Question about Conair GS28L 1500 Watt Ultimate Fabric Steamer
Hose Broke Because there is no support on the bottom of the hose, it was basically cut itself in half inside the fabric cover. I can feel the separation inside. Do I have to ship the entire until back to have it replaced under the 1 year warranty?
Shark Super Steamer
The steam generator is defective.
Aug 28, 2016 | Euro-Pro Shark Super Steamer
Where can I get a replacement plastic part?
Try the place that you bought it. They may have the supplier / manufacturer information of where you can get parts from.
Sep 19, 2015 | Yamata PSS-2001 Power Stand-Up Steamer for...
Elna ironing press manual
I don't have a manual but these are extremely simple to use once and there is a demo on youtube for business shirts How to use Elna Press for Ironing Shirt and other videos from same member show sheets and jeans. Technique is simple, place part of garment onto the board with the rest sitting on your knees (use press sitting down in front of it) to take the weight, lower press closed with your left hand, then bring the spring loaded right handle down to apply the pressure, this has a big spring behind it and applies pressure, wait 2-3 seconds then lift right handle to release the pressure and then using your left hand grip the whole press will want to open up again. That's it! Set the temperature setting on the press and iron from your lowest temperature items first, nylons, up to cottons, linens on the hottest setting last as it will take 5 minutes or so to come up to full temperature. If you have the vapojet spray attachement, then you fill this with tap water and slide it onto the handle, give it a spray with the press open before you close to press and it turns to steam. Cleaning the top hot plate can be done with a special cleaning stick product you can buy (or any similar iron cleaning stick will work too, but you need to apply it to a hot plate so be really careful as you do this, then wipe it off with some waste fabric. Great press to own and perfect for applying interfacing if you are a sewist, (just use a piece of waste fabric so side of the interfacing doesn't attach to the top plate or your bottom cover).
Jul 12, 2014 | Garment Steamers & Presses
Home touch steamer
hose kinked or generator bad.
Dec 18, 2013 | Garment Steamers & Presses
Doesn't steam
the hoses sometime kink when hot then get hard in the kink part once cooled down.. you may need to fin the area and warm it up to let the steam pass..
Dec 13, 2013 | Haan Complete Multipurpose Steamer MS-30R
What are the advantages of using a steamer over an iron?
steamers are usually believed to be easier to use and less damaging to the fabric over time
Jan 30, 2013 | Garment Steamers & Presses
Conair GS28L 1500 Watt Ultimate Fabric Steamer Logo
46 people viewed this question
Top Conair Garment Steamers & Presses Experts
Tom Chichester
Bill Boyd
ray gallant
Are you a Conair Garment Steamer and Press Expert? Answer questions, earn points and help others
