Tp link 5210
Hi all i have asame tp link 5210 Ac point and 3 other clients take internet from ac point 5210.Every one day i must restarted because freezing , blooking.i cant conect my laptop to ac point if i not restarted before.why that?
  • 7,733 Answers
Try to update the firmware.Here is the link TPLINK
Download for TL WA5210G V1
Posted on Apr 08, 2014
Testimonial: "I did this before, but nothing.i have buy 3 pieces because im a tehnician, i work with wifi antena.because i can`t faind a wai i change the marka.other marka is verry good. i dont have problem now. i think tp -ling 5210 have problem wint the channal fregvency maby. i wait for a help to resolve my problem for tp-link 5210. Windows was unable to connect to "Tp-link Acpooint" << that is the problem,but if i restarting antena after that is working about 1 day maby. Please heelp. thanks again"
  • Doctor PC
    Doctor PC Apr 10, 2014
    What is your OS? Restart the antenna? or router? Connect or not? Please clarify.TKS
5 Suggested Answers
  • 17 Answers
SOURCE: d-link dwl-2100ap in WDS mode Received Deauth: WLAN 1 11G STA
I have had similar problems with DWL-2100 and (much less often) with DWL-3200. I have no solution, but a workaround: changing the authentication mode. For example, if the units are using WPA-Personal, I change it (on both) to WPA2-Personal or WPA-Auto-Personal. It doesn't seem to matter which mode is used, it's just the fact of changing it that helps (eventually). You may have to go through the process more than once. Also, realize that although the web interface comes up 30 seconds or so after a reboot, it may take another 30-60 seconds before a link is established, so don't give up too soon while trying these changes.
Posted on Apr 23, 2009
veenu goel
  • 38 Answers
SOURCE: how to configure my tcp/ip TP-link access point
click on start
go to run
then type cmd
type ipconfig (in case of window)
Posted on Nov 06, 2009
zhu_1754431
  • 108 Answers
SOURCE: i have installed my new
in your network connection, there is an Internet protocol(tcp/ip) double click it. put in obtain ip address automatically. same in dns server then ok.
If not work, configure it manually by using your laptop copy the ip addresses in your laptop, including subnet mask, and defualt gateway, and put it to your pc..
hope it can help you.
Posted on Dec 27, 2010
puertobori
  • 7733 Answers
SOURCE: set up TP-LINK TL-WA701D 150mbps wireless N access point
SET IT BY INSERT THE CD AND FOLOW THE INSTRUCTIONS.
Posted on Dec 19, 2011
Reboot
Manual
http://www.tp-link.com/resources/software/200912243240113.pdf
If you are using this with POE, there have been complaints that Ethernet links over 15 metres or poor cable quality can cause this effect.
Also there are warnings in the manual about keeping it clear of electrical RF interference which may also cause this effect.
Jul 23, 2014 | TP-LINK TP link TL-WA901ND 300 / 11n...
Tp link 5210
You can use repeaters but its not an ideal solution. You may need repeaters at every 100m which means 10 repeaters plus internet or connectivity is not guranteed. Because distance is very large. Look for an alternate ISP connection or something.
Jan 23, 2014 | Computers & Internet
I can surf the internet trough my laptop, but i cannot connect the internet trough my handphone...
Reconnect the wireless to your phone.Most Likely your phone will be the problem, not the TP Link.
Feb 21, 2013 | TP-LINK Computers & Internet
I HAVE A PACKARD BELL VERSA E 400 AND AFTER A FORMAT I DONT HAVE THE DRIVERS NEEDED TO INSTALL NEW WINDOWS SOFTWARE PLEASE HELP!!!!
Hi george,
Windows comes with the necessary basic drivers such as video and keyboard support etc. You will need to download the other drivers for each of your hardware devices.
For example, if you had a TP-LINK 2405A Wireless Card,
Google "TP-LINK 2405A Wireless Card Driver"
and a AC-97 Sound Card "Ac-97 Driver"
If you could clarify what drivers you are missing that would help me help you alot easier.
hope this helps you, Best of luck.
Jul 10, 2011 | Computers & Internet
How to use switch?? this is the topology INTERNET->MODEM->ROUTER AS AP ->...
Switch learns network MAC addresses And controls the network packets to reduce broadcast packet traffic on your network !
INTERNET V MODEM V Back of router ethernet port 1 V ROUTER AS AP Wi Fi Back of router ethernet port 2 V Switch Port V V
-> STATION Client/ /CLIENT ' Local/Lan
or
INTERNET V MODEM V Could Place Switch in Here instead Switch Port V V V ROUTER Station V AS AP Wi Fi client V V Client/ Local/Lan
May 03, 2017 | TP-LINK TL-SF 1008 P 8-port 10/100 PoE...
I could not loged in to the web based configuratin page of 5210
Turn off the router.
Press and hold small reset button (usually with a pin or pen) for 1 minute.
While still holding the reset button, turn the router back on and keep holding reset button for 30 seconds.
This will completely reset your router. The username/password will be set to default. (Usually Admin/Admin)
Feb 28, 2011 | TP-LINK TPLink TLWA5210G 24GHz High Power...
DRIVER TL-WN651G WIRELESS ADAPTER THX
This is a link to the a site with the driver download.
Mar 02, 2010 | D-Link DI 1135C-3/TP (DI-1135C-3/TP)...
Proscan 40" TV from Best BUy - screen freeze, screen goes blank
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jun 23, 2017 | Proscan 26LB30QD 26 in. LCD HDTV
Computers & Internet Logo
151 people viewed this question
David Payne
David Payne
