Question about Maytag Refrigerators
Mother board replacement
I replaced the mother board on my maytag and now the display is blinking PE0 0000. Model MFI2269VEM7.
  • 62 Answers
SOURCE: MAYTAG REFRIGERATOR
The number is 67004704. You can find replacement parts and number by going to the SEARS parts web site and putting your model number in and it will show a pic and part number wit prices.
Posted on Aug 31, 2008
  • 220 Answers
SOURCE: The entire fountain assembly needs to be replaced.
Part number 12001760 fountain kit(includes solenoid, flapper door &hinge pin $50,part number 61003425 control board $95,part number 61003407 fountain bracket $25.
 Depends on how much you like the fridge but thats a lot to spend on an ice dispenser. and thats assuming you do it yourself otherwise add at least another $100
Posted on Sep 27, 2009
SOURCE: need reset code for maytag fridge MFI2266AEU. Just
My sticker is missing. What code do I use?
Posted on Feb 01, 2010
rohntech
  • 422 Answers
SOURCE: After installing a new mother
It's board are already programmed so check it's wiring for open, look for deformed component it may cause it not buttons to work. Also do not overlook the possibility of a factory defect control board sometimes it do happened. Be sure that you installed it correctly the same as the old one. Look for loose connection.
Thanks for asking. Good luck.
Posted on Jul 04, 2011
richroth
  • 9472 Answers
SOURCE: I have a maytag ice 2O. Just replaced the HV control board, programmed with code 1411. All seemed well, but the icemaker turns the auger without prompting, and will not turn when the dispenser is depr
Did you put the correct code in? The code should be listed inside the unit.
Posted on Dec 10, 2012
Blinking display
jph, this is a classic symptom of the high voltage board failure. What board did you replace? The high voltage board is the one on the back side of the refer, left hand side. Catriver.
Sep 19, 2007 | Maytag MFI2568AE Side by Side French Door...
SONY LED TV MODEL - KDL-40W900A .MOTHER BOARD IS DAMAGED. REPLACEMENT COST 8000-10000 INR. CAN ANY ONE SUGGEST IF REPAIRING MOTHER BOARD IS POSSIBLE?? AND WHERE IN MUMBAI ?ANY CONTACT DETAILS ...
Mother board repairing at component level is not possible to Sony. It is best to replace it. Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 02, 2016 | Sony Televison & Video
Where is timing device on maytag refrig
The timing device is on the back lower leg area, looks like a white round dial with a flat blade screw driver edge on it
Jan 15, 2014 | Refrigerators
All display lights blink
You will need to replace the main board on the back of the unit. Here is the board to order. Be sure to program the board when you install it. There will be instructions that come with the board.
The part comes with a 365 day, any part, any reason return policy.
Nov 20, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
The ice trap door won't stop cycling open and closed and the control panel on the door is blinking all of the lights
Called maytag with model and serial number. This is a very common problem. They sent a new mother board free of charge within a couple of days. You will have to go to the back of the fridge to swap mother boards. It was pretty simple if you have a little patience. Maytag wanted to charge $200 for the service call but it took my husband about twenty minutes. Then you will need to reprogram with the code inside of the door. I was told that this happens alot if there is a power surge, so I now have the fridge on a surge protector. Haven't had a problem since. Hope this helps.
Nov 10, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Digital readout blinks
Hello , I can help with this issue , When your display fades or flashes it is the first sign of your control board going out. The control powers your digital screen and they are very common to fail. If you have the model with the controls in the back top of unit against the wall it is basic to replace the board yourself , if you have the controls in the front of the unit it is more advanced to get into but is still possible. [controls meaning screen & burner knobs.]
A good place to order is sears parts. be sure to use your model off the oven its self. Please let meknow if you have anymore questions. Phil
Dec 31, 2008 | Maytag MES5752BAS Stainless Steel Electric...
Repiring
your motherboard is faulty. replace.
Jan 04, 2008 | Compaq Deskpro EN FC 6450+ Model 10000...
Kenmore Fridge- all lights blinking
sorry to say this but the mother board has took a hit replace this and all will be well
Dec 31, 2007 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
