Question about Viking VGIC305-4B Gas Kitchen Range
3 of 4 burner ignitors spsrk at the same time, when turning on just one burner ? Thwn 2 keep sparking while the other burning is running w/o spark ?
    Problem Solver:
  • 4 Answers
I have a similar problem.
Either ground, polarity, ignitor is hairline cracked or module. Look at this post http://appliancejunk.com/forums/index.php?topic=4812.0
hope it helps
Posted on Sep 06, 2009
The ignitor keeps sparking and won't stop.Do not
First of all, the model number is under the cooktop bottom, and secondly, this can happen due to the burner switches got wet somehow. Best thing to do is to unplug unit for 6-12 hours, allow to dry, then re-plug unit back in, this should be enough time to dry out the burner switches.
Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 13, 2011 | Bosch Cooktops
Jenn-Air JDG8430 Ignitor won't stop sparking after burner ignites
Test the ignitor first, if the ignitor does not spark should be the ignitor itself.
Oct 12, 2008 | Jenn-Air 30 in. JGD8430A Gas Cooktop
Cleaned gas cooktop and spark ignitor started sparking on its own
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 07, 2010 | Whirlpool SCS3014LS Gas Cooktop
Viking gas stove top ignitors sparking incorrectly
all ignitors spark at the same time no matter which burner is turned on. If you are having trouble with one burner not lighting try cleaning around the ignitor with a small screw driver so the spark has a good path to ground.
Mar 19, 2010 | Viking Kitchen Ranges
Hi, I replaced the right side ignitor module and now the ignitors spark vigorously and the burners light but the ignitors won't spot sparking and sometimes keep sparking several seconds after I turn off...
There are a few things to check for. Make sure the electrode ( the small metal piece that the spark comes off from ) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and NOT a tooth pick as these can break off and make things worse. The next thing to check for are theignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it. Sometimes cleaning can get moisture into the surface switches, try drying them with an hair dryer to see of this will help.
thanks.keep updated and please do accept the solution.
Sep 18, 2009 | Viking 30" Professional Select Built-in...
Cannot light
some times the wire for the ignitor will get burned inside the chamber, if this happens you will not get a spark and will need a tech, but turn the gas valve to the piliot position hold down the button on the gas valve while clicking the electric ignitor button, look thru the site glass towards the left side of the burner assembly while doing this, if there is no spark it will have to be taken apart and replace the spark ignitor, not a big job you just have to make sure the seal on the burner cover doesn't tear or get damaged
May 03, 2009 | General Electric GE SmartWater Household...
G.E Profile gas cook top #JGP640 ignitor.
It is sparking because the module does not sense the heat which would normally cause the sparking to stop.
It can be caused by a poor ground, make sure the ignitor at that burner is clean and free from any obstructions. If it is then it could either be a defective ignitor or spark module.
Mar 12, 2009 | GE Cooktops
Gas ignitors continue to spark every 5 seconds in off position
try unplugging the unit over night, itspossible that by you cleaning the tops, the electrodes got wet, falsley sparkin, when the water dries out it should stop, and no not dangerous in any way, only annoying to listen to
Feb 13, 2009 | Amana AKS3040 Gas Cooktop
Ignitors won't stop sparking
If your ignitors on the burners continue to click after cleaning it is because they are wet. The spark module is not sensing the flame is on therefore still telling it to click. Just leave all burners on high for 20 minutes until they dry out and stop clicking. The clicking is not dangerous. Just annoying. If they continue to click you may have some grease residue or cleaning residue on the ignitors. Take a piece of sandpaper, nail filer and file the tips of the ignitors where it has metal above the porcelain white part. Good luck.
Sep 20, 2008 | Kitchen Ranges
Viking VGIC305-4B Gas Kitchen Range Logo
243 people viewed this question
Top Viking Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
