Question about GE Ovens
How to change out light receptacle for GE wall ovens JKP30W0M1WW
I need to change out the WHOLE receptacle do i have to disassemble the whole oven? i have the part how to change out light receptacl for GE wall ovens JKP30W0M1WW
SOURCE: Control panel disassembly
Shut the breaker off to the oven first. Frame around mircowave is a snapped on front. Removing allows access to two screws under control panal. Must actually pull entire unit out about 9 inches to access top of control area to remove access panel. Once front control panel is removed and top is opened, easy access to what you need to get to. Carefully write down color coding of wires before removing any of them. Remove old power supply board and display and reconnect. Reverse process. A bit of work but if you watch the disassembly process carefully, pretty easy.
Posted on Jul 12, 2008
  • 69 Answers
SOURCE: need instructions on my GE profile wall oven
GE.COM really helps
Posted on Sep 20, 2009
Macmarkus
  • 2605 Answers
SOURCE: I have a Thermadore double wall oven, M# C302ZS.
I've copy and pasted an exert from this ovens service manual. try this and let me know of the results.
Good Luck
F-24 or F-25 This is caused by close contact to the control panel for more than 60 seconds,
appears in display window such as someone leaning against the controls or objects hanging in front of
controls.
F followed by 2 digits appears Touch OFF or turn power off at the circuit breaker, wait 3 minutes and turn
in the display window it back on.
Posted on Oct 29, 2009
SOURCE: I have a Thermador SC301 wall oven and the display
I have just repaired two SC301 ovens myself, but it is alot of work. You can get the oven's LED lights reconditioned at a company called CGI industries. Look them up on the web and click on the link for thermador. Removing the led panel and oven relay board is an involved job, but easier if you do it the correct way. First, turn off the power to the oven. Then pull the oven out of the wall socket about 1 quarter of the way. Remove the top cover of the oven with a phillips screw driver. This reveals the oven relay board. Take a digital picture of the board to remember the wire positions, or alternatively write them down. You also need to remove the touch panel (two screws underneath) and gain access to the LED. Remove the LED panel and wires. ship both to CGI (boards only) and you will have them back in less than a week. Costs about $170 before shipping. Reinstall and turn power on. All is good.
Posted on May 03, 2010
jyackle5
  • 8197 Answers
SOURCE: I need to replace my
Try calling maly at (800) 999-1360 to get your part.
Posted on Nov 22, 2010
How do I uninstall a GE double wall over?
The instructions come with the oven. And differ with models. Most important to follow all items. If the instructions are lost , Google GE double wall oven ( give model number). Or try the GE Dealer.
Aug 23, 2014 | Ovens
Jen-air electric oven jjw8530. Door will not shut all the way. Light stays on. Hindges have been replaced twice. Not hindges! Help!
Bubbcrk,
Is your door lock in the way? I think that your model has one correct? Have you checked the door light switch? If it is the switch that is keeping the door from shutting and turning the light out, you can get one fairly cheap.
Please Clarify.
Door Light Switch for your model
http://www.pricedrightparts.com/products/Door-Light-Switch-PRP71002904.html
Thanks Joe
Jun 11, 2011 | Ovens
The start button is not activating the oven - do i have to change the whole board
HI, you need to change the whole front keypad not the board. This piece is about 150-200.00.
Sean
Mar 26, 2011 | GE Profile JTP18 Electric Single Oven
GE Profile Wall Oven Circuit Board
http://www.searspartsdirect.com/partsdirect
I HAVE QUESTIONS. THIS THERE 240 VOLTS AC TO OVEN. YOU MAY HAVE A BREAKER PROBLEM. FLIP THE BREAKER BACK AND FORTH 3-5 TIMES FAST TO GET IT TO RESET. IF THE LAST THING YOU DID WAS A SELF CLEAN THEN YOU MAY HAVE A SAFETY THERMOSTAT PROBLEM. IF YOU CANNOT FIND THE WHOLE MODEL NUMBER ON THIS SITE CALL 1-800-GECARES THEY WILL HELP YOU WITH PARTS
Apr 25, 2010 | GE Profile JTP18 Electric Single Oven
Has an f-8 on dislay oven won't work
F8 Shorted meat probe Problem could be with the probe, the receptacle, or probe circuit. Check probe. Look for pinched wire. Look for condensation or contamination on probe receptacle
Mar 15, 2010 | GE 24" Built-in Single Electric Wall Oven...
Replace oven light bulb? magic chef wall oven
for model 9815xub, the oven light consists of a light bulb cover(clear plastic, sometimes called lens) the light bulb receptacle( pressure mounted against the back wall of the oven ) and the light bulb, standard appliance bulb that screws into the receptacle, the same as the lens, it also screws into the receptacle, twist counter clockwise to remove both the lens and the bulb. as a reference try the following site:
www.partselect.com/ and type your model number in the window, then click on the oven cavity breakdown to view thwe assembly.
Jan 31, 2010 | Whirlpool RBS275PD Electric Single Oven
Key board will not light up...Nothing....Oven light will come on......TTT
Whirlpool RBD305DQ15 Electric double wall oven, the control panel does not light up so you can't tell what you are doing. Do I need to replace the whole board or is there a fuse to replace?
Oct 05, 2009 | Whirlpool RBD305PD Electric Double Oven
Wall Oven JKP30W0M1WW - front control panel overlay bubbles and separates. It did this before it was 1 yr old and they sent me a replacement and now before that part is 1 yr old it is doing it again -...
GE is now fixing this problem, no charge. I called about mine, at 866-622-6184 They have the white version already available. A month wait on the black. Then they send out a service tech to install, free to you.
Jul 20, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
Cracked see through glass -Frigidaire Gas Self Cleaning Wall Oven
Hi, You can replace the glass piece. You will need the whole model # when you call for the part.
Good luck. Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | GE JTP86 Electric Double Oven
Jul 11, 2008 | Ovens
Ovens Logo
21 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
