Question about Humminbird 587Ci Combo ()
My 587 shows double screen when on full screen
When it is down imaging it dont show my full screen like in the simulator. it worked for a while is there a reset button so i can go back to 0
I have a lexmark x4550 and I am trying to scan old photos so I can insert into a slide show. But the pictures scan in small with large white edge around it. I am guessing I need to change the image...
Open the Lexmark Imaging Studio on your computer. From the desktop, double-click the Lexmark Imaging Studio icon > click Scan > click Custom Settings > change the settings as needed.
Source: Lexmark X3500-X4500 Series Users Guide.
May 26, 2011 | Lexmark C533DN InkJet Printer
Blu Ray showing "split screen/double
Did you check your settings on your tv and blu ray?
Jun 04, 2017 | Televison & Video
I can't get any web player to stay full screen. Youtube, Megavideo, JWplayer, tvdex, hulu, the list goes on. Please help. It isn't fixed by changing the accelerate video settings thing.
If megavideo is full "web browser" page size click the image/player after you hit the green play button and the video is playing, then it opens a new window with the small player in it, then hit the only dark grey button that falls down screen that says like "cinema on" to turn it off and make the player show, play the video, and now you can full screen it and keep it full screened! If plugin questions keep popping up it's because spam ads or the video itself needs you to keep pushing yes.
Jan 31, 2011 | HP Computers & Internet
Tv shows double images
Look for the convergence menu in the manual and try to align it.
Apr 02, 2009 | Toshiba TP55H60 55" Rear Projection...
Double images
you will need to have the tv re converged to make the picture right call a repairman
Feb 16, 2009 | Samsung HCM4215W 42" Rear Projection...
Pictures won't show on screen
I have checked to see if I can simulate your problem on my D70.
There are no settings on the Set-up menu to turn off the display.
The display should show for a minimum of 6 seconds after a phot is taken.
You can reduce the screen brightness but that will not turn it completely black.
I presume you have eliminated all other possibilities by changing batteries, card, lens etc..
If so, it would suggest an LCD screen failure which would necessitate a repair by a Nikon agent.
Jan 21, 2009 | Nikon D70s Digital Camera
When creating a Kai's Power Show quick show the images in the slide show are always much smaller than the computer screen images on the monitor or projector. When projecting a show this not a problem,...
Pose your problem in a Kai's Power Show category, natch.
Then the experts can tell you to configure quick show and save your configuration.
You should probably let people on to what version you're using, and double-check that you haven't specified a need to keep room in the matte for the full file-path, title, metadata, and other stuff that would use up the other 3/4 of the screen in the show template you saved last time.
Girl, would -that- be a space-killer.
Jul 27, 2008 | Computers & Internet
Nikon Coolpix L11 - LCD screen shows double image
It could be a loose LCD connection carefully take off the back and lift the LCD very carfully you will see the ribbon cable lift the tab take out the LCD and reinsert it and push the tab back down. If this does not fix it you might have a damaged main board its one or the other.
Apr 04, 2008 | Nikon Coolpix L11 Digital Camera
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Humminbird 587Ci Combo () Logo
27 people viewed this question
Top Humminbird Boating Experts
Mike Marcotte
Mike Marcotte
Phil Walker
Phil Walker
Steve
Steve
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
