Question about Casio FX-9750GPlus Calculator
How to solve an inverse of matrices
MAT isn't appearing when i press options.
  • Casio Master
  • 8,068 Answers
You must be in the RUN screen.
Press Menu
Press 1:Run
Press OPTN
Under tab F2:Mat you get the MAT tab.
To invert a non-singular matrix A (a matrix with non-zero determinant) you, on the command line type in
Mat A then press the [x^-1] key. The [x^-1] is the shifted function of the right parenthesis.
how to solve an inverse of matrices - 0d100874-9ad9-434c-9c55-b1502275425d.png
Posted on Mar 25, 2014
How to solve the inverse of a 3x3 matrix
You can jump to the end of the post for you answer.
A. Define the matrix (Create it)
Turn calculator ON.
Press Menu,select the MAT icon and press [EXE]
You see a list of possible matrix labels (A, B, C,D,E,F)
All that have not been created have a "none" to their right
Highlight a matrix name and press the right arrow. Where there was "none" , you have a template 0x0.
That is where you specify the dimensions (mxn). exemple. 2x2
Enter the first dimension and press [EXE]
Enter the 2nd dimension and press [EXE]
A matrix template opens where you enter the coefficients left to right and up down.
After each coefficient press [EXE]. Cursor moves to the next coefficient, etc.
At the bottom of the screen you have 3 menus for Row and column manipulations. But those will have to wait for now.
Press [SHIFT][QUIT] to return to the list of matrices to create new ones
B. Operations on matrices
Once you have one matrix, you can do operations on it: Calculate the determinant (if matrix is square), calculate its inverse, transpose, augment it, fill it, etc..
These operations are accessed as follows.
Quit the matrix editor by pressing [Menu] and selecting the [Run] application.
Press [OPTN][F2:MAT]
You have the menus Mat,M(atrix)->L(ist), Det(erminant), Trn (transpose), Aug(ment) ->, Iden(tity),Dim(ension) Fill
Exemple : calculate the determinant of a matrix A (already defined).
You press the [OPTN][F2:MAT] key sequence (just above)
Press [F3:Det]; the command det is displayed on screen.
Press [F1:Mat] the identifier Mat is displayed.
Press [ALPHA] A; screen display det Mat A.
Press [EXE] to get the value of the determinant.
C. Square of Matrix A
[OPTN][F2:MAT] (MAT) [Alpha] A ^2 [EXE]
D. Product of two compatible matrices MatAXMatB
[OPTN][F2:MAT] (MAT) [Alpha] A [*] (MAT) [ALPHA] B [EXE]
E. Calculate the inverse of a square matrix (Mat A)
Use commands like the ones above to display the command Mat A, the press the [x^-1] key. You will get the inverse if matrix can be inverted.
Apr 27, 2012 | Casio FX-9860G Graphic Calculator
I'm having a hard time trying to solve matrices on my Casio calculator. I can enter the deminsions of the matrix, but I don't know how to solve them.
Here is enough to get you started and a little more.
Read the post ant consult your calculator manual. The screen captures below may not look exactly as your calculator but the steps are identical.
A. Define a matrix (Create it)
  1. Turn calculator ON.
  2. Press Menu,select the MAT icon and press [EXE]
  3. You see a list of possible matrix labels (A, B, C,D,E,F)
  4. All that have not been created have a "none" to their right
  5. Highlight a matrix name and press the right arrow. Where there was "none" , you have a template 0x0.
  6. That is where you specify the dimensions (mxn). example. 2x2
  7. Enter the first dimension and press [EXE]
  8. Enter the 2nd dimension and press [EXE]
  9. A matrix template opens where you enter the coefficients left to right and up down.
  10. After each coefficient press [EXE]. Cursor moves to the next coefficient, etc.
B Operations on matrices
  1. These operations are accessed as follows.
  2. Quit the matrix editor by pressing [Menu] and selecting the [Run] application.
  3. Press [OPTN][F2:MAT]
  4. You have the menus Mat,M(atrix)->L(ist), Det(erminant), Trn (transpose), Aug(ment) ->, Iden(tity),Dim(ension) Fill
Example : calculate the determinant of a matrix A (already defined).
  1. You press the [OPTN][F2:MAT] key sequence (just above)
  2. Press [F3:Det]; the command det is displayed on screen.
  3. Press [F1:Mat] the identifier Mat is displayed.
  4. Press [ALPHA] A; screen display det Mat A.
  5. Press [EXE] to get the value of the determinant.
Part E Invert a (square, non singular) matrix that was already defined.
Press [OPTN] [F2:Mat] to open a screen similar to the one in capture above
Press [F1:Mat] to have identifier Mat displayed.
Enter the name of the matrix by pressing [ALPHA] A, for example.
Press [SHIFT] [ ) ] activate the (x^-1) key.
This is what you might see (with parentheses and without).
Press [EXE] button to calculate the inverse.
Apr 20, 2011 | Casio FX-9750GPlus Calculator
I am unable to solve determinant of matrix.
How to calculate the determinant of a (square, non-singular) matrix is described in part B
Apr 08, 2011 | Casio FX-9860G Graphic Calculator
How do you add matrices such as a (2x2) (2x3) on a casio fx-9750g
Mar 23, 2011 | Casio FX-9750GPlus Calculator
How can i use Graphic calculator (fx-9860G) to solve matrics ( addition and multiplication etc). Would you please help me step by step. Asmat
Mar 09, 2011 | Casio FX-9860G Graphic Calculator
Hoe to calculate a inverse matrix?
Sorry if post is too long. Skim through it to find the inverse of a matrix in part at the end:Part E
Note: Matrix must be square (nXn) and non singular (its determinant not equal to zero)
Feb 25, 2011 | Casio FX9750GII Graphic Calculator
How do you do matrix?
Here is a small sample of things you can do with matrices.
Press the F6 key to access other functions.
Jan 23, 2011 | Casio FX9750GII Graphic Calculator
How do I find the solution to a matrix once the coefficients are entered?
I am afraid that "find the solution of a matrix" does not mean anything. However if you want to perform some arithmetic operations on the matrices ( multiplication, addition, subtraction) you can do so using the regular operation keys.
If on the other hand you want to calculate determinants of square matrices, inverse square matrices etc.
Go to the RUN/MAT screen and press [OPTN, then press F2 to open access these operations and this is what you see.
F1 type the MAT identifier in command line
M>L converts a matrix to a list
Det calculates the Determinant of a square matrix
Trn transposes the matrix,
etc.
To invert a square matix, use the [X^-1] key e.g. MatA^-1
Nov 22, 2010 | Casio FX9750GII Graphic Calculator
How can I solve a matrix on my Casio fx-9750GA PLUS? I'm used to using the TI calculators.
If you have mastered matrix manipulations on the TI calculators, it should be a breeze to learn the same on the Casios.
  6. That is where you specify the dimensions (mxn). exemple. 2x2
Square of Matrix A
[OPTN][F2:MAT] (MAT) [Alpha] A [* ) (MAT) [ALPHA] B [EXE]
Hope it helps.
Thank you for using FixYa.
Nov 23, 2009 | Casio Office Equipment & Supplies
ERR:SINGULAR MAT when finding inverse of matrices
If a matrix has a determinant of 0, this error appears. If you get this error, your matrix doesn't have an inverse.
Jun 02, 2009 | Texas Instruments TI-84 Plus Silver...
Casio FX-9750GPlus Calculator Logo
76 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
