Question about Kenmore Refrigerators
Need parts need to order the clear bars that go in the door that holds back items
    Prodigy:
    An expert who has answered 500 questions.
  • Kenmore Expert
  • 650 Answers
Searspartsdirect.com would be your best bet
Posted on Apr 13, 2014
Need to speak to a customer service person regarding sending package back
contact the company direct by phone that you were returning the item to and sort it out
Sep 29, 2016 | The Watches
Door not closing
with the door open, look at the latch mechanism.. it is usually a two finger item or a one finger item that hooks on the stud or heavy bar mounted on the body door facing..these fingers must be in alignment in order for the door to close..while working the door release try to reset thes fingers by opening them up by hand as wide as they will go..some are spring loaded and may pop back to preset position.. now if the door has been"sprung" it will need readjusted to fit the body of the car..(was there an accident with the car or did a gust of wind pull the door open?)..this issue can be addressed by a body shop...good luck..
Jan 21, 2013 | 1991 BMW 5 Series
Our back door (double glazed with locks at top, middle and bottom) has become permanently locked from the inside. It would appear that the lock at the top has bolted shut. (We have safestyle doors and...
Hi, W/D here.
Easy fix. Your upper locking bar has slipped. While someone is holding the door handle in the open position, you'll need to push the upper lock bolt back far enough to get the door open. You can slide it back carefully with a screwdriver or knife, a little at a time, while holding slight tension on the door with the handle. OK, door's open. Remove the inner door lock cover plate. The lever and locking knob will come off with it. Remove the mortise cover plate, on the edge of the door. Insert a small, thin bladed into the upper alignment slot in the lock behind the mortise cover plate, and loosen the upper allen screw behind the inside lock cover plate. Use the screwdriver to engage a slot in the locking bar, and raise or lower the bar until you have it level with the alignment slot. Tighten the allen screw.
Sometimes, the bar is so far out of alignment that you will have to gain access to the other end of the bar, in order to raise or lower it. This is done by removing the plastic cover on top of the door, and using needle nosed pliers to move the bar.
This should fix you up.
Best regards, --W/D--
Jan 28, 2011 | Locks & Locksmithing
I have a Frigidaire freezer that I bought in 1994. It's a 17 cubic foot upright, model #FFU17M6AW. I need to replace one of the brackets that hold the bars for the door shelving in place. It's a plastic...
you can most likely order this part from marcone appliance parts or allbrands appliance parts they both have websites and both mail to your door marcone will most likely be able to steer you in the right direction hope this helps
Jul 13, 2010 | Frigidaire Freezers
Poulan Pro Chainsaw chain tensioner is junk -- chain now goes from tight to falling off in 1 cut. Model PP4620AVX. Looking for more foolproof mechanism!
Hammy if you scream loud enough Poulan may foot the bill for this.
Poulan “PP4620AVX” IPL (exploded parts list)
We are going to replace this page 2; item 70
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2009/NIUS2009-PP4620AVX-545103410-952802169.pdf
Poulan “PP4620AVHD” OM
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2005/NOUS2005_545047502.pdf
Poulan “PP4620AVHD” IPL
http://www.ordertree.com/modelinfo/PWE/PP4620AVHD-Gas-Saw/75.PP4620AVHD-Gas-Saw.1.59.1.html
With this; “Handle, Chassis & Bar Assembly” print; item 67; ChainBrake Assembly; $21.83.
You also need;
  • Item 68; Bar Mounting Nut; $0.56 each (need 2) and
  • “Engine Assembly” print; not illustrated; part number 545006011; Scrench; $9.75.
This is the configuration professionals have used forever. The only thing to remember here is to hold the nose of the bar up when adjusting and tightening the bar nuts.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 18, 2010 | Poulan Pro Chain Saw 46cc 20"
Need parts cant find them i need the part that holds the oil tube in the bar oil tank
I find 2 that may apply
Model 107624 saw; item 9; pn 107721-01; Hose Retainer dead end at RemingtonPower.
Master Parts
http://www.masterparts.net/Merchant2/merchant.mvc?Screen=SRCH&Store_Code=MPD
cursor down to the “Search For The Following Word(s):” window, type “107721-01” and click the
[To Order Or Search Type Part Number Above And Click Here] bar below.
I was pleasantly surprised to find it, $2.10
Model M30016 saw; items 13 & 14; pn(s) 113030-01 & 113003-01; Oil Reservoir Grommet & Oil Connector. Both available here:
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
  • Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
  • Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
  • Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
113030-01 $1.40 & 113003-01 $1.88
I invested quite a bit of time in this that would have been saved had you included a model number. Brevity in a question where the item cannot be seen or touched costs us both time and frustration. Please include the model number in future inquires.
Are you aware RemingtonPower is no longer in production? Soon eBay will be the only source of replacement parts.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 20, 2010 | Remington 16" Electric Chain Saw
Marvel, Model 61 RF ww-F made in 7-19-2000
Dear John,
Contact the factory directly at 800-223-3900 8:00am to 5:00 pm EST. I believe the bar pn is 42241938 (for the 2nd and third bar) and the top bar pn is 42241937. (I am going by memory so have them verify it). They also have a kit that has both side hinges and new springs for the freezer door. If you can't get through via phone contact Tim Malloy using tmalloy@northlandnka.com. He's a little overloaded but should get back to you within a day or two.
Nov 01, 2009 | Marvel 61RFxx 24-inch Refrigerator/Freezer
Door won't open from inside
Most part like this are dealer items, if you go by the dealer they can pull up a picture of all the parts and you can show them what you need. They will either have it in stock or order for you,
Feb 24, 2009 | 2002 Jeep Grand Cherokee
AEG LAVERMAT
Thank you for your inquiry with Reliable Parts. Your research is as follows.
DOOR HANDLE FOR DANBY MODEL DWM5500W-1
Part number: 660137
Price: $ 6.99
Availability: in stock
All items need to be prepaid with a visa or a master card. No returns on electrical items, factory orders or damaged parts. All other returns are subject to a 20% restock charge. No returns accepted after 90 days from the date of purchase. Please add $4.95 for special factory orders. If you would like to order the part online, please visit our website and type in the part number in the quick find box. From there you can add to a shopping cart and check out online 24/7 If you have any other questions or for phone orders you can contact us at the numbers listed below.
Thanks again Shane Lyth
Reliable Parts
206-575-1791
slyth@relparts.com
1-800-666-0313 ext 1791
Online customer has requested assistance for the following part search:
Brand Name: Danby
Item Description: WASHER DOOR HANDLE
Model & Serial Number and Full Description:
DANBY MODEL DWM5500W-1 FRONT LOAD WASHER THE DOOR HANDLE BROKE OFF . THE LOCK MECHANISM STILL GOOD. NEED ONLY THE PLASTIC PART OF THE DOOR , WHERE THE HANDLE IS ATTACHED. THE SEE THROUGH WINDOW IS GOOD.
Nov 02, 2007 | Danby DWM5500W-1 Energy Star 1.69 Cu.Ft....
Refrigerators Logo
23 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
