Question about Star DP8340-FM Receipt Printer
Printer is lightly printing
Printer works fine except it is very light on the paper...we have installed several new ribbons but still have the same problem.
    Master:
  • 623 Answers
Be sure the platen pressure lever is set to the right position, It sounds like it's set too far back - towards the 'multiple copy' position.
Posted on Jan 22, 2015
Canon mg3520. I cant not print a nozzle check pattern. it takes the paper and prints one line and stops. it keeps the paper in the printer. then the warning light flashes 2 times
hmmm seems like your printer isn't recognizing the ink carts installed or its running into some other malfunction regarding to the ink tray system in the printer is there any pop ups coming on your computer screen about the printer via the canon software that was installed? (if any software was downloaded from canon or software from a cd)
Feb 23, 2017 | Canon PIXMA MG3520 Inkjet Multifunction...
Blank page feeding during print job
Please adjust paper size in printer properties.
Oct 09, 2008 | HP Deskjet 6940 InkJet Printer
I have a Zebra 105Se zebra Printer for testing. When a label is printed it just prints 1/4th of the label,then the printer stops and paper/ribbon light,Pause light and data light is on.When I open the...
Make sure that both ribbon and media paths are clean (no glue, or sticked labels). Make shure the ribon and the media are corect installed on their paths.
Sep 23, 2011 | Zebra 105Se Thermal Printer
Ink has run out ??? it no longer prints... TSP100 How do we change the ink roller/cartridge or whatever it requires?
TSP100 Thermal Printer work with a thermosensible paper, there is no ink to change, if the print quality is poor you have to
  • check the paper roller, it can be wrong installed.
  • Check the upper cover if not closed properly close it.
  • check the print head or the pressor roller.
Jun 13, 2011 | Star Micronics TSP100 Thermal Printer
I changed the ribbon to the monochrome R3012, but the printer has the NO RIBBON light on and it won't recognize it. I set the printing references to that ribbon style, the ribbon is not torn, I have made...
You may have installed ribbon incorrectly.
Align the gears of ribbon spindle with gears on printer and second important thing is that ribbon should come from up not from down.
Mar 13, 2011 | Evolis PEBBLE 4 Led Card Printer
Reset. Orange light blinks several times. Then Green. Then orange several times, then... on and on. Cannot reset. All ink cartridges have ink.
count the number of orange flashes in between the green light. two flashes = out of paper, 3=paper jam, 4=empty ink tank, 6=print head not installed, 7=print head defective, 8=waste ink tank is almost full
Jun 08, 2010 | Canon i850 InkJet Photo Printer
Everytime I turn my Zebra TLP 2844-Z printer on,
The red light means out of paper or ink ribbon. Some people chose not to use the ink ribbon and get thermal direct paper which requires no ink ribbon but the printer has to be told by the driver not to expect ribbon or the red light will come on. Also not having the correct paper height set in the driver will make the red light come on as well so check the advanced tab in the properties of the driver then click printing defaults. In the ZDesigner driver height and width are entered there. In the zebra universal, click paper output and enter the size.
Oct 01, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Dot matrix printer. very light print on last page of form
Hi and welcome to FixYa,
Based on your description, the printer is working, it is not a form issue, the printer head is good, an adjustment might be needed and it works, there is no reason to replace the Lexmark 2381plus printer even if it is 7 years old (not unless you would want to).
To the faint printing on the last of the 3 pages:
  • the take-up spool/wheel drawing the ribbon is not working (most likely). The ribbon is not moving hence the printer head is not striking fresh ribbon area. Check the ribbon cartridge, it may be stuck or the driving spindle where the ribbon's take-up spool/wheel locks into. It may need a bit of cleaning and/or lubrication;
  • the printer head is slightly adjusted away from the paper. Normally, there is a mechanical lever/adjustment that sets how many paper & duplicates are fed. Adjust for 1 only.
Good luck and thank you for using FixYa.
Jan 30, 2009 | Lexmark 2381 Plus Matrix Printer
MY PRINT OUTS HAS LINES
your printer has either:
1.low ink
2.the movement of the in slider is to slow
3.the paper is going too fast when it is printed
i sugesset you either take it back (if its new) ,or get a new printer
Dec 31, 2008 | Fargo Persona C11 Thermal Printer
Samsung ML-2510 Laser
SIMPLY UNINSTALL THIS PRINTER FROM COMPUTER AND REINSTALL IT AS A NEW PRINTER FROM THE INSTALL DISC THIS WILL USUALLY
FIX THIS TYPE OF PROBLEM
Jan 17, 2008 | Samsung ML-2510 Laser Printer
Star DP8340-FM Receipt Printer Logo
41 people viewed this question
Top Star Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
ray gallant
Jean DeLauche
Jean DeLauche
Are you a Star Office Equipment and Supply Expert? Answer questions, earn points and help others
