Question about Cooper Lighting Flood Lights. 180 Degree Motion Activated Solar Powered Floodlight -
Cooper ms34w wont turn off stays on night an day without movment
Cooper ms34w motion activated floodlight stays on after plugged in and stays on and does not activated by movements
    Champion:
  • 203 Answers
Have you had a look at the underside of the motion detector the should be some things for you to a just it with
Posted on Jun 22, 2014
My floodlights Utilitech 6211W-PIR23A come ok but will not turn off at night, on test they work ok.
light sensor failed or covered in dirt. or you have set it on double switch that means the stay on. to turn off permanent light flick the power on to the lights on off on. should go back to timer that has been set. 3 5 10 min.
Apr 19, 2018 | Utilitech Pro 180-Degree 2-Head LED...
Light remains on all night
turn power off at breaker and back on . some use that as a reset .
Jan 19, 2016 | Cooper Lighting All Pro Outdoor Security...
Sounds like the batteries are not getting charged. Check to see if there was some packing material in place to keep the batteries disconnected for shipping.
Dec 05, 2013 | Cooper Lighting Flood Lights. 180 Degree...
Reset instructions for PIR floodlight
There should be a screw adjustment under the PIR unit. Clockwise direction increases the amount of time it stays on and anticlockwise decreases the amount of time it stays on. It's usually a small hole which you can see a slot in which you turn with a screwdriver.
Nov 24, 2013 | Televison & Video
User manual for fl09sbk light
It appears this device is rate 10 amps at 230 volts = 2300 watts.
Use at least #14 wire and 15 amp breaker.
Connect wire at connection point on light.
Unit appears to have a transformer, and might make humming sound.
There is override located somewhere on unit. Possibly as a button on the motion sensor
If infrared motion detector requires separate wiring connection, then use following wiring illustration:
http://waterheatertimer.org/images/How-to-wire-motion-sensor-230V.jpg
Motion sensor will probably have 2 settings.
1st setting for sensitivity, so it will not activate when cat walks up driveway.
2nd setting for time duration, selectable from 30 seconds to 7 minutes
ML FL09SBK IP44 36W Fluorescent PIR Floodlight c/w Lamp
IP44 Low Energy Floodlight c/w PIR & Override.
Black finish.
T4 twist and lock lampholder.
36 Watt 6500k T4 spiral compact fluorescent lamp included.
(replacement lamp - product code FL09L).
Electrical termination via 10 Amp connector block within secure enclosure c/w cord grip.
PIR detection range of 12 meters at 2 meter height from ground.
Detection arch of 160 degrees.
Time range 30 seconds to 7 minutes.
Manual override.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 12, 2012 | Woods Outdoor Lighting Timer
Motion sensor light wiring
problem could be sensor, not light, black is power, white is neutral, green is ground, sensor may have a red wire, black wire and a white wire, hook black wire to power from sensor, red to black wire on light,
white wires will connect together, then wire black to power on home, white to white on home and green to ground, if you need help call an electrician and they will wire it for you
Feb 03, 2012 | Home
Installation instructions for a Cooper Wiring Devices OS310U-W-K Motion-Activated Occupancy Sensor Wall Switch, White
LED bulbs with leaking motion sensors tend to flicker as well, more so than CFL. I switched to Cooper style - but now my Cooper OS310u will sense motion - and keep sensing motion almost all the time. If it's in test mode - it will shut off but otherwise it keeps sensing it. This is in a garage - and door open or closed does not seem to affect it. I have the same unit working in my basement just fine.
suggestion - don't try LEDs to solve the problem and yes - it will burn out your CFLs real fast.
Jan 12, 2012 | Electrical Supplies
Cooper Lighting Flood Lights. 180 Degree Motion Activated Solar Powered Floodlight - Logo
399 people viewed this question
Top Cooper Lighting Home Security Experts
Lawrence Oravetz
Are you a Cooper Lighting Home Security Expert? Answer questions, earn points and help others
