Question about Bernina Sewing Machines
Bobbin case won't release
Bernina B750 will not release the bobbin case. Have followed instructions in the manual.
  • 39 Answers
Http://www.bernina.com/en-US/Support-5/Machines-en/BERNINA-750-QE-us
this should give you some help Im not familiar with this machine but I think it may be a sensor problem
Posted on Mar 28, 2014
SOURCE: Bobbin won't wind
I have checked the gears underneath and see no missing teeth for the bobbin part. The bobbin "seat" does raise, but does not engage. Thanks
Posted on Dec 23, 2007
  • 1894 Answers
SOURCE: replacing the bobbin case
1) Use a strong polyester type thread, NOT FINE COTTON
2) Use a low tension,nuber 2 for exanple
3) Always check the threading, if in doubt rethread all the way
from the top bottom making sure you pass roun and not
through thr fixed holder spring.
4) Make sure the thread moves freely with the tension disc held
to the right while pulling the thread through the needle
5) Be very careful that the thread is pulled up from the lower
bobbin correctly and check there is no muddle or stray
thread under the cover
6 Dont pull on the fabric (not thick for beginning) - just guide it
Posted on Feb 05, 2008
  • 5 Answers
SOURCE: using a bernina gold latch bobbin case on the Bernina 435 machine
There isn't a Bernina 435. If you are referring to the 430 than the gold latch bobbin case will not work in that machine. If you are talking about the Bernina 450 the gold latch will work in that machine, with or without the embroidery module.
Posted on Aug 15, 2009
SOURCE: I have a Bernina Virtuosa 155 and use it daily. Without
In checking I can either adjust the tenion screw and if that does not work, purchase a new bobbin case.
Posted on Oct 28, 2009
  • 108 Answers
SOURCE: JcPenney 7064 , bobbin case, bobbin and manual ??
i was able to find it at www.ifixmachines.com
Posted on Feb 15, 2010
I have a Bernina 770QE. The bobbin (black) is stuck in the bobbin casing (chrome). How do I get it to release?
Take the bobbin assembly loose and turn your hand crank and move it until the hook is at the top. Pull assembly apart and clean the assembly with qtip and sewing machine oil. It will likely be dirty that is causing parts to stick. If the bobbin spring feels weak it may be a good idea to replace it.
Aug 06, 2017 | Bernina Sewing Machines
Instruction Manual for Bernina 801 - need instructions for oiling the Bernina 801
Hi Jim&Bev, The link below in a 23 page user manual for a Bernina 801 Sewing Machine, I hope this helps.......CHEERS..
Bernina 801 Owner Manual
Apr 16, 2016 | Bernina Sewing Machines
Bobbin case won't close. Stop start button is red. Oil can? Icon on screen
Consult your owner's manual. If you don't have one, go to www.Bernina.com and look in the Support section for a manual to download.
If the bobbin is not installed properly, the machine will not work. The oil can logo indicates that you should oil the machine according to the manual's instructions. Use Bernina oil for computerized sewing machines. Only one or two drops of oil in the locations(s) per the instructions.
Oct 16, 2015 | Bernina Sewing Machines
Loose top thread bernina 1008, tension problem but no solutions yet...
Are you sure you are getting the top thread between the tension discs? You should be able to tell the difference when you lower the pressed foot.
Jan 27, 2013 | Bernina 1008
My mother has a bernina 1008 and now that we have taken the bobbin casing out to clean it won't catch when threaded. Any ideas?
Are you threading the bobbin case correctly - the bobbin should rotate clockwise when pulling the thread out under the tension spring. Are you ensuring that the bobbin case is firmly clicked back into position when replacing it. Check your needle is OK. Did you remove the hook from the hook race when cleaning out - have you oiled the hook race ?
Jan 22, 2012 | Bernina Sewing Machines
I have a Bernina Activa 230 and my bobbin case is stuck in the machine and it wont come out, Someone Please help me what do I do?
can you unlatch the ring cover device? there is a little release lever on the left just inside the bobbin area which secures a hinged silver square called hook race cover, if you unlatch this, flop the cover forward, then the bobbin case and shuttle should all come out as well.
Nov 02, 2011 | Bernina Activa 130
B/A 180 engine groans and then stops...push pedal and may start stitching again...Sometimes have to turn hand wheel. ????
Refer to your owner's manual to better assist you in following these instructions.Remove the bobbin case. Release the hook cover by pushing the lever which is located at the top left side of where the bobbin case is inserted. After the cover pops open, remove the hook. Observe if the machine now moves freely. Clean the hook and the hook area with a toothbrush, removing all lint and debris. Place one small drop of sewing machine oil on the rim of the hook. Replace the hook into the raceway and close the cover. Replace the bobbin case and test sew.
Jun 02, 2011 | Bernina Artista 180
HOW DO YOU THREAD A BERNINA MACHINE
http://www.singerco.com/resources/
Choose basic operations and bobbin winding then threading.
Although, this is Singer and not Bernina, the process is the same and the instructions/graphics are easy to follow.
Mar 02, 2010 | Bernina Sewing Machines
Bernina 930 feed dogs won't come back up
Make sure you are oiling your machine every 8-10 hours of constant sewing or every six months if it's not in use. Use Bernina oil for CB hook and follow the instructions in your manual making sure you oil in the bobbin area.
Dec 19, 2009 | Bernina Sewing Machines
I have a Bernina 530 Record and i'm trying to but
You would be best to download an instruction manual for your machine as it explains clearly, with diagrams how to thread and insert the bobbin. You probably wont find the 530 manual however download a copy for Bernina 530-2 or 532-2 as they are almost identical to the 530.
Sep 25, 2009 | Bernina Sewing Machines
Sewing Machines Logo
165 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
