My toshiba tv wont power on
I cant get my tv to power on at all worked one minute then next morning wont power on
  • 1,511 Answers
Check circuit breakers, fuses, and wired connections. In some cases a power surge can disrupt the power board. If you had a power outage and the TV was plugged into the outlet, s surge can damage vital parts.
Posted on Mar 25, 2014
2 Suggested Answers
ekcnoel
  • 998 Answers
SOURCE: Tv was on and working
your power supply is already defective try to check the fuse capacitors or the regulator.
Posted on Oct 14, 2010
I have a Toshiba DLP 62HM15A TV; I turned the TV off the night before and everything was working fine. But the next morning I went to turn it on, but the power red light came on then turned off then o
Many LED TVs and other electronics have bad capacitors on their power supply boards. You can visually inspect them by opening the TV and looking for capacitors with bulging tops. If you see any, replace them all in the power board section. This should fix the problem. Check to see if your TV is still under warranty first though.
Dec 04, 2014 | Toshiba Televison & Video
RCA D52W20 HDTV TRIES TO TURN ON 3 TIMES BUT WONT POWER UP
remove all the electrical wire connections from the back of the tv .remove the power plug from the electrical outlet and wait for two minutes and replug the wire and then ckeck.it should work.
reply.
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba REGZA 40E200U 40 LCD TV wont turn on after it was working fine the night before.
Your TV needs servicing, Most likely you have a power supply related issue. Do you have any experience with electronics repair?
Sep 01, 2012 | Toshiba REGZA 40E200U 40" LCD TV
I accidentally left my tv on overnight and it wont turn on
this could be anything from a blown fuse to a power supply or mainboard issue . you realy should have a tech come in and look at it to give you an estimate of repairs
Dec 09, 2009 | Televison & Video
My toshiba 57h93 worked fine this morning power went out
Ur DM power board is dead,must be replaced.Try this
website for the board.Tv repair World.com.
Oct 20, 2009 | Toshiba 57H93 57" Rear Projection HDTV
Remote problem
With the set on, I would like you to use all of the manual control buttons on the set to see if they all work the way they should. If any one of them does not or if all don't, then I would say your have a corrupted E-Prom which will have to be replaced by a service center. This is not an expensive repair, probably around 75-100 $, depending on who does it. It's a no brainer for a tech.
Apr 04, 2008 | Toshiba 32A61 32" TV
No picture, no sound, no menus
hard to diagnose with out voltage measurements, first thing i would do is call insurance company and tell them you had a brown out and then the tv went out.
a common problem with this tv is convergence amp ic's
http://www.hdtvoice.com/voice/showthread.php?t=28929
Feb 21, 2008 | Toshiba 42H83 42" Rear Projection...
TV refuses to stay on
I'm the OP of this, and what I did was had it unplugged for about 2 days, plugged it back in and it has worked since.
Aug 23, 2007 | Toshiba MD20F51 20 in. TV/DVD Combo
TV does not turn on; red light blinking.
your problem is a more technical problem you will need a tech to look at your set if you are not a tech you wont be able to do it your self. contact a tech to repair your set the problem is in the power supply or related circuit.good luck.
May 02, 2007 | Toshiba 27AF41 27" TV
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
