Question about Sewing Machines
Front tenseness for the cotton dasen't vork
Front button for cotton tenseness not in the funcions
    New Friend:
  • 46 Answers
If the spring in the tension discs is not tightened correctly then the tension discs will be lose snd not provide the tension you need to sew.
Posted on Mar 28, 2014
What would a typical tension number be for a cotton fabric? mine is loopy or tight right now
you didn't mention the name and model number of the sewing machine or serger... is the loopy thread on top or bottom? when is the thread tight? what type of cotton fabric,, solid cotton--polyster cotton? normally mine stays on 4 or 5 --depends on fabric I'm sewing..
Dec 15, 2014 | Sewing Machines
How to thread the machine
From the spool pin take the thread to the left and over the top cotton guide, bring the thread towards you and straight down in between the tension discs, make sure the presser foot is up so the discs are open, straight down towards the needle and round the first big cotton guide, straight back up to the take up lever making sure the take up lever is at the top, right to left through the eye of the take up lever, straight down to the needle going through any guides on the way, thread the needle front to back
Oct 02, 2013 | Necchi 4575 Mechanical Sewing Machine
Are needles threaded front to back
Thread cotton through needle from front to back.
Jul 04, 2012 | Singer 14SH654
My PFAFF 207 keeps knotting from the bobbin and having long threads which become tense and need cutting beneath the material. Please help
You need to check the following-
1- check that needle is perfectly pointed under a magnifying glass\
2- check the tension on the thread from the upper reel , increase it if necessary .
Aug 05, 2011 | Sewing Machines
Bottom stitching loose
If your bottom stitching is loose ie looping it is normally the top tension that needs tightening. Just adjust the tention on your cotton on the top front of your machine. Hope this works.
Feb 05, 2011 | Sew D'Lite 11401 Mechanical Sewing Machine
Where is the reverse button on elna 2005?
The reverse button is next to where you thread the cotton. as the thread goes down to the needle, there is a small cream tab approx 1.5cm long. This is pushed down when you want to reverse. It will only go down about 1.5cm then release.
Sep 26, 2010 | Elna 2005 Mechanical Sewing Machine
I have a RS2000 and the cotton real spins the cotton breaks and then i have this mass of cotton under the foot and i cant turn the wheel forward or back all the cotton has looped underneath the material. i...
I think you are suposed to use the left hand guide above the needle. The right hand guide is used when you are using a twin needle. See if that helps.
Aug 13, 2010 | Toyota Sewing Machines
Thread is to tense and cannot fix bobbin
See if you can find the threading guide or manual online at sewusa.
If you cannot find the exact model, you may find one that is very similar that will show you how to thread, wind a bobbin and insert it into the bobbin case/shuttle.
You can also try these suggestions:
Set the tension to 4.
Lift the presser foot and rethread the machine. It is important to thread in this manner for the tension control to work properly.
Mar 01, 2010 | Euro-Pro Sewing Machines
I need a threading diagram singer 329k sewing machine
Cotton omn the reel pin, take the thread from the right to the left and through the top cotton guide above the takeup lever, make sure the takeup lever is at the top and make sure the presser foot is up, take the thread down the right hand side, round the tension unit and back up the left hand side to the takeup lever, right to left through the takeup lever and then follow the guides all the way down to the needle and thread front to back, flat side of the needle must face back.
when you put the bobbin in, bobbin in your left hand and the thread must feed from the bottom of the bobbin, drop the bobbin, through the groove and lay the thread to the back.
Feb 12, 2010 | Singer Sewing Machines
Tension
5 is the default tension.. if you are not satisfied with it try to adjust a little.it a try and error
Sep 06, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
41 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
