Question about Cycling
I have a Schwinn 202 Biodyne Performance System that will not power up. Any suggestions?
Will not power up
My Schwinn Biodyne 150 doesn't pedal smoothly. It is normal, then too hard, then normal. No problem or error message on the console.
Take a look at the crank to see if the threads are showing on either retainer cap. Having the left-hand one back out and start causing problems is a common issue with these bikes. If it's coming out, use a large water pump pliers, or a screwdriver and hammer, to turn or tap it back clockwise.
Mar 02, 2015 | Schwinn Cycling
How do you remove pedal arms on schwhinn biodyne 220 so the shroud can be removed?
There should be a circular insert at the shroud that the crank arms for the pedals go through. It took me a little careful work to pop the inserts out of the shroud. This leaves a just enough space to carefully squeeze the shroud over the pedals allowing access to the interior. Its a tight fit and may require tackling it from different angles to get the shroud off. It can be done, but be careful not to apply too much pressure resulting the cracking off the shroud.
May 26, 2014 | Schwinn 220 Recumbent Exercise Bike - 2012...
LOST OPERATING MANUAL FOR SCHWINN 202 BIO DYNE
Try this http://adf.ly/3pDUa
Nov 22, 2011 | Cycling
Cannot adjust the tension on Schwinn 202. Computer is on but tension will not move up or down
I have the same problem with a schwinn 202 that someone gave to me because the resistance adjustment no longer worked. They were advised by Schwinn that the motor needed replacement, but after testing mine, the problem seems to be a lack of power from the computer to the motor. Schwinn tech support will get a call from me tomorrow.
Nov 21, 2010 | Schwinn Cycling
Schwinn recumbent bike 203 Ac adapter or batteries?
It uses an AC adapter. You can visit:
fitnessrepairparts.com
This is where I am getting the AC parts for my 201.
Mar 21, 2009 | Cycling
Cycling Logo
69 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
