Question about PANDIGITAL 7-Inch Digital Photo Frame with 2 Interchangeable Frames (DPF701) Digital Picture Frame
Screen shows light with crack, cannot turn off
Light up screen with black line across, will not turn off,talked with tech support- need to send tablet in. told that I need to file claim on line and get email for instructions. tablet will not power off
  • 1,511 Answers
Internal defect needs factory service. Module inside needs replacing and you cannot do that.
Posted on Mar 25, 2014
The Top screen has a big black circle on it.
The top screen will need to be replaced. Your only options are to either to send it off for repair or to fix it yourself.
If you intend on fixing it yourself I have a couple of guides to help you...
DS lite dismantling guide.
DS lite top screen replacement.
Hope this helps, any problems or further questions please feel free to contact me via my profile page.
Regards,
SOD69
Feb 28, 2010 | Nintendo DS Lite Console
Hp pavilion turns on but i have a black screen. can't get on internet to download anything to help can you help?
The HP model you are talking about has graphic card issues. Usually when you see a black screen when the laptop turns on, it indicates a graphic issue.
If you search in the HP forums about black screens on start up it shows a bad graphic card.
If the laptop is still under warranty contact their support techs online with a different computer and let them know whats going on and they should have you send it to them for a replacement card.
Jul 08, 2009 | HP Pavilion dv6000z Notebook
Iphone screen beoken, black liquid showing; phone stops working
hello basicly the the liquid is the lcd that lays between the screen that gives you the display if this fluid escapes it will no longer display properly and as it leaks more display will be lost ,to solve you will need to replace the screen
Jan 18, 2009 | Apple iPhone Smartphone
Black screen on Acer 5100, but will work with external monitor
It sounds like the control board or cable for the LCD may be damaged. If you're still under warranty, you'll need to send it back to Acer to be repaired.
Feb 13, 2008 | Acer Aspire 5100 Notebook
Green lines
This is the convergence amps going bad. You would need some tech experience. But could do it if talked throu.
Sep 11, 2007 | Philips Magnavox 51MP392H Rear Projection...
JVC model AV 278p6 standard television
I'll bet you have vertical output IC with some pins not soldered. This IC ( integrated circuit) is a "chip" that makes the picture fill out from top to bottom. After a period of time heat will cause the pins to crack loose on the circuit board. You need to have a tech check it for you. Stargazer
Aug 16, 2007 | JVC AV-27530 27" TV
Ghostly vertical lines
you have done said it vertical lines then you will have to take your tv to a tech for repairs.good luck.
May 13, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Picture problem
Usually that symptom is caused by cracked solder joints on the vertical output IC. As the IC starts heating up, the picture starts breaking up at the top with several "dancing" dark lines appearing, the top scrunches down and then when the vertical quits altogether, the screen goes completely black. A good slap on the side of the TV might make it happen faster or clear it up temporarily. If you have experience working on PC boards then you can resolder the pins of the vertical output IC but if you have never soldered parts on PC boards then allow a qualified tech to handle it for you.
Nov 20, 2006 | Sony KV-35S42 35" TV
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
PANDIGITAL 7-Inch Digital Photo Frame with 2 Interchangeable Frames (DPF701) Digital Picture Frame Logo
Top PANDIGITAL Photography Experts
Gareth Cockram
Gareth Cockram
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
