Question about PaceMaster Exercise & Fitness
Bad relay message
Any thoughts on what I can do?
Relays next to pc board
Do you have control voltage, usually 24 volts to the relay or relays? If so the relay does not respond it is bad. If not you need to find out why by working backwards thought your control voltage system's wiring to find cause. I hope that gives you a place to start.
Nov 22, 2013 | Heating & Cooling
My plymouth, voyager turns off while I'm driving it down the road..
Just an Idea. When it dies next time check the relay temperatures, if you can. Once I had a fan relay which would over heat and the radiator fan would not work. After relay cooled down it would work(This usually happened when I was stuck in traffic). Could be a fuel pump relay. If relay is a lot hotter than the other relay could be bad relay. My thought is it will not cost you anything to try it. I think it may be something electrical over heating. 30 years ago my thought would have been the coil, when the coil started going bad it would heat up and the car would die till it cooled off.
Nov 18, 2017 | Cars & Trucks
Have a new fuel pump , but it isn't pumping the fuel thought the system to start the pickup, not getting enough power to the pump . no fuel thought the pump. all fuse are good.
COULD BE SHORT IN FUEL PUMP WIRES OR YOU HAVE BAD FUEL PUMP RELAY OR PCM IS FAULTY COMMAND CIRCUIT IS NOT DRIVING THE FUEL PUMP RELAY OR FUEL PUMP.
Mar 19, 2011 | 2001 Chevrolet Silverado
The lights will not shut off. It has the auto light control and I tried shutting it off manually, which did nothing. What would cause this? The battery is dead enough it won't start, but the lights are...
i think that car has a headlight relay if it does the relay is bad replace relay (relay should be in fuse box) if relay is good or doesn't have one headlight switch is bad or u have a short
reason head lights still work but won't start is cause the headlights don't require as much power to run as the starter does
Jan 30, 2011 | 2007 Chevrolet Monte Carlo
Air handling unit runs continuosly, Model UHSA heat & air. Feels like the heat may be be on even when cooling is selected. Any thoughts?
You have a bad sequencer or thermal relay it controls the low fan and the heat strips. Normally there are tou but the one connected to the fan relay is the bad one.
Jan 03, 2010 | Heating & Cooling
Power window does not work
your window power relay is either bad,or the switch is not supplying power to the relay to energize the contacts that feed the window motor power,if you can find the relay, push switch and you should hear a click from relay that switch is supplying power to the relay
Sep 12, 2009 | 2003 Honda CR-V
1994 Mercedes c280 high beams not working...
headlight relay is under the screwed down portion of the fusebox.
Oct 13, 2008 | 1994 Mercedes-Benz C-Class
High beams not working...
More likely to be the high beam relay if it is affecting both headlights.
Exercise & Fitness Logo
27 people viewed this question
Top PaceMaster Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a PaceMaster Exercise and Fitnes Expert? Answer questions, earn points and help others
