Question about Ricoh Aficio AP3800C Laser Printer
Ricoh AP3800C sc389 error code
Errors out every time it is turned on any help?
    New Friend:
  • 97 Answers
SC389 is a development gamma error in the magenta. There can be several causes for this error - a toner supply problem, incorrect toner used, a laser exposure problem etc. This is not likely to be an easy problem to fix unless you are experienced in such matters, so you may need to look for someone who can help out.
Posted on Mar 28, 2014
jaylex
  • 417 Answers
SOURCE: cause for error code sc560 on ricoh ap3850c
H there below is what is stated in the service manual and I suggest to change the power cord before the main PSU (Power Supply Unit)
SC 560 Zero Cross Error
When the power switch is turned on. The machine checks how many Zero-cross signals are generated during 500 ms. If the number of Zero-cross signals is more than 66 or less than 45 and the condition is detected more than 10 times this code is shown.
Cause is electrical noise in the supply from the power cord.
Solution
  • Change to another power wall socket
  • Change power cord
  • Replace main PSU (Power Supply Unit)
I hope this help you
Thanks J
Posted on Jan 13, 2008
SOURCE: Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
Posted on Jun 23, 2008
Bubbabear64
  • 2794 Answers
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
SOURCE: ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Posted on Feb 24, 2009
CANON IR4570 e000805-0000 AND e000110-001
on ir5570 error ,,E000110-001,,is polygon motor
Apr 05, 2010 | Canon ImageRunner 4570 | IR4570 |
Error 163 173 ibm 600e laptop when turned on these errors occur
this error is the battery by the sound of things, you need to replace the cmos battery , then enter the configuation utlity and set date and time, hope this helps
Nov 29, 2009 | IBM ThinkPad 600E 2645 Notebook
Turn signals turn on windshield wipers
If your turn signal is multifunctioning (dimmer switch, cruise control, wipers, etc.) then it's probably a faulty switch. Takes about 20 minutes to replace and costs around $60.
Jun 08, 2009 | 2008 Dodge Caliber
System error 0000D8 005D0273
Unfortunately, your error is a firmware error. Try unplugging from the wall if you can't do a normal power down. Unplug the network cable and then try plugging in and re-poer up the plotter. If the error comes back, your looking at replacing the firmware dimm. HP part number C6074-69350 on exchange or C6074-60350 new outright purchase without turn-in. Part should be available through http://partsurfer.hp.com. Below is a link for a free PDF of the HP Service Manual on your machine. When you look up your error it will refer you over to the firmware error. Go to the index at the end first as it's easier to locate the section for the error from the index.
http://www.feedroller.com/Store/Service%20Manual/DESIGNJET%201050C,%201055CM%20Large%20Format%20Service%20Manual.pdf
Hope that helps you.
Jul 16, 2008 | HP DesignJet 1050c plus InkJet Printer
Error
I do not think you fixed the CMOS battery - (backup battery = CMOS battery) According to the error codes, you have a dead backup battery and the time is not set. Makes sense? 161
(Dead battery.) 1. Go to Checking the Backup Battery
2. Backup battery.
3. System board.
163
(Time and date were not set.) 1. Set time and date.
2. System board.
hope this will help.
Jun 06, 2008 | IBM ThinkPad 380ED
Error
turn off your printer press PRINT & ESC at the same time, prees on/off at same time then release the PRINT & ESC botton then press SET
Apr 27, 2008 | Casio KL60SR Label Printer
Error code 6000
Hi there, every time I turn on my printer, it keeps saying error 6B00
Any halp for me Canon PM810
Apr 14, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Error code 6502 on MP510
why error 6502..........?????
Help me pls.........!!!!!!!!!!!
Feb 26, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Error #45
Error message appears on EVF/LCD screen
  • Turn the camera off, then on again.
  • Remove memory card from the camera.
  • Remove the battery and wipe the contacts with a clean, dry cloth ( Battery life).
  • Insert a new or charged battery ( Loading the batteries).
  • If all else fails, get customer support help
Jan 04, 2008 | Kodak EasyShare Z740 Digital Camera
Ricoh Aficio AP3800C Laser Printer Logo
193 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
