Question about Viking VGS0166 Stainless Steel Gas Single Oven
Oven temperature I have two single ovens. I bought them at the same time when I remodel my kithchen. around 6 years. Ovens are used an average of 10 to 12 times a year. after two year, they can't regulate the temperature. I put a dial thermomether inside the ovens. I have to set the ovens to around 365 -370 degrees in order for the oven temperature to reach 350 degrees, then it varies, it goes up and down. it's hard to bake anything with this problem.What could be the cause of the temperature to fluctuate like this? Than you.... Jorge
  • annie-jajjie Dec 05, 2007
    My Viking oven seems to go to 450 degrees regardless of what temp setting I select
  • Anonymous Mar 27, 2014
    When using my oven to bake, usually at 350 degrees, my oven cycles off and does not cycle back on. The first few times I used the oven, I could hear it cycle on and off, but now it only cycles off. The display will continue to show 350 degrees, but the oven is not nearly as hot. I have turned the oven off and then immediately turned it back on. The preheating temperature is down to 165 degrees which causes my baked goods to be gooey on the inside. Was it designed to work this way or is it malfunctioning?
You guys should check your tempurature sensor. Our oven has been acting weird like saying it has heated up to 400 degrees in like 1 minute haha. Well after a few months of this happening on occasion we get an F2 error flashing..
did some research on it and apparently for GE ovens this is a temp sensor gone bad. Im looking to buy one now which is how i found this post, i just thought id tell you all what i found out and maybe you should look into that as well.
Posted on Dec 06, 2007
How close should the temp control hold the temp
Generally the oven temperature will fluctuate as much as 30 degrees above or below the set temperature. The longer the oven is on, the less the temperature fluctuates. If you measure the highest and lowest temperatures readings with a thermometer after the oven has been preheated at least 20 minutes, you should come up with an average temperature somewhere within about 10 degrees of the set temperature. You can calibrate most ovens up to 35 degrees higher or lower if it is off. Any more than that requires replacing parts.
Apr 24, 2014 | GE Profile JTP18 Electric Single Oven
When baking the oven doesn't bake evenly and always bakes quicker than the time on recipes. Items burn and the middle is raw. Can the oven be recalculated to work better?? John
Electric ovens are always different from gas ovens. You have to set the temperature on average 10-15 degrees lower and watch out 15 minutes earlier if you are baking cakes, 5 mins for cookies etc. Always bake in the centre of the oven. use a metal bowl of water in another tray which may help balance out the temperature
Jan 01, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Model SVD48600 door won't open after clean cycle. Fan also locked on. Powered off overnight; no change: "Locked" still displayed
That is a very complicated unit for the average handyman. It has electronic controls and a relay board, sensors and a locking mechanism. First thing I would check is the locking mechanism and the switch on it. Do this first and let me know if you find one of the switches defective or shorted. While there, check the light switch which is bi-functional being used for the light and also to tell the ERC the door is opened or closed.
Jenn-Air self-cleaning ovens have a special setting that allows you to clean the oven without chemicals or scrubbing. The oven heats to a temperature higher than used for cooking. The intense heat burns food spills and other residue off oven's inner surfaces.
1. Remove the broiler pan and any utensils to prevent them from being damaged. Take out the oven racks, since the high heat might discolor them.
2. Wet a cleaning cloth or sponge with hot water and detergent. Wash off splatters or spills from areas that won't be affected by the cleaning process, including the oven door liner and the oven's front frame. Wipe up any excess grease or spills on the oven floor.
3. Close the oven door and press the "clean" pad on the unit's touch pad.
4. Enter the amount of cleaning time. For example, two hours is appropriate for a lightly soiled oven, three for average and four for heavily soiled. Cleaning should start immediately. The oven will remain locked during the cycle.
5. To delay cleaning, hit the "stop time" pad and enter the desired stop time. For example, if it is 9 p.m. and you want the oven to clean for three hours starting at 10 p.m., key in the numbers 1,0,0.
6. While the cleaning function operates, use the scouring pads to wash the oven racks and other utensils. Once the cycle ends and the oven unlocks and cools, you can use a damp cloth to pick up any loose or burnt debris inside. Replace the racks, broiler pan and utensils.
Tell us news.
May 09, 2010 | Jenn-Air JGW8130DD Gas Single Oven
My maytag oven has a function error. F5 and F3
Hi sorianocynth,
Maytag error F5 and F3 do have different indications. Error F5 means watchdog and hardware conflict. The only way to resolve this is to replace clock (ERC). On the other hnd, F3 means you have shorted or open oven temperature sensor (RTD). Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. When they send out the part detailed instruction will be provided.
Hope this helps.
Thank you for using FixYa.
Jan 19, 2010 | Maytag 30 in. Electric Single Wall Oven...
Jenn-air SVD48600P oven will not work / F3 error . I recently replace the expense control / clock unit on my oven because it would not heat. This was advice from repair person. Once replaced the over...
Hi jmhostetler9,
This F3 that keeps flashing on your oven is caused by a shorted or open oven temperature sensor (RTD). To fix this problem check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model # ready when you call.
Hope this helps.
Dec 22, 2009 | Jenn-Air JJW8530C Expressions Collection...
Kenmore double oven flashing "door locked"
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Receiving F3 Code
HI, no need to replace the unit at this time. this is a Open or shorted oven temperature sensor (RTD).
Jul 16, 2009 | GE JRS04 Electric Single Oven
Oven light
Hi there it's possible that you are using an incorrect bulb in your oven....ensure on purchasing relacements that these are OVEN Bulbs (these are special bulb to operate at high temperature) ensure that the bulbs are screwed correctly and firmly into the holders and the glass cap is correctly fitted and secure.....
regards Sir Galahad
Mar 10, 2009 | DCS Large Appliances Built-In Ovens...
Dacor oven
Faulty temperature select. How old do you think the unit is ?
Nov 24, 2007 | Dacor ECS130 Epicure Electric Single Oven
Oven taking a long timt to heat to temperature
Try shutting off the breaker for about 10 minutes - then bring the power back on
Sep 20, 2007 | GE Profile JT912 Electric Single Oven
Viking VGS0166 Stainless Steel Gas Single Oven Logo
452 people viewed this question
Top Viking Ovens Experts
Dan Webster
Dan Webster
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Viking Oven Expert? Answer questions, earn points and help others
