Question about LG Televison & Video
Glitching channel info keeps blinking on and off the screen making other function unresponsive
    Top Expert:
  • LG Master
  • 74,383 Answers
Main system control memory IC fault. Replace it, and re-program it. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 26, 2014
Indication Light On, Black Screen, Unresponsive
I happened the same problem and the solution must change the power pack
Jan 25, 2014 | LG M2362D 23 in. LCD TV
Display powers of with power up of AVC
how many blinks does the red light give in a row? This would be an error code?
The problem for 7 blinks would be an Interface board. Apparently there is a glitch in the interface board that sends signals to the television. Basically the glitch shorts out the board and the t.v wont turn on and you will see the power light blink 7 times pause then 7 more. You can replace the board with a new one and update the software on the new interface board.
If is isn't 7, let me know and I will help you out with this
thanks
Apr 26, 2008 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Pictures not bing displayed.
Hi, Not sure if it's the same problem but mine (same make but different model) also does that if the size of the JPG images are bigger than 4 megapixels. I have to resize the images using the batch function of Coral paintshop photo pro X3 to bring the images to 4 magapixels or below.
Jan 11, 2014 | Audiovox DPF700 Digital Picture Frame
Power button doesnt respond
i had the same thing happen twice know. what i think it is, is that the screen for some reason glitches out and becomes unresponsive. i havent updated mine. to shut the device off when it has these glitches i hold down the sleep button and the volume down button. then press the sleep button to start the device. hope this is your only problem. gl
Jan 04, 2014 | Dell Venue 8 Pro Tablet Computer
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
Jun 29, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
The "clean" light keeps blinking. It will not allow me to start another cycle or to cancel/drain.
The blinking clean light is an interruption in the dishwasher program that either indicates a malfunction, or it can be a simple glitch. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r3575752-dishwasher_blinking_clean_light
Now, keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
I have often found this to be a momentary glitch in operation. If the problem keeps reoccuring the number of flashes is an indication of WHICH circuit is causing your problem. As all dishwashers differ in operation and features, refer to your tech sheet for the recommended troubleshooting steps.
If you have any questions, please let me know. I hope this helps you solve your problem.
NOTE: Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons.
Dec 09, 2009 | Microwave Ovens
Clean light blinking a 7 code for a kitchen aid dishwasher model KUDM01TJWH. What is the sequence to clear, what are the blink code explanations?
Blinking 7 times is usually a thermister related problem. However, I have often found this to be a momentary glitch in operation. If the problem keeps reoccuring the number of flashes is an indication of WHICH circuit is causing your problem. As all dishwashers differ in operation and features, refer to your tech sheet for the recommended troubleshooting steps.
Dec 08, 2009 | Dishwashers
The whirlpool agp 931 keeps blinking 7 times, puase, 7 times when I start it. It does not do the washing program . Is that a code for an error? any help would be much appreciated
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Dec 07, 2009 | Whirlpool 18 in. ADP530 Free-standing...
Clean light is blinking and the washer will not restart and run a cycle.
The blinking clean light is an interruption in the dishwasher programming that either indicates a malfunction, or it can be a simple glitch in operation. The following link explains how you may be able to clear the blinking clean light problem:
I have often found this to be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of WHICH circuit is causing your problem. You will need to refer to your tech sheet to determine this.
Nov 27, 2009 | Washing Machines
Televison & Video Logo
18 people viewed this question
Computer Repairing
Computer Repairing
