances that you'll just end up puncturing the evaporator and you'll turn a simple, inexpensive repair into a majorly expensive one.
  • Use hot water to drain all the frosted ice that is visible.
  • Re-place all the units removed during the process.
  • Once all the ice is cleared away and the condensate drain opening is cleared, you are done.
Best of Luck,
Please do rate my solution, If found helpful.
Regards.
Nov 20, 2010 | Roper RT18HDXKQ Top Freezer Refrigerator
Maytag side by side refrigerator/freezer
the drain is frozen, needs to be cleared, hose on lower back of cabinet
Jul 09, 2010 | Maytag MSD2756G Side by Side Refrigerator
Model 78182891 Coldspot with excessive water Collecting in Refrig
a plugged or frozen drain is a common problem that occurs from time to time in just about all refrigs so the answer is yes it may occur again in the future. But folllow theses directions and it will probably not occur again for 2-3 years.
  • Unplug refrigerator
  • unload food from freezer
  • remove icemaker if present (there are 3 screws remove the one on the bottom and loosen the 2 on top of icemaker then lift it off the 2 screws unplug from wiring harness)
  • remove 2 screws holding rear cover in place
  • move cover to the side or remove from unit altogether
  • defrost any and all ice from bottom of freezer and aluminum drain pan that is now exposed
  • flush drain hole that you will see once ice is cleared with warm water. (sometimes I use a large syringe or turkey baster to forcefully flush hot water thru the drain tube)
  • reassemble in reverse order
Post back if you have any questions and I'll gladly help you out Thanks Peyton
Mar 17, 2009 | Kenmore Refrigerators
Most likely whats happening is you have a frozen drain for the defrost cycle. here are step by step instrutions for repair:
Post bak if you have any questions and I'll gladly help you out Thanks Peyton
Mar 14, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water collecting inside, under the crisper drawers.
ok these are instructions for cleaning the drain on your refrig.
If you have any further questions please ask. Thnaks Peyton
Mar 14, 2009 | Refrigerators
Water in refrigerator, freezer is cold refrigerator is not
sounds like you have a frozen defrost drain. This is a fairly easy repair you can do yourself.
that should fix you up. if you have any further questions leave me a comment here and I'll gladly help any way I can. thanks Peyton
Mar 11, 2009 | Kenmore Refrigerators
Roper frig, freezer on top ,frozen under tray.water in bottom of frig
that should fix you up. if you have any further questions leave me a comment here and I'll gladly help any way I can. thanks Peytonreassemble in reverse order
Feb 23, 2009 | Whirlpool Refrigerators
Amana refrigerator warm
Chances are if they are getting cool but not cold-
1) the evaporator fan in the freezer is not running
2) Defrost heater has failed
3) Defrost sensor has failed
4) Defrost timer/refrigerator control has failed.
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator.
Plug the unit back in or turn it back on, close the doors, and check temperature after a couple of hours of operation. If all OK, you will need to have the above tested, or, if you know how to use a multimeter and can read a schematic/wiring diagram, I can instruct you on how to check the above.
Jan 20, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Ice acculumates in the bottom of freezer
Defrost drain tube is plugged. Drain is a round hole about the size of a quarter below the evaporator coils. (behind back wall of freezer.) Take a turkey baster with hot (not boiling) water and shoot it into the drain hole until water runs through it (into drain pan under refrig.)
Aug 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag MBR2258XES Stainless Steel Logo
230 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
