Question about Microsoft Xbox 360 Console
How do i reconnect the xclaps in my 360 ? - Microsoft Xbox 360 Console
  • 32 Answers
Put in the opposite sides first. Usually 3 sides go in easily and you need to force in the other side. I did it by bending them out with a flat head screwdriver. Eventually I just replaced them for screws. I suggest that.
Posted on Jun 15, 2009
My xbox 360 is now showing flashing 1 red light on and off
These steps are taken from the support site as always, it's the first website where you should look.
Solution 1: Disconnect and reconnect cables
Here's how:
  1. Turn off your Xbox 360 console.
  2. Unplug all memory units, controllers, and accessories from your console.
  3. Unplug everything from the back of your console, including power and video cables.
    Don't remove the hard drive.
  1. Reconnect your console's power supply.
  2. Reconnect each accessory one at a time, starting with a controller.
  3. After you've reconnected every accessory, turn the console on.
Solution 2: Remove the hard drive
To see whether the problem involves the original Xbox 360 Hard Drive, temporarily remove the hard disk drive. Here's how.
Note Not all Xbox 360 consoles include a hard drive. If your Xbox 360 console doesn't have a hard drive, to go Solution 3.
  1. Turn off the console.
  2. Locate the hard drive on the top of the console (or on the left side, depending on how the console is oriented).
  • Press the release button on the hard drive.
  • Lift the hard drive away from the console.
hdseparating.jpg If these steps resolve the issue, reattach the hard drive to verify that the error occurs only when your Xbox 360 Hard Drive is connected.
Solution 3: Disconnect memory units or USB flash drives
Here's how:
  2. Unplug any memory units or USB flash drives attached to your console.
  3. Turn on the console.
If these steps resolve the problem, reattach the memory unit or USB flash drive to make sure the error occurs only when it's connected. If this is true, order a replacement memory unit or use another USB flash drive.
Solution 4: Request a repair
If the previous steps don't resolve the single flashing red light issue, there are no additional troubleshooting steps. Your original Xbox 360 console must be repaired at our service center. Start the repair process online.
Jan 09, 2015 | Microsoft Xbox 360 Console
Got new Xbox 360 yesterday. Can't get sound.
Check the HDMI/Scart cable, disconnect and reconnect both at Xbox and TV.
Jan 09, 2013 | Buck Legendary: The Box for Xbox 360
Xbox live connection keeps dropping
It can either be your internet connection, your adapter cable, or your router. I have had lots of problems with my internets router and I have Linksys so if you have that same type it might just be the routers connection. Did you try hooking up your 360 straight to your internets modem? My fiance does this with his 360 because he has had problems with the router and the connection. Maybe try to disconnect your router it and let it sit for a couple of minutes and then reconnect it and let it reset before you reconnect it to your 360. Also you may want to call some type of support either for your internet or your router. They may be able to help in some way. It seems like everyone I know has gone through at least one 360 system. We had to just replace ours also after having it for under a year. The only system that I haven't heard complaints about is the 360 elite but the price is too much for us to get one. Anyway good luck and hope I helped a little bit.
Nov 25, 2010 | Computers & Internet
Broken wire to yellow cymbal
I would recommend stripping both ends of the wire to expose the wire, add another piece of wire in between the broken wire, to lengthen the wire overall, then simply reconnect all the wires together. After the wires are reconnected then, add some electrical tape around the parts where the wire is exposed. If there is not enough wire to patch it up, then sorry to say but, you will need to buy some replacement cymbals. It will $13.99 with free shipping on ebay, just seach "replacement cymbals xbox 360", it will come right up.
Feb 01, 2010 | Buck Guitar Hero World Tour for for Xbox...
Xbox 360 won't turn on
I had this problem. Make sure the pins in the USB ports (2 on the front and 1 on the back of the console) aren't bent and there's nothing obstructing them. I unbent some of the metal inside these ports, and voila! I have a working xbox.
Oct 09, 2009 | Microsoft Xbox 360 Console
Xbox 360 flashing red
I had a similar problem with my xbox 360. Reconnect all cords that are in the back of the xbox. If that doesn't work the best thing to do is call microsoft.
Aug 22, 2009 | Microsoft Xbox 360 Elite Console
Sysem error E73 on Xbox 360
Follow the steps below, Hope this helps
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Remove the hard drive, turn on your xbox 360 without the hard drive.
3. Re attach the hard drive and turn on your xbox 360
4. If the steps wont resolve the issue, your console needs to be serviced. Contact Xbox Customer Support to check the warranty status of your xbox 360.. Good Luck!
Mar 31, 2009 | Microsoft Xbox 360 Console
Will not reconize guitar or drums
make sure u press the reconnect button onur 360 and controllers.
Mar 21, 2009 | Buck Guitar Hero World Tour for for Xbox...
Microsoft Xbox 360 Console Logo
61 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
