Question about Dell Inspiron Computers & Internet
Dell inspirion on start up it saying could not load file or assembly'MOM. Implementation'on of it's dependencies. The system cannot find the file specifield
  • 1,511 Answers
The locator in the systems operating program cannot find the hardware or other links necessary to carry out the operation. Either the upstart files are corrupt, or a command was initiated seeking an incorrect address.
Posted on Mar 25, 2014
    Top Expert:
  • Dell Master
  • 26,727 Answers
I would try and reboot using F8 just before it starts. You may be able to recover any damaged files from there
  • 400 Answers
SOURCE: I have dell 110L inspirion with XP professional.
I think your Windows installation is damaged. Boot from your operating system CD. (Go into setup mode F2 or delete during bootup. Go to the Boot select screen and set up to boot from CD. Place your OS CD in the drive and power on.) When it boots, it should give you the option of REPAIR. Select this and allow Windows to repair itself. I hope this helps you resolve your problem.
Posted on Nov 16, 2009
  • 3 Answers
SOURCE: no operating system
This sounds like a common case. Usually if computers are not shut down properly then data is lost. You might need to do a fresh reinstall of operating system (windows). Before you do this, try to find a way to back up important files. Try connecting the hard drive to another pc and make a copy of needed files. Then install a fresh copy of windows. You can obtain a copy of installation these ways:
It comes with some computers.
Your computer might have a recovery section on the hard drive.
You can purchase a copy from a store "walmart"
You can purchase a copy from microsoft
Or if your smart you can get it online for free.
Posted on Apr 24, 2009
halbrook
  • 560 Answers
SOURCE: my Dell inspirion dc power jack base assembly
Ebay is my best source of computer parts.
Posted on Jan 19, 2010
LASITHA-VEGA
  • 428 Answers
SOURCE: See the end of this message for details on
Not sure whether this is a Q.
To enable just in time (JIT) debugging, the config file for this application or machine (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the machine rather than being handled by this dialog.
In VS the way to enable/disable that is: 1-On the "TOOLS" menu, click Options. 2-In the Options dialog box, select the Debugging folder. 3-In the Debugging folder, select the Just-In-Time page. 4-In the Enable Just-In-Time debugging of these types of code box, select or clear the relevant program types: Managed, Native, or Script. To disable Just-In-Time debugging, once it has been enabled, you must be running with Administrator privileges. Enabling Just-In-Time debugging sets a registry key, and Administrator privileges are required to change that key. 5-Click OK.
It has to be done by the developer and its his responsible to guide the application error reporting to the system event handlers. If this is an issue which occurs in a certain app, have to check for the .net version (specially in vista). Many 1.0 and 1.1 based apps give the problem. To install dotnet fw 1.1 on Vista will give an error. Most of the time caused by DEP (Data Execution Prevention). But the thing is some software forces the installation of .net framework (older versions). How ever Vista is packed with .net 3.0 and 2.0. Even if you allowed to install will not be able to uninstall 2.0 (possible to remove 3.0 though).
How to solve the installation issue: This issue is resolved in Microsoft .NET Framework 1.1 SP1, however you will need to use the following procedure to install both the .NET Framework and the Service Pack at the same time: Download Microsoft .NET Framework 1.1 Redistributable Package and Microsoft .NET Framework 1.1 Service Pack 1 using links below: Dotnet Framework 1.1 Redest Dotnet Framework 1.1 SP1
Save both installations in the same directory Ensure that the Microsoft .NET Framework 1.1 Redistributable Package is named dotnetfx.exe. If not, change its name to dotnetfx.exe. Ensure that Microsoft .NET Framework 1.1 Service Pack 1 is named dotnetfxsp1.exe. If not, change its name to dotnetfxsp1.exe. Open command prompt as Administrator, and change to the directory where the two installations are saved. Run the following commands using the order shown below dotnetfx.exe /c:"msiexec.exe /a netfx.msi TARGETDIR=C:dotnet" dotnetfxsp1.exe /Xp:C:dotnet etfxsp.msp msiexec.exe /a c:dotnet etfx.msi /p c:dotnet etfxsp.msp Install both Microsoft .Net Framework 1.1 and Service Pack 1 by running C:dotnet etfx.msi
The systems must be backed up before trying this specially the system state. How ever the keys can be repaid in a damage This thread will also be helpful http://blogs.msdn.com/b/astebner/archive/2007/03/26/how-to-repair-the-net-framework-2-0-and-3-0-on-windows-vista.aspx...
Posted on May 29, 2010
joecoolvette
  • 5660 Answers
SOURCE: dell inspirion 6000 is showing "loading PBR2.....done. NTLDR IS MISSING.HOW TO FIX
Use the Restoration Disk. When asked choose Repair.
(Non-Destructive Installation)
You are missing basic Windows files. Boot loader files.
Also you may have to prepare to replace the harddrive. May have bad Sectors on it.
Means I would copy off all personal information, after getting that laptop going again, or you may lose it.
Regards,
joecoolvette
http://en.wikipedia.org/wiki/NTLDR
http://computer.howstuffworks.com/hard-disk.htm
http://computer.howstuffworks.com/hard-disk7.htm
Posted on Dec 19, 2012
Dell inspirion 1545, turn the power on and the screen shows inspirion loading. then the fan speeds up and slows down then the pc shuts down
hi Denny...
just to narrow the possibilities try to start it on main power only (remove the battery).
If it started OK then replace the battery...If not, send me your feedback.
Mar 21, 2018 | Dell Computers & Internet
I want to down load pictures to my comp from a picture disk How do I do it ?
Use PC file manager software to transfer the picture files from the disk to the hard drive and put in "my pictures" folder.
Oct 13, 2014 | Dell Computers & Internet
On start up I keep getting this could not load file or assembly'MOM.Implementation' on one of its' dependencies. The system cannot find the file specifield
The DLL or Dynamic Link is missing and unless you do a full installation of the program or operating system, you will never open the area or program desired.
Mar 25, 2014 | Dell Dimension Computers & Internet
Dell inspirion 6000 is showing "loading PBR2.....done. NTLDR IS MISSING.HOW TO FIX
Regards,
joecoolvette
Dec 19, 2012 | Dell Inspiron 6000 Notebook
The dvd drive on dell inspirion 1525 wont open...when I go to it under computer it says please insert dics and then say failed to eject...what do we do??????????
The loading tray has a pin hole on the front door, get a fine screwdriver or needle and push it in until you hear a click the tray should pop open, pull it all the way out, look under the tray for a small black loading belt make sure it is snug tight. If the DVD driver fails to work at this point, replace the entire assembly.
Jan 08, 2011 | Dell Inspiron 1525 Notebook
Dell laptop DVD issue
If you have Vista OS, it could be a problem after installing ATI's Catalyst Software Suite. If you recently installed it, try uninstalling it or rolling it back to an older version.
Mar 20, 2010 | Dell Studio 1737 Laptop
To get motherboard chipset files.
things to try:
1. install .net 2.0 (try this first)
2. uninstall your video driver. (you may have to do it manually)
3. reinstall your video driver files.
4 if all else fails try to run system restore back before you installed the video driver. Then download all the windows updates (.net 2.0 also) and then put on the video driver.
Apr 08, 2009 | ASUS SOCKET AM2 AMD ATHLON 64 X2/64...
It did not work..T__T
Please download just the driver from HERE.
Don't install the Catalyst software. Your card should work with just the driver. Also make sure you have the latest version of DirectX.
BTW, which OS are you using? If you are using Vista, then you may find that this driver may not be compatible as it is for 2000/XP.
May 01, 2008 | ATI Mobility RADEON Graphic Card
Computers & Internet Logo
29 people viewed this question
Alun Cox
