How do I replace a battery o Trio stealth -9 ?
U suggested a new battery. Where do I put it ?
  • 3,320 Answers
This is a tablet question
Posted on Mar 26, 2014
My trio stealth g2 when you recharge the battery it only charges up to 50 percent and stops What can I do to get the battery back up to 100%?
The only way will be to replace the battery. Lithium battery's only have a limited service life, and begin to degrade quite markedly after a couple of hundred charges. The older the battery is, the less capacity it has for storing electricity, so your Tablet has detected that the battery within has lost 50% of it's original capacity. If the Tablet is relatively new and you have not recharged it many times, you may be able to claim a replacement battery under warranty from the supplier {:o)
Dec 31, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Trio stealth tablet will not go past logo
This may be unrelated, but if you let the tablet go to sleep it will drain the battery. I found this out with my Stealth Pro about three months ago, I imagine it is more of an Android issue. It would not startup or go past the opening logo until I had charged it enough. This may also be the case if the battery is damaged or will not take a charge, in theory.
Aug 21, 2014 | Mach Speed Trio Stealth Pro Trio Stealth...
Where can I buy a charger for my trio stealth g2 tablet?
I was able to use my cell phone charger when my Trio Stealth Tablet charger stopped working. I would suggest first trying to use a basic cell phone charger before going out and spending lots of money on a charger "specifically" for a tablet.
Jul 11, 2014 | Mach Speed Trio Stealth G2 Tablet -...
I have a Trio-Stealth G2-8 and turn on but the screen said @9 Dual Core and don't do anything else can somebody tell me how to fixed?
Its a common problem with tablets and not easy to fix.
Your tablet has a corrupt os and is caught in a boot loop.
There are fixes but not easy for a beginner.
Boot into recovery mode by pressing the power button and holding the down volume button in then select restore tablet from the recovery menu.
Jun 12, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
Battery
Take the back cover off. Remove the battery.
Mar 25, 2014 | Mach Speed Trio Stealth Pro Trio Stealth...
Trio stealth G2-9 battery life will not charge
It's possible your charger is faulty. If your unit can charge with a USB cord through a computer try that. If it charges then your charger is faulty. The charger can be tested with a voltmeter by someone knowledgeable. The other problem possible is that the charging receptacle is faulty. That would show up if the USB method doesn't work. If the charger is o.k. then your battery won't hold a charge and needs to be replaced.
Mar 20, 2014 | Mach Speed Trio Stealth G2 Tablet -...
It turns on goes to @ 9 DUAL CORE and freezes
perform a factory reset if you flip the tablet over there will be the word "reset", there will be a tiny hole just put a pin in for a bit then take it out.
Mar 11, 2014 | Mach Speed Trio Stealth Pro Trio Stealth...
Charge trio g2
Hi Jennifer,
Battery error or charger error.try with new charger or usb cable.
if you have warranty you have no problem and go for warranty.
regards.
nuwan
Jan 10, 2014 | Mach Speed Trio Tablets & eReaders
Trio stealth G2 Hype only gives me a battery picture and doesn't come on after charging
I've tied finding an answer. Nothing works. Get a new one, or if you still have a warranty, get it fixed
Sep 05, 2013 | Mach Speed Trio Stealth G2 Tablet -...
88 people viewed this question
 Grubhead
Grubhead
