Question about LG DLG2524 Gas Dryer
LG Gas Dryer Noise
High Pitch squeal and how to get the panels off
  • LG Master
  • 1,511 Answers
Contact the manufacture at their web site and get a Support Rep. to assist you with dowloads of Manuals.
Posted on Mar 25, 2014
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: LG dryer is making a very bad noise (high pitched
Sounds like a guide wheel... first the bearing started to go bad,then it actually locked up or came apart.
The wheel(s) will need to be replaced.
You can find new parts by doing a search for "appliance parts"
Then enter your model number into one of the sites and look for your part from the menu.
Check a couple of different sites to be sure that your getting the best pricing/
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 07, 2009
Testimonial: "Thanks guys - you're awesome"
heatman101
  • 43501 Answers
SOURCE: LG dryer was making a squealing noise, then
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dfhjdg
Posted on Sep 29, 2010
When i run my GE Clothes Dryer, It has a high pitch squeak How can I fix this
remove the front panel inside there is what is called the top door bearing,its probably worn through the drum slides and into the plastic bearing creating this squeal part # WE3m26
Feb 10, 2013 | GE Dryers
Car is making a high pitch squeal some times when driving,noise gets worse when I take foot off the gas pedal. Also has odor of boiled eggs at times. Is this a tranny problem or emission system failure or...
The high pitch squeal ia most likely the serpentine belt on the front of the engine you can buy some belt dressing from the part store and put it on there and fix that or some soap will work also, the belt may also need to be tightened. As for the egg smell if it smells like eggs it's the catylitic converter doing it's job and is normal, although you should not be able to smell it inside the car when driving you may have an exhaust leak and could be very dangerous carbon monoxide exposure.
Jun 02, 2011 | 1998 Nissan Maxima
Had the video card replaced and 6 months later no sound only a high pitch noise. What is wrong with it?
fans bearings are going bad. lube or replace the whole fan. it also could be powersupply, they make a high pitch squeal sometimes when going bad.
Mar 24, 2011 | Vizio VP322 32 in. Plasma TV
I have a kenmore gas dryer model 70722990 when you turn it on it has a very high pitch squeal sound runs for 5 minutes then turns it's self off and won't turn back on. can you please tell me whats going...
heatman101
Asker
Dec 27, 2010 | Kenmore Dryers
Dryer is making a high pitch noise while operating, it is fine for about 30 sec. and then it starts to chirp.as if something is rubbing.
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 16, 2010 | LG DLG3788W Gas Dryer
Dryer works but makes high pitch noise
This probally the idler pulley, drum rollers, or a bearing hard to say until you take it apart and take a look. There is a good video on checking and replacing these parts at www.appliancehelponline.com/servicemanual.html
Hope this helps
Mar 21, 2010 | Dryers
When we start our dryer it makes a loud noise as if it struggles to get the drum moving. Once the dryer is moving it has no trouble moving, but every time we start it, the noise happens again even if i was...
Is this noise like a loud buzz or hum? If it is it may be the motor draging
and can't quite get going. bearing getting worn.
Also check drum rollers or glides and the idler pully one of them may
be dragging if they are you might put a little high temp oil on it.
Hope this helps..
Jan 25, 2010 | LG DLE2532W Electric Dryer
Maytag electic dryer noise
First, pop up the top of the dryer -- use a large slotted screwdriver under each corner of the top. There will be screws holding the front of the dryer -- take these out and take the front off. The squealing is coming from roller bushings which need lubricating. Apply machine oil to all the axles/bushings -- this most likely will stop the squealing -- and don't forget to unplug it first.
Apr 23, 2009 | Maytag Dryers
LG DLG2524 Gas Dryer Logo
53 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
