Question about Fisher and Paykel Washing Machines
Washing machine, not doing spin cycle
Machine washes and not spin drying, turns a little bit and arlam goes off and lid light comes on not locking
Oceti
  • 51 Answers
SOURCE: Will not drain or spin
Unless you jarred the machine it's the timer. You can check this by bypassing the lid switch and seeing if it will cycle.
Posted on Dec 13, 2007
  • 22 Answers
SOURCE: washing machine will not spin or drain
look at my post "eco smart won't drain, smells hot". It could be something stuck in very lowest part fo drainage area. you have to remove the motor on bottom of washer to see into this area and remove blockage.
Posted on Oct 21, 2008
  • 151 Answers
SOURCE: GE Prodigy Washing machine making clunking noise
One common problem area is the clutch assembly. The clutch is built on top of the motor, the motor drives the clutch and the clutch assembly drives the rest of the washer. The clutch gets very noisy when parts inside are worn out. The shoes lining that drives the inner drum of the clutch wear off and you will get a metal on metal sound. Clutches often can be rebuilt, but sometimes they are too worn and replacing the whole clutch is the best repair. Please use this link here for clutch replace and repair info. The belt and pump may be the next items to check for noises. How to access the washer. Clutch repair help.
Posted on May 03, 2009
BIKER T
  • 909 Answers
SOURCE: spin cycle is off balance washing machine is
i dont believe it is the agitator per say. Assuming this problem has just started and doesnt have transportation bolts still attatched. Two conditions cause the imballance. 1)(if unit is a top loader) Check if all 4 shock absorber springs are well lubricated and not sticking. 2)A more involved problem which often happens, Underneath the washer, is the drive motor. on the motor, is a round pulley. this pulley needs to come off and strip further until you see a long spring. If it is not broken, clean it up using a solvent and a rag. reassemble and test. (if spring is defective, it will slip instead of grip on a spin cycle.
Posted on Sep 17, 2009
SOURCE: frigidaire washing machine no spin cycle
I had the same problem with my Frigidaire Affinity front load washer. It would go through the wash cycle but would not do the final spin cycle that takes the access water out of the clothes. It would actually cut off when it got to be 6 minutes left. I checked the hoses, belt, motor and pump but all were functioning properly. I even cleaned out the filter thats located in front of the water pump. It was full of coins and other debris but it still didnt fix the problem. I called the repairman and he concluded that the control board was bad and would have to be relaced. The board is $200 and labor $140. It will cost you $340 dollars to correct this problem unless you know how to replace the control board yourself. Only had the washer for 3 years. I wouldnt expect something like that to occur within that short period of time.
Posted on Sep 22, 2009
Why does the lid lock light start flashing after the wash cycle and will not rinse or spin?
Lift lid, stick screwdriver into slot where lid latch-pin inserts and see if it goes into the cycle. If so, try adjusting position of latch.
Sep 01, 2014 | Washing Machines
I have a frigidaire washing machine and it spins out just a small amout of water during the cycle, not a lot , have checked the pump and it works, just wondering if it could possibly be the lid lock
It would not agitate if it were the lid lock, just as agitation should stop when you open the lid during cycles. More likely it's something blocking the drain hose. Here is a link to an excellent online repair manual. Click on the picture of the wash machine, then go to chapter 2. Then have a look at Section 2-3.
http://appliancerepair.net/washing-machine-repair-2.html
Sep 13, 2012 | Frigidaire Washing Machines
Maytag Washer Lid lock light
Its normal for the machine to cycle the lock before starting its cycle. I'm assuming your machine is a bravos style.
May 30, 2012 | Maytag Washing Machines
I have a whirlpool washing machine, M 31062, WTW4950XW0. I am attempting to use it for the first time and the Sensing Light is coming on when I press START. The Lid locks and there is a noise like the...
I have a Whirlpool model WTW4950XW0. Once i push the start button.
The lid locks, sensing lite on, machine goes through its cycle, than lid unlocks
monents later.What wrong. I was doing laundry and notice the machine making some noise on the spin cycle. I push the pause button and remove some clothes.
thats when the sensing lite keeps blinking.
thanks
Rich
Jan 01, 2011 | Whirlpool Washing Machines
When i put the wash cycle on it goes and does fill up with water, but then when comes to spin cycle it stops agitating and starts beeping constantly with the light on where the "lid locked" icon is.. When...
Hi Ellie,Just read your posting.Now does your machine drain most of the water from the machine but it does not spin the clothes dry?Is this correct?Also does the mahine only show the lid lock icon when the machine is beeping?Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
Aug 17, 2010 | Fisher and Paykel GWL11 Top Load Washer
The washing machine doesn't open if I use detergent
read the side of the detergent box it normally says how much, and your washer is probably not opening because it has lid lock to open it you need to pause the cycle and wait a few minutes and it will release the lock also if the washeer is spinning or agitating the lid will automatically lock to open do as described above
Feb 19, 2010 | Asko Washing Machines
Our washing machine was stopping at various stages & would beep and just not continue with the cycle. (Sometimes it would fun a full cycle without a problem however). We took it to an official...
The drum suspension rods may be worn or one of them may be brocken, throwing the drum out of balance.
They are fairly easy to change if you know how to open the top hatch. Check and remove them individually.
Let me know if you need assistance or more info.
Ash
Oct 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing machine door locked indesit WD12X
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Apr 01, 2009 | Washing Machines
Dec 13, 2007 | Washing Machines
Fisher paykal top load washing machine
I had the same problem. I unplugged the machine for a while (overnight) and it then worked properly when I plugged it back in. Probably just a circuit board issue that was cleared with the power removed.
Sep 02, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
12 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
