Question about Brother MFC-9120CN Fax machine
Send fax via my laptop
Can i fax using my laptop in windows 8
  • 400 Answers
You should be able to, as you can with Windows 7. Just type "windows fax" in a Google search and it will give you directions. OR you can go to Windows help, for the same information. I hope this helps.
Posted on Mar 25, 2014
Is there a way to hook up my hp lazer jet pro m1212 nf mfp to be able to send a fax utiling my laptop which is by wifi. In other words no land line available.
Without a dial-up line available for your fax machine, the only other way to fax is via the internet if it's supported by your MFP. Google online faxing or fax via internet for solutions you may be able to use in your situation.
HISTORY
Fax or facsimile was invented as a way to take a printed document, scan it into digital form and transmit it to it's destination in a matter of seconds -vs- sending it via an expensive courier taking hours or days. This is before the internet, Adobe and other players made a way to create and send documents via the internet without the need for a fax machine and dedicated phone line. While faxes may still be sent that way when the printed document is the only media available, faxing has died off considerably. Most large companies now have ways implemented to move documents digitally without the need to fax. I predict the fax portion of a MFP to disappear in the not too distant future. Earlier MFP's didn't include a fax feature and one had to but the next model up to get it, now it's included in nearly every MFP. Adobe's PDF format with the ability to fill in the forms fields electronically (as in your US taxes) without having to have expensive office software made printing and faxing a thing of the past. Don't be surprised if the business or other entity requests you, and all of us, to submit a PDF document to their business email address rather than a fax.
Good luck with your quest!
Oct 15, 2013 | HP LaserJet Pro M1212nf MFP -...
Tip
How to Send a Fax with Microsoft Windows 7 Note for you to use the built in...
Note for you to use the built in "Windows Fax and Scan" option to send faxes you will need to have a dial-up modem installed in your computer.
1. To access the software click the "Start" button and in the "Search Programs and Files" box type "Windows Fax and Scan".
2. Next click on "Windows Fax and Scan".
***Note Will Finish The Setup Process When I Get To My Computer With A Modem In It***
on Jul 28, 2010 | Computers & Internet
Tip
How to Configure Windows XP to send and receive Fax?
If you are using windows XP, you can use sending and receiving option for fax service built into windows XP. You can enjoy free facilities of fax from your computer, because buying a dedicated fax machine for home or small office may not be a feasible option. Using windows XP based fax services; you can read, save, forward, delete the fax messages. By default fax service is not installed in your windows XP, but if you have windows XP CD, you can install fax feature using Add or Remove Program option.
Follow the gives steps to install fax components:
  • To install this feature, you will need to be logged into your computer with administrative rights.
  • Make sure, you have installed modem driver on your computer before running fax components setup.
  • Now click on Start button and go to System Control Panel then double click on Add or Remove Program.
  • Select the Fax services check box under Add or Remove Windows components.
  • Now click Next to finish the fax installation wizard and close it.
After the fax components installed, now configure the fax setting before using it.
  • First click on Start button, go to All Programs> Accessories> Communications then click on Fax Console.
  • Now in fax configuration wizard, type the fax cover page information then click on Next.
  • Select the suitable modem for fax and also enable others send and receive options.
  • Now type the TSID (Transmitting Subscriber Identification) and click Next then type here CSID (Called Subscriber Identification) and again Next.
  • At the end select the printer to be automatically printing the fax and click to finish.
on Feb 13, 2010 | Computers & Internet
Can't install Lexmark Pro901 in Windows 8
Please check this article on how to install your Lexmark printer to a Windows 8 OS: http://bit.ly/WjeXIy
Jan 06, 2013 | Lexmark Pinnacle Pro901 Multifunction...
There is no multi function suite in windows 8
I don't have proper idea..but you can try these steps:
1. Click the Start button Picture of the Start button, click All Programs, and then click Windows Fax and Scan.
2. On the toolbar, click New Fax. If it's the first time you're sending a fax, you'll be prompted to complete the Fax Setup wizard.
3.When you're finished creating your fax, click Send.
If need any help on windows 8(fix windows 8 solution) then you can get technical help from here:http://www.vtechsquad.com/
Nov 15, 2012 | Brother MFC-6890CDW Printer
How do I hook up an HP v40 to my PC and a cable modem so that my FAX works?
You probably need to hook up to a landline telephone line, too. Or, you can use an "e-fax" service that lets you send faxes via internet. Basically, they would send your fax as middleman to the recipient. Windows Vista except Business version) does not have inherent fax support like Windows XP and Windows 7 Professional. And programs such as WinFax did not upgrade to Vista and 7. But, your fax modem should have come with some faxing software.
You put in modem card and then run telephone line to back. You can usually run a line to a telephone from the 2nd connection on the back with the telephone symbol below it.
Hope this helps you a litle.
Nov 20, 2010 | Computers & Internet
How to print to fax using the canon imagerunner 2020i
On the installation cd's of the machine there is a fax driver if you install the fax driver the fax is showing as a fax in the printers and faxes in the controll panel.If you print to the fax a window will open where you tipe the name and number you want to send the fax to.There is also a option if you want to add it to the addresbook.After editing the info add it to the receipient list and send.Your document will faxed from your computer via the IR machine,if your machine is connected to a fax line.
You can edit the address book easy by logging to your machine via your broser tipe the ip address of the machine in your browser and press go.If the machine is connected via local LAN.
Nov 16, 2009 | Canon Office Equipment & Supplies
How can send fax thru internet
You can not send faxes thru the internet unless you use a service such as E-Fax.
Faxes usually are sent via phone lines only.
If you are asking anything else then you have to be more precise in your question as it is not exactly clear as to what you are asking!
Good Luck!
Rich Lilja
Dec 04, 2008 | HP LaserJet 3055 All-In-One Printer
Broadcast Fax Sending
Change the resolution to STANDARD. This will cut your send times by 50%
Sep 06, 2008 | Symantec Winfax Pro 10.03 (winfax10.03)...
Document to memory before sending
Here's the manual. Look at page 6-8. That tells how to turn on real-time transmission. You just need to do the same thing, except switch it to off when you get to that step. http://www.brother.ca/en/products/pdf/manuals/MFC8220-UG.pdf
Sep 06, 2007 | Brother MFC-8220 Fax
Brother MFC-9120CN Fax machine Logo
18 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
