Question about Caterpillar E70B Excavator
I have hydraulic oil in my radiator, e70b
I have flushed it repeatedly. But it keeps reaccuring.
  • Arlon Fowler
    Arlon Fowler Mar 25, 2014
    I doesn't use engine oil. It's loosing hyd. oil tho.
  • Floyd Fowler
    Floyd Fowler Feb 07, 2015
    It was the engine oil water exchange cooler mounted on the right side ov the motor. easy to take off and has 2- O - rings inside. Replaced them and all is well.
  • 400 Answers
I am not familiar with that particular machine, but I believe it would more likely be diesel or motor oil, unless of course there is a water exchange hydraulic cooler. If there is, check that for a leak to the coolant. If not, I would check compression on each cylinder, and/or look for signs of a blown head gasket. Other possibilities are probably more serious than even that. I hope this is helpful.
Posted on Mar 25, 2014
  • 1 more comment
  • Arlon Fowler
    Arlon Fowler Mar 27, 2014
    I took a sample of the sludge and boiled the water out of it. It turned out to be motor oil. Why don't I have water in the crank case?
  • downhille Mar 27, 2014
    Perhaps it is because the oil pressure is greater than the water pressure. If you have the service manual, look to see where in the head or block the oil passages are near the water passages, and especially where there might be a gasket between them. I believe you will find a head gasket blown, or perhaps a blown gasket elsewhere.... or worse, a cracked block. I'd consult the manual, get your best idea of what could cause this, then proceed. I believe at the very least you will need to pull the head, but look (at the manual) for other possibilities. Again, I am not familiar with this machine, but I hope I can give you some ideas of where to start looking. May God bless you on your search, and in your life.
  • T Davis
    T Davis Apr 15, 2014
    This unit has a 4D32 engine - it has an oil cooler on the side of the engine. normally when you get oil in the water and not in the block/pan, this is the probelm. Check that...
What would cause the hydraulic cooling fans fluid to leak out when i drive the car and my car overheats and how can i fix it with hardly any money to my name?
the problem is most probably a failed oil cooler in the radiator tank
this allows oil into the cooling system that causes the engine to over heat
you can buy quality radiator/ block cleaner and flush the system yourself but the fix is to replace the radiator tank with the oil cooler inside
blocking off the lines will only cause transmission over heating
the only cheap option is a good radiator from a wreckers as replacing the tank can be almost as expensive as a new radiator
ring around and get prices that are close to what you can afford and make a decision from there
Apr 25, 2016 | Cars & Trucks
I have a jeep liberty 2002 changed radiator heater core back flushed at jeep dealer heater works for a while really hot and sometime itj just starts blowing cold air suggestion jeep dealer said sceen keep...
What does your radiator fill tank look like? When is the last time you changed radiator fluid? If you have an oil leak into the radiator, combination produces a jelly like substance that may be what blocks the screen. You may need a radiator flush and refill.
Feb 13, 2015 | Jeep Cars & Trucks
Why my Excavator Hyundai-210 Over Heating.
Step 1. Check radiator water level
2. Check fan belt tension
3. Use compressed air and blow through BOTH engine radiator and hydraulic radiators in the REVERSE direction of normal air flow.
4.Flush out engine radiator with radiator flushing additive.
5. Ensure that all rubber foam around radiators is gap proof, this keeps maximises air flow through radiator fins and stops hot air from engine from recirculating back in to radiators.
Hope this helps
Sep 20, 2013 | Dorman 740-210 Hyundai Elantra Front...
Cat E70B excavator
Evacuate the hydraulic tank and clean with kerosene.Get as much fluid out of the machine as possible. Replace Filters and if it builds back up with metal SELL SELL SELL it or your in for some big money repairs.
May 05, 2013 | Caterpillar E70B Excavator
My 99 lexus gs400 is leaking a brown fluid. Not sure from where as It has had a transmission flush and radiator replaced. It also makes a weird rattling noise when started in the morning.
re rattle on start up,turn engine off then start again,repeat again if rattle continues.if oil change needed do it as my hydraulic lifters rattle in low temp or when oil old
Jan 31, 2013 | Cars & Trucks
Leaking hydraulic oil around the turntable
The seal units at the turn table are worn or there are grooves worn around the sealing ring.. It is common for this area that is subject to such movement in the worst possible conditions of dust and other contaminents
Jan 16, 2013 | Caterpillar E70B Excavator
I need to flush my radiator. The check engine coolant keeps coming on and it seems to have a slow leak in the system.
First I would check the oil to make sure that the water is not leaking in through the head gasket. If the oil is ok, then you can go to any autoparts store and get some radiator stop leak. This will fix small holes. Flushing the radiator will probably not do any good.
Nov 05, 2010 | Chevrolet Venture Cars & Trucks
Oil in my coolant system
it is likely the head gasket. it's seeping oil into the cooling system.
Jul 18, 2010 | 1995 Plymouth Neon
Log splitter how to flush hydraulic system
removing hydraulic oil from the system
  • fully extend the cylinder. and shutdown.
  • remove the one end of the hose that is from the rod end of the clylinder.
  • two ways you can go here. either: detach the one end of the hose that is attached to directional control valve and leads to the cap end of the cylinder and place the end in a pale then retract the cylinder by physically forcing the rod back in and all the oil will drain out of the cap end into the pale and the rod end will fill with air.
  • or u could hold the directional valve in the position to let the oil flow back to tank while physically forcing the rod back in. the oil in the cap end will drain to tank and rod end will fill with air.
  • drain the tank of oil.
  • if you wanted to be extra thurough remove the remaining lines and drain the oil out of them.
  • reattach all lines.
  • replace oil filters/strainers. should be one on the return line going to tank. and one on the suction line before the pump. But there may not be a second filter.
  • fill tank with new oil.
  • extend the cylinder using the pump. allowing the air to bleed off the rod side. may chatter at bit while extending. if excessive chatter remove line end to allow the air in the rod side to bleed to atmosphere and continue till fully extended.
  • reattach line. probably a good idea to run a couple cycles.
  • and repeat the entire process for a thurogh flushing.
  • ! note: dont be dissconnecting lines with pressure in them or while the system is running.
  • ! note: be sure to have enough oil in the tank so the pump is not sucking air. this will eventually cause unrepairable damage to pump if sucking air for too long.
  • i just wrote this off the top of my head and ive only worked on industrial hyraulic systems and never on a log splitter before so just keep that in mind. hope it helps
Dec 04, 2009 | Plumbing
How do i flush my radiator myself?
If it works leave well alone ,just keep it topped up with pure antifreeze and not the diluted stuff
Oct 23, 2009 | 1991 Chevrolet Caprice
Caterpillar E70B Excavator Logo
588 people viewed this question
Top Caterpillar Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Caterpillar Garden Expert? Answer questions, earn points and help others
