Question about Pioneer VSX-823-K
HDMI light is flashing
Can't power up the unit. No HDMI connection made so I don't know what the error means.
    Genius:
  • Pioneer Master
  • 1,054 Answers
The unit is in protect mode. Try pressing and holding the 'advanced surround' and power buttons. It should power up. If it shuts down again right away, there is a problem with the amp that needs to be repaired.
Posted on Mar 26, 2014
I have a VSX-44 and the HDMI Light is flashing and my unit will not turn on...is this an issue that can be resolved or will my unit need to go for repairs? FYI- this unit is fresh out the box! Brand new......
don't touch it or you will void your warranty
have it looked at under warranty or if the shop where you bought it has a replacement policy take it back there
Mar 30, 2015 | Audio Players & Recorders
HDMI light flashing
Unit is in protect mode. Hold "advanced Surround" button and power switch for a couple seconds and it should turn on. If it turns back off, disconnect all your speaker wires and try again. If it still shuts off, the amp is bad and needs to go in for repair.
Apr 02, 2014 | Pioneer VSX-823-K
The HDMI light on my receiver is flashing. The power button does nothing, and no other inputs do anything. There is nothing on the screen, and neither of the knobs do anything. I unplugged it for a...
For model vsx-523-k with HDMI light flashing.... PLUG THE UNIT IN AND WITH THE HDMI LIGHT FLASHING "PRESS THE POWER AND THE AVANCED SURROUND BUTTON SIMULTANEOUSLY. .. AND HOLD FOR 5 SECONDS this clear the error. .
Aug 22, 2013 | Pioneer VSX-523-K 5.1 Channel AV Receiver...
BH fitness pioneer start treadmill- flashing E7
see this error has 2 alternatives. proceed according. God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Jul 15, 2013 | Exercise & Fitness
Kfwe50a1 will not start, green light comes on and then flashes red 6 times
Hi Keith,
6 flashes of the led light is an error code and the unit will not fire-up unless isolated the faulty parts.
To confirm if it is the real fault, unplug the unit from the outlet for 15 minutes and then plug it back in and check if the symptoms still persist.
Your unit has a self diagnostic screen that can be access by pressing in rapid sequence "Display", "Channel 5", "Volume (-)", "Power" on the remote control while the unit is in standby mode or the led light stops from blinking.
Self diagnostic screen will be display. Error code will be display together with numerical "0" means no fault detected and "1" means fault detected.
You will see "6 : LOWB with a numerical "1" on the screen, this is an error code for 6 flashes of the led light.
After you've confirmed that the the error code is "6 blinks/ LOWB error code", then the G1 board (Power supply board) is faulty. LOWB error code means that there's a malfunction on the 6Volts output of the G1 board.
To isolate the fault on the G1 board, you must have a skills on electronics troubleshooting, soldering and desoldering parts on the board, have necessary tools and test instrument. If you can't troubleshoot the unit yourself, don't worry, there's a DIY solution so that you can save money for the service fee of a TV technician. You may replaced the entire G1 board(part no. A-1087-323-A), this is more convenient if you are going to do-it-yourself because no troubleshooting and soldering required. I would advice you to obtain the board from your nearest Sony service center because this board is currently not available online.
Please let me know if you need further assistance.
Ratings and feedback is highly appreciated.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Nov 08, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Says "error" and don't know
If the error light is flashing: Check the front door and the fuser door to be sure that they are closed. Also check for any jam including the duplex section. Make sure there is not a sensor flag stuck in the down position. This can indicate memory full, print overrun, size error DX or duplex disabled.
If the error light is not flashing: it can mean there is no paper in tray 1 or the machine may be asking for you to put paper in the multi purpose tray.
Is this the only light that is on?
Jul 06, 2011 | Brother HL2240D Laser Printer
Power light flashes 5 times and then ready flashes 3 times
Unfortunately that is 2 different errors... One being easily fixed. The 5 blinking power LED means its time to replace the Lamp, thats the easiest one to fix.
The blinking ready light means a "Fan 3 error". There is no reference on what that could be. It could be as simple as cleaning the air filter, or as complicated as replacing one of the fan units. You will need to contact Vivitek to know for sure:
http://www.vivitekusa.com/v_contact_support.asp
Attached you will find a chart for diagnosing the Power and Blinking Ready Lights:
Mar 10, 2011 | Vivitek D825MS Projector
All the lights on the buttons flashing with error message
Please perform the following steps:
* Take the cartridges out of the unit. Dis connect the unit from the computer.
* Unplug the power cord from the back of the unit.
* Press OK and Cancel buttons together while connecting the power cord back to the unit.
* Now turn on the unit and verify the result.
:) Dr Tony
May 12, 2010 | HP Officejet 5610 All-In-One InkJet...
Red light flashes 10 times - Panasonic TH-42PX6U
hey there! i finally figured it out!! If you have a computer hooked up with the HDMI cable in the back of the TV and the computer is either on screen saver mood or sleep mood then it is trying to make the television go to sleep aswell. So the only way you can have a computer hooked up to the TV is if you use the front HDMI hook up. pretty weird but thats what was wrong with mine. Hopefully that was the problem :):)
Nov 02, 2007 | Panasonic TH-42PX60U Television
Pioneer VSX-823-K Logo
355 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
