Washer won't fill or agate
Replaced the lid switch but still don't work
jsrock516
  • 5911 Answers
SOURCE: how to replace a switch-lid on a whirlpool washer
You can check various appliance repair websites for self help manuals, or you can follow these steps:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame. Just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
I hope you find this helpful. If you have any questions please let me know by posting comments.
Have you purchased a lid switch yet? Most major appliance repair centers carry them. The price is about $35. If you have not purchased one yet, let me know what your EXACT model number is (located on the rim of the wash tub opening under the lid) and I will locate a part number for you. I hope this information helps you.
Posted on Jan 21, 2008
IFIXALL
  • 868 Answers
SOURCE: maytag washer
replace the micro switch and your problem is solved.Its a very small switch right next to your door switch and fuse.It has 3 wires and must be replaced to fix this problem.
Posted on May 23, 2008
docjohn174
  • 943 Answers
SOURCE: Maytag atlantis washer
hi thanks for the question you say you activated the washer with screw driver . is the striker on the lid there ,.you could have a broken striker. check that if its there . replace the lid switch the appliance doc
Posted on Sep 28, 2008
AlmostBob
  • 550 Answers
SOURCE: I need to replace lid switch on Kenmore washer.
remove trims from edges of control panel
remove screws from under trims
rais and flip control panel over backwards(hinged at top) do not dislodge air hose to level sensor
remmove brass clips from washer body top, not position for reinstall
disconnect lid switch connector cable
lift and remove entire body
turn upsidie down
change switch
reassemble in reverse order
~20minutes
Posted on Oct 02, 2008
canbruce75
  • 1776 Answers
SOURCE: lid switch on a 20802 kenmore washer
Check the video at the following link and see if it is of assistance to you in changing out the lid switch. Sure hope so and best wishes.
http://www.youtube.com/watch?v=fC8SY3cU1Yc&feature=PlayList&p=A8EAB62928245279&playnext=1&playnext_from=PL&index=61
Posted on Sep 25, 2009
Lid Locks- Fills for 2 seconds and stops
see this causes and fix it. God bless you
Door or Lid Latch Assembly If the washer lid won't lock the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer door won't lock the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Main Control Board If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
Maytag_lse7804ace: washer won't fill with water. If I fill it by hand, the cycle works fine (until it gets to the rinse cycle, when it won't fill again).
Hello John,
The most probable reason the washer is not filling is because of a blown fuse that is part of the lid switch asm. By UNPLUGGING THE WASHER and removing the 2 INNER screws on the the control panel and the control panel can be rotated down to see the fuse in the lid switch asm. Here is where the fuse is on the switch asm. its circled in red 11_4_2011_1_39_54_am.jpg
Nov 03, 2011 | Washing Machines
Just curious, if my washer won't fill but the spin cycle still works, does that rule out the lid switch as the problem?
No if doesnt rule out the lid switch yet in fact that very likely is the problem,the lid switch asm. is wired through a fuse that if lid switch is bad the fuse will blow and in addation to the fuse being wired to the lid switch,it too is wired to the water inlet valve and will not fill if the fuse on lid switch asm. is blown
I know this by replacing more lid switch/fuse assamblies in 30 year appliance repair career that i can remember. I dare say (by assumption) that the tech that came to diagnose your washer gave you the exact correct diagnosis
Jul 28, 2011 | Maytag LSE7806A Top Load Stacked...
Washer fills with water but then will not cycle through after filling tub
I looked up yur model. It is a fine washer. Your lid switch on this model don't allow for wsh or spin if the the lid is ope. Older models would let the washer wash but not spin. This switch here won't allow for wash or spin. How it works
My page on these
Note: this washer is a newer model and I have yet to come across one. I believe your problem to be the lid switch. It has 3 wires. 2 hot ones and another one attached to the frame. Jump them 2 live wires and see if she runs. If it works get a new switch and party on!
I am TheMobilian.
Let me know what ya find out, I am here to help.
Jul 21, 2011 | Whirlpool LSR5132PQ Top Load Washer
Washer won't do spin cycle....and won't start any cycle
Hello & Welcome to FixYa
When the washer fills but does not agitate or spin then you can check if the lid switch is fine. You can jump start the lid switch by connecting both the wires with each other or use the third wire to act as jumper between the two. After this if the problem is solved then replacing lid switch is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Hi my washer will not drain or spin Please help
lid switch or pump 1st start washer is the washer agatating lift the lid if it stops you need to ck the water pump all wasers need to drain the water befor thay will drain
Jun 24, 2011 | Maytag Performa PAV2200
Will fill, agate, but will not drain. is there a reset button?
this is a direct driver washer, i would first check the lid switch then look at the motor coupler..the motor is double shafted on the front side is the pump on the rear is a coupling that connects the motor to the transmission # 285753 this part is plastic with a rubber bushing ... there is no reset button.....
Jan 26, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
After filling up washer won't work
After filling it should go into agatate if you tried a lid switch then I would check the motor coupler it may be broken or striped. Couplers are a common problem it's there to save the motor if it get hung up. While you have it out check the clutch and brake lineings. If the motor is runing it could be the agitator splines striped and wont turn.
If it has belts check them ,also pullys
That pretty much leaves the timer not likely and transmisson not likely but possible.
Apr 24, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer won"t fill with water
check your lid switch if its a top load
May 18, 2009 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
