Connecting mac to celcus tv
I am using a mini display port to HDMI Adapter from my Macbook Pro to my Celcus TV it used to work and I could watch Netflic etc but no for some reason it doesn't work anymore and when I attach the lead to the TV and select the correct HDMI channel it just says 'No Signal'. Can someone help me fix this? I don't know if I should be selecting a certain thing to make it work
  • 4 Answers
SOURCE: No signal input when connecting PC to LG TV via HDMI
Do you also have a computer monitor attached to the computer when attempting to use the HDMI?
Posted on Mar 30, 2009
SOURCE: I'm trying to hook my Macbook Pro to my TV
Hi
It may just be possible that DVI signal does not convert to HDMI signal. So in theory this may not be possilbe for you to get a result with your present attempt. May i suggest connecting to the DVI port of the TV. i.e Mini Display to DVI.
Regards
Posted on Dec 30, 2009
  • 63 Answers
SOURCE: I just bought the LG
YOU USE VGA PORT FOR CONNECT LG MONITOR .
Posted on Sep 07, 2011
gopakumarg43
  • 73619 Answers
SOURCE: What is the 'One4All' remote code for Celcus TVs?
Try these codes. If it do not help you, Try code search method.
0147 0135 0250 0257 0310 0394
Code Search Method
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Posted on Apr 06, 2012
SD Tech
  • 14553 Answers
SOURCE: channel selector doesn't work
If only 1 button does not work it may be a problem where some liquid got inside--
Some units have a lockout feature which will disable most or all buttons on the remote and or the set.
If set changes channels with the buttons on the set problem is with the remote--they can be tested easily.
Posted on Apr 16, 2012
What cable is needed to stream Netflix to a Macbook?
If you want to use a TV as a secondary or mirrored monitor. All you would need is a Mini-DVI to HDMI adapter. Use the adapter to connect an HDMI cable between your computer and the TV. Once connected you will have an option to use it as a secondary or mirrored (exact copy of what is on your laptop) monitor. If you have one of the newer macbook pros you need a Mini Display port to HDMI adapter.
Jul 30, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Tip
Connect you HDTV to your Mac.
One of the first things you may notice about your new big-screen HDTV is that it has more connections for video than your old TV ever dreamed about. It probably has two or three HDMI connections, maybe a DVI connector, a VGA connector, and at least one component video connection. And those are just the connections most commonly used for high definition.
It’s shame to let all those connections go to waste. Your Mac just happens to be sitting nearby; why not hook it up to your new HDTV? It's actually a pretty easy task. A few lucky souls won't even need an adapter; for the rest of us, at least one adapter will be necessary.
Pick the Right HDTV Port For best quality, your HDTV's HDMI or DVI ports are the preferred connection method. Both are capable of the same digital quality. The only practical differences are the style of the connector and the fact that HDMI supports video and audio in a single connection. If it has one, another option is to use your HDTV’s VGA port. The VGA connection isn't as good as the HDMI or DVI method, but as long as your TV supports full resolution via the VGA port, you'll be hard pressed to notice the difference. Mac Pro, MacBook Pro, Mac Mini Mac Pros, MacBook Pros, and Mac Minis have standard DVI connectors. Mac Minis and MacBook Pros have a single DVI port; Mac Pros have at least two DVI ports. If your HDTV has a free DVI port, then all you need is a standard DVD cable; no adapter is necessary. But in all likelihood, you'll need to connect your Mac to your HDTV using either an HDMI or VGA connection; both options require an adapter. If you choose VGA, you can use the adapter that came with your Mac. If you choose HDMI, you'll need a simple adapter, which is available from multiple sources. The adapter may be a cable with a DVI connector on one end and an HDMI connector on the other, or it may be a small adapter that has both types of connectors, but no cable. Either type will work fine. iMac, MacBook iMacs and MacBooks have a mini DVI connector for hooking up external monitors or TVs. You'll need at least one adapter, maybe even two. At a minimum, you'll need a mini DVI-to-DVI adapter. You may also need a DVI-to-HDMI or DVI-to-VGA adapter, depending on which port on the HDTV you choose for the connection. Make the Connection Once you determine which, if any, adapters you need, and have the necessary cable to reach from your Mac to the HDTV, turn off both the HDTV and the Mac. Connect the cable between the Mac and the HDTV. Turn the HDTV back on first. It doesn't need to be set to the connection the Mac is on, but it must be powered up first, so that when it boots, your Mac can recognize the TV and the resolution it needs. Once the HDTV is powered up, turn on the Mac. Your Mac should recognize the format and resolution of the TV, and automatically select the native resolution of the TV for running the video. In a few seconds, you should see the Mac desktop on the HDTV. Over or Underscan You may notice that the Mac's desktop appears to be slightly larger than the HDTV's screen (its edges are cut off); this is called overscan. Or, you may notice that the desktop doesn't occupy all of the HDTV's screen real estate (there are dark areas around the edges); this is called underscan. You can usually correct either issue by making adjustments on the HDTV. Check the HDTV's manual for information on making scan-related adjustments. They may be called overscan, underscan, dot-by-dot, or pixel-by-pixel. If your HDTV has a dot-by-dot or pixel-by-pixel capability, give this a try; it should eliminate any over or underscan issues. Some HDTVs only offer these special scan controls on specific inputs, so be sure to connect to the corresponding input on your HDTV. Time to Watch a Movie Once you have your Mac and HDTV working together, it's time to kick back and watch a video from your Mac. Be sure to check out the QuickTime HD trailers for a sense of what HD and your Mac is capable of. Enjoy!
on Feb 22, 2010 | Computers & Internet
How to connect my macbook pro to my 50' sanyo lcd tv and get picture and sound
This all depends on how old your MacBook Pro is. If your laptop was made in the last 2 years you probably have a mini-display port plug on the left hand side of your laptop next to the usb and firewire ports. You will need to buy a mini-display port adapter to HDMI from apple or a third party and this adapter will allow you to get the video out of your laptop onto your TV. As for the sound, you will need a 3.5mm adapter to plug into your headphone jack. Plug in some yellow and white RCA audio cords from the adapter to the TV sound inputs. This should take care of that.
If you are looking to watch videos from your Mac and you own a PS3 or an Xbox 360 you can use ps3mediaserver and download the Mac version. It will allow you to stream videos from your mac to your tv through the console. This should work by just starting the software, making sure both the mac and the console are connected to the same network or router and it should just automatically show up on the console and you can navigated it with the controller and view your videos. Read the help me section of the ps3mediaserver software for more info on sharing all your videos.
Good Luck.
Apr 29, 2011 | Sanyo Televison & Video
How do you connect a mac to an HDMI device and can you get sound to the tv ?
Hey, you would need a Mini display to HDMI cable and unfortunately the sound cannot be ported through the mini display port.
Mar 14, 2011 | Apple Customized 15" MacBook Pro Laptop...
When I connect my unibody macbook pro to my old tv using a vga to tv converter, my computer doesn't even recognize the disyplay.
When you connect your tv to your mac, make sure the cables are plugged into the TV first, and then plug your mac into the computer.
But a vga to tv converted doesn't make much sense. Your connection should be mini-display from your mac, to an adapter to either VGA, DVI, or HDMI depending on your TV connection type.
Dec 31, 2010 | Apple Computers & Internet
Trouble connecting Insignia HDTV 19" to my macbook pro
Pick the Right HDTV PortFor best quality, your HDTV's HDMI or DVI ports are the preferred connection method. Both are capable of the same digital quality. The only practical differences are the style of the connector and the fact that HDMI supports video and audio in a single connection.If it has one, another option is to use your HDTV’s VGA port. The VGA connection isn't as good as the HDMI or DVI method, but as long as your TV supports full resolution via the VGA port, you'll be hard pressed to notice the difference.Mac Pro, MacBook Pro, Mac MiniMac Pros, MacBook Pros, and Mac Minis have standard DVI connectors. Mac Minis and MacBook Pros have a single DVI port; Mac Pros have at least two DVI ports.If your HDTV has a free DVI port, then all you need is a standard DVD cable; no adapter is necessary. But in all likelihood, you'll need to connect your Mac to your HDTV using either an HDMI or VGA connection; both options require an adapter. If you choose VGA, you can use the adapter that came with your Mac.If you choose HDMI, you'll need a simple adapter, which is available from multiple sources. The adapter may be a cable with a DVI connector on one end and an HDMI connector on the other, or it may be a small adapter that has both types of connectors, but no cable. Either type will work fine.iMac, MacBookiMacs and MacBooks have a mini DVI connector for hooking up external monitors or TVs. You'll need at least one adapter, maybe even two. At a minimum, you'll need a mini DVI-to-DVI adapter. You may also need a DVI-to-HDMI or DVI-to-VGA adapter, depending on which port on the HDTV you choose for the connection.Make the ConnectionOnce you determine which, if any, adapters you need, and have the necessary cable to reach from your Mac to the HDTV, turn off both the HDTV and the Mac. Connect the cable between the Mac and the HDTV.Turn the HDTV back on first. It doesn't need to be set to the connection the Mac is on, but it must be powered up first, so that when it boots, your Mac can recognize the TV and the resolution it needs. Once the HDTV is powered up, turn on the Mac.Your Mac should recognize the format and resolution of the TV, and automatically select the native resolution of the TV for running the video. In a few seconds, you should see the Mac desktop on the HDTV.Over or UnderscanYou may notice that the Mac's desktop appears to be slightly larger than the HDTV's screen (its edges are cut off); this is called overscan. Or, you may notice that the desktop doesn't occupy all of the HDTV's screen real estate (there are dark areas around the edges); this is called underscan.You can usually correct either issue by making adjustments on the HDTV. Check the HDTV's manual for information on making scan-related adjustments. They may be called overscan, underscan, dot-by-dot, or pixel-by-pixel. If your HDTV has a dot-by-dot or pixel-by-pixel capability, give this a try; it should eliminate any over or underscan issues. Some HDTVs only offer these special scan controls on specific inputs, so be sure to connect to the corresponding input on your HDTV.Time to Watch a MovieOnce you have your Mac and HDTV working together, it's time to kick back and watch a video from your Mac. Be sure to check out the QuickTime HD trailers for a sense of what HD and your Mac is capable of. Enjoy!
Feb 22, 2010 | Insignia 19 in. Widescreen Flat-Panel LCD...
I have a macbook and want to hook up to my dynex 24 inch tv. I am successful using (mini dvi to dvi to hdmi) connection to the tv receiving great video. My problem is that I have no been able to get audio...
Your mac would have to have a fully hd compliant mini port. To be honest I havent even checked to see if any do. Then you would want to get a mini video port to HDMI adapter. If you don't have one of the newer Intel mac then chances are you cant do sound through that port, which is what your tv is looking for on the hdmi port.
Easiest solution is to hook your headphone port on your laptop to a stereo or some decent computer speakers, which usually sound better than tv speakers anyway.
Jan 08, 2010 | Apple Computers & Internet
I'm trying to hook my Macbook Pro to my TV (Samsung 50'' Plasma 720), I have all the cables needed to hook up sound and picture. I have the Mini display port to Dvi Adapter and Dvi to HDMI cable. My...
Hi
Regards
Dec 29, 2009 | Apple Computers & Internet
I have connected my macbook to my tv using mini
Later MacBook (Pro) use a mini-DVI connector that does not pass analog needed for composite or S-video. Was yours ever working? And most DVI connectors do not pass sound as seen by your cabling. You cannot detect display through RCA. You just set it in Sys Prefs :: Displays, try some other settings, although your seem right.
I have a white early-2009 MacBook and mini-DVI to HDMI adapter (monoprice <$10) and HDMI cable and have not connected the TOS-link for sound, yet--just slideshows at 1920x1080. You will get a much better picture digitally. -Ken
Jul 13, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
TV won't recognize signal from a DVI to HDMI input adapter
I had a similar problem with a Mac Mini.  The problem was caused by a mix-matched resolution (the Mac tries to use 75Hz refresh rate, TV expects 60Hz).  The best solution I found was to remote into the Mac (I used LogMeIn.com) and change the resolution on the Mac from a remote computer until the image appears on screen.
Process: 1) Connect Mac to a normal monitor and install the LogMeIn server (or other VNC type application) 2) Connect the Mac to the TV 3) Connect to LogMeIn from another computer (preferrably one where you can see the TV) 4) Go to Applications / System Preferences / Display 5) Change the resolution to your TVs native resolution, and change the refresh rate to 60Hz
Apr 08, 2009 | Westinghouse Televison & Video
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
Electro Med Services...
