Question about Ford Vehicle Parts & Accessories
1999 Ford Windstar engine installation
Install crate engine in 1999 Ford Windstar
  • Ford Master
  • 2,760 Answers
Your gonna need a lift to put it on, as that ones gotta go up from underneath van , but first ya gotta unhook and lower old one, remove engine from transaxle and push it back up from underneath , takes more than 14 man hours to do getting everything hooked back up again , steering was the bigest obstacle to work around , nothing the home garage mech should attempt his self
Posted on Apr 04, 2014
1999 fORD WINDSTAR IDLE PROBLEM
what code comes up when the engine light comes on
Aug 02, 2012 | 1998 Ford Windstar
What kind of battery is recomended fora Ford Winstar 1999 in terms of durability and capacity to feed the alternator properly?
There are two different engines Ford installed in the Windstar. The following information is assuming your vehicle has the 3.8 liter v-6...850 cold cranking amps, 750 cold cranking amps, 650 cold cranking amps, or 720 cold cranking amps. It is highly probable that your vehicle has the 3.8 liter, as 94% of Windstars had that engine installed. Hope this helps you out.
Jun 23, 2010 | 1999 Ford Windstar
Will at 1998 ford windstar transmission fit in a 1996 ford windstar
YEP IT WILL WORK MATCH UP YOUR ENGINE.YOU HAVE A 3.0 OR 3.8 BOTH ENGINES CAME IN THE FORD WINDSTAR 1996 TO 1999.TRANSMISSION WILL FIT.
May 21, 2010 | 1996 Ford Windstar
1999 Ford Windstar-Will Turn over but won't start?
fuel pressure regulator could hav failed-located by engine or the ignition module may not be workin-by dist area try not to be a parts replacer-buy a repair book
Jan 09, 2010 | 1999 Ford Windstar
How to replace starter windstar 2003 V6 engine?
2003 Ford Truck Windstar 3.8L SFI 6cyl Repair Guide
Ford Windstar 1999-2003 - Starter Removal & Installation
  1. Disconnect the negative battery cable.
  2. Raise and support the vehicle safely.
    NOTE When removing the hard shell connector at terminal -S-, grasp the plastic shell. Do not pull on the wire.
  3. Disconnect the starter electrical harness.
  4. Remove the upper starter bolt.
  5. Support the starter and remove the lower bolt.
  6. Remove the starter from the vehicle.
  7. Fig. The starter is located at the lower front of the engine, and is visible through the air duct
To install:
  1. Position the starter in the vehicle.
  2. Install the upper and lower bolts. Tighten to 15-20 ft. lbs. (20-27 Nm).
  3. Connect the starter electrical harness. Tighten the starter cable nut to 80-124 inch lbs. (9-14 Nm).
    NOTE When installing the hard shell connector, be careful to push it straight on and make sure it locks in position with a notable click or detent.
  4. Lower the vehicle.
  5. Connect the negative battery cable.
I really hope helps with this (remember rated this help) Good luck.
Dec 31, 2009 | 2003 Ford Windstar
Location intake air sensor 1999 ford windstar 3.8
follow your airbox usually front right side of engine and there should be a grommet or a similar attachment holding the sensor into the hose.
Mar 30, 2009 | 1999 Ford Windstar
1999 ford windstar trailer light install
use the tow connector located behind the tire jack mount at the rear :)
Mar 22, 2009 | 1999 Ford Windstar
Went to start 1999 ford windstar explosion
Yes it can be fixed - I have seen this before as the plennium is plastic and mostly is replaced for a part of it cracking off in side the engine and making ticking noice when idling. check the price with the dealer I am sure they will have it in stock and would change 2-3 labour install
Nov 20, 2008 | 2000 Ford Windstar
Vehicle Parts & Accessories Logo
59 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
