Question about Whirlpool Ovens
Door will not open
The light is now in the oven but the door will not undo
  • 1,511 Answers
Did you do a Cleaning and Lock the door by chance? Get the manual for instructions on releasing the latch.
Posted on Mar 25, 2014
How do I clean in between glass doors on a Westinghouse 663 wall oven? I don't see any screws to undo. There must be a trick to it!
lift the door off it;s hinges then lay it on the floor or a table top and look around the outer edge several screws hold the 2 halves together .CAUTION glass will slide out and break .GOOD LUCK
Aug 19, 2016 | Ovens Ovens
How do I replace the handle on a neff oven?
1. Fully open the oven door.
2. Move the catch levers on the right and left-hand sides to the fully open position.
3. Placing the door at an upward angle toward you, grasp the door with both hands and lift it out of the hinges toward you.
4. undo the screws in each Connor & lift out the glass.
5. do the same with the handle screws, then put new handle on.
6.repeat above steps backwards.
Aug 30, 2014 | Neff Ovens
How do i clean inside my delonghi glass door the inside
if you pull the oven out a little bit and look under the the door there should be 3 screws you only need two undo one on each side but when undoing the last screw hold the bottom of the door tight as it will fall when you have door frunt off job done ok
Oct 12, 2012 | DeLonghi DEBIE24SS Stainless Steel...
How to pick the right element
open the door in the oven theres 4 scrwes then unscrwe the light the plate should fall down then one screw to undo to take off the heater there might be 3 or 4 screws holding it in plase undo them when tajkeing heater out be carefull not to pull to hard as the wires will coime off and go right in side so do it slowly ok
Oct 12, 2012 | Ovens
I need to set the time on my diplomat softline oven
If you operate the grill with door closed, cut-out will come into operation and the grill will not light. pull oven out of the wal,l undo the screws that are in the galvanized cover, lift up the cover and press the red reset button. put it all back together & it should be okay.
Sep 14, 2011 | Ovens
Have a maytag super capacity plus oven i tried cleaning the oven now the door will not open and it shows f9 on the front
Had the same problem. How I fixed it, was by using a very thin, and I mean really thin, flat tip screw driver and a flash light. Unplug the stove. Use the flash light to look at the very top of the oven door. You should see in the air vent slats a silver hook. Use the screw driver to go through the vent slats and push the lock open. Now, you should be able to open your door. But we arent done yet. With the door open, plug the stove back in. Close the door and wait for the F9 to flash. Now open your door, and on the right side you should see a tiny peg sticking out on the open oven. Its for the light to come on when the oven door is open and also to let the oven know the door is ajar. Push it in and wait. The door latch circuit should reset like normal, and you will see the latch move back into its normal open position. Which resets the F9 error and allows you once again to use your oven like normal.
Dec 20, 2009 | Maytag Ovens
Electrolux EOB944. How do you remove the Glass panel in oven door ?
Hi
to remove glass panel you need to open door abit on top of door is 2 screws. undo these but hold handle at same time so it doesnt fall . once scrwes are out prise apart a little bit the lift glass then it should be of . hope this helps
regards dan
Mar 19, 2009 | Electrolux Ovens
Noise from fan when electric oven is first turned on
The fans are not normally repairable, but there is no problem obtaining replacements.
On a double oven, there are usually 2 fans fitted.
There is an external cooling fan usually fitted on the top of the oven, you would have to remove the top cover of oven to access it, and possibly the rear panel as well.
Then there is the fan fitted in the main oven compartment.
If you open the oven door as it is working, you should be able to determine if it is the fan oven or the external cooling fan that is the cause of the problem.
If you determine it is the fan in the oven that is noisy, then to undo the fan blade assy, you have unscrew the nut clockwise to remove it. as opposed to the normal way of undoing a nut.
Please rate my fixya solution.
Thanks.
Feb 09, 2009 | Whirlpool RBD305PD Electric Double Oven
Nef u1461 top oven
hi managed to clean my oven door this week end! yes you undo the two screws nearest the middle - but you will need an alan key to undo the top glass pops off -there is a spring clasp underneath - just ensure that you leave the door flat whilst you taking it apart. hope this helps i now have a nice clean oven door - you will be able to clean all parts once you pop off the glass - hope i was usefull!
Apr 16, 2008 | Neff B1641 Single circotherm super...
Ovens Logo
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
