Question about Hunter Televison & Video
Remote control manual
Lights and fan don't work. no communication between remote and fan
  • 1,511 Answers
Either the batteries on the remote are backwards or need replacing; Or the Contacts on the fan are disconnected or damaged.
Posted on Mar 25, 2014
CEILING FAN WORKS,BUT REMOTE ONLY WORKS THE FAN SECTION, WILL NOT DIM LIGHTS NOR TURN OFF LIGHTS ONLY SO WE CAN USE FAN ONLY. WHAT DO WE HAVE TO DO?
Fist, make sure the bulbs are good. Check in another fixture to verify that they indeed work. Since the remote works the fan, dead batteries can be ruled out. The problem will be confined to either a bad receiver in the fixture, or a bad remote.
Since Hampton Bay is a line carried by Home Depot, you may have some luck bringing your remote to HD and trying it out on the display units. You may need to try different address settings on the remote to find one that works if you don't get results the first time. This is usually several two position switches often called "DIP Switches". Change the positions of them one at a time until you find one that works. Try to control a fan first. Once you find a fan the reacts to the commands from the remote, try to control the light. If the light doesn't work - the remote has a bad transmitter or light switch control. You could attempt to disassemble the switch, but most don't have parts that look different when they're bad. You'll probably have to replace the remote.
If the lights work, then the problem is with your fixture. You can remove or simply bypass the radio controller in the fixture and install an after market receiver and remote to control it again. These are sold at Home Depot and work with any paddle fan.
I hope this helps & good luck!
Oct 26, 2011 | Hampton Bay 48670 Flemish Pewter Finish...
Ceiling fan with remote control stopped working suddenly, ruled out battery for remote control, because I changed a new one, ruled out circuit since everything is working, I don't have a pull on the...
with Hampton Fans,, normally if the remote is good with a known good battery , and it quits working,, its the remote receiver, not the actual remote that goes bad. you can contact these guys I heard they have the part you need http://www.ceiling-fans-n-more.com/hampton-bay-ceiling-fan-parts.php
Sep 07, 2011 | Hampton Bay 24750 Huntington III Ceiling...
Don't have remote control how can you get it to
Don't know that fan even thou I sale Fanimation! If it came with a remote & has no pull chains then you can only use the remote feature. You can order a new transmitter, that you would have to match the dip switches in the receiver to. I would need to have model# of fan. www.fanfairceilingfans.com fanman9952@aol.com
Aug 19, 2011 | Fanimation Pedestal in White with Standard...
The remote control will no longer turn off the lights on the fan but will still turn the fan blades on and off. What do you suggest? Would getting a new remote control solve the problem? If so, how do I...
You remote is working fine but for the control on the light switch. If teh fan is switched on and off then the communication is good enough and the remote and the main unit is communicating. Hence remove the remote control and clean the pads of the light button. Dry up if possible and if there is a carbon track, the you can use a carbon pen to make up the lost track, or if the pad has lost the carbon pad then stick one conductive pad so that the circuit is activated. I hope you try this out. Good day
Aug 16, 2010 | Hampton Bay 24002 Ceiling Fan
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
Hunter 52, fan works but light no longer works with remote or chain pull
mcdevito75 here, Don"t the fan lights work off the wall switch, The chain pull should be for fan speed. Check make sure electricity is going to the fan.
Jul 19, 2010 | Hunter 52" Ceiling Fan With Light And...
I have a Hampton remote ceiling fan with lights.The Redington 11
the carbon of remote which help to connect the points of remote is not working so purchase the liquid carbon and put on the inner points on remorte buttons
then i feel it strt working.
Apr 29, 2010 | Universal Remote Control Hampton Bay...
Remote control wall unit does not turn on Monte Carlo fan or light although red light comes on when buttons are pushed (fan and light worked for about 2 years although it was hardly ever used).Frank
Are the manual switches on the fan in the 'on' position?
Select the maximum fan speed on the remote and then operate the manual switch on the fan. Set that to the highest speed then control it with the remote.
Same theory applies to the light.
If this is not the problem then the remote receiver on the fan is probably faulty.
Feb 28, 2010 | Monte Carlo (5LCR52MW) Fan
Recently moved, the remote doesn't work the fan, and there isn't a wall on off switch This is a Hampton Breeze fan. A Hunter univesal remote
If the remote is not working, first check the batteries. If you have the manual for the programmable remote try to reset it. If you have no wall swtch you have to control the fan and light manually with the pull chains on the fan.
Jan 16, 2010 | Hunter 27148 Remote Control
Using remote control and wall switch
think your out of luck. the switches need to be the same on both units to communicate
Jul 22, 2009 | Aloha Housewares (93645) Ceiling Fan
Televison & Video Logo
121 people viewed this question
Top Hunter Televison & Video Experts
Michael Vanidestine
Michael Vanidestine
Level 1 Expert
Henry  Thomas
Henry Thomas
Paul Bade
Are you a Hunter Televison and Video Expert? Answer questions, earn points and help others
