Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
No sound on TV
Have had a problem w sound for the last 6 months, usually rebooting the cable box did the trick. Sound went out, my little trick did not work, exchanged the cable boxes for new ones, still no sound. Any suggestions welcomed
  • Official Brand Answer
  • 350 Answers
Please double-check your connections between the cable box and TV. If the problem persists, resetting the TV by pressing and holding the [ACTION] and [POWER] buttons down on the TV remote until the words "SELF CHECK" appears may fix the audio problem.
Posted on Mar 26, 2014
  • 192 Answers
SOURCE: Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Posted on Jun 24, 2007
  • 95 Answers
SOURCE: Split screen question
Ah split screen just another way of getting two picture in one screen, or sport for he and Opra for her.
Fisrt you must understand what split screen is, it is taking two information from different source and sending the info to the micro to devide the info for two seperat image.
Well something like that but I know you were inpress,
Yes you can. Take the main source you or using I would say the TV box in cable connection or av1 and then your DVD or and VCR to source av2 or 3. When presing split screen or pip you will get one screen showing the main source your tv box and the second your dvd (or VCR) in the source input solector you should be able to change the second amage input with input solector and the tv box change the other.
Oh what a butiful life aint it.
Try this with 7 different source, Cable, satelite, fta, dvd, camera, gaming sytem, and computor,... well that another chapter.
What about Bob
Posted on Mar 01, 2008
  • 4234 Answers
SOURCE: SOUND NOT WORKING ON ALL CHANNELS
Check to make sure that the set is not set for SAP. This is an alternate audio channel that usually contains another language. Some stations broadcast the audio in both others do not.
Dan
Posted on Sep 11, 2008
  • 116 Answers
SOURCE: I bought a panasonic 50"
See if oyu can buy a HDMI selector box, does the sound system have a dvd player in it? IF so I would go with S-video instead of hdmi, save the HDMI for the blue ray player. What is the very first item you have listed up there? PAnasonic what? LEt me know, hope this helps.
Posted on Dec 11, 2008
spqr163
  • 37 Answers
SOURCE: No video with HDMI port
try 2 things, first use the rgb cables or video (yellow) cable and plug it into the tv using one of the imports..(vid 1,2,3 etc...) and see if that works. then check to see if you get a picture by not using the cable box, by pass it and connect it connect it in the uhv channel. also make sure you have it on the right input of the tv (meaning scroll through the input button on your remote to find the picture...i've done this a million times). still no picture try your dvd player input and if you have a vhs input see if that works. if it is the hdmi input...to be honest it's expensive and a pain to replace...
Posted on Mar 12, 2009
Power went out now no sound on tv. Tried rebooting the cable box still no sound
hi what is the make and model number of the tv thanks
shaun
Mar 10, 2017 | Televison & Video
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
Hitachi 51F710E has no sound
The audio portion of the main board is failing. You can get a replacement here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jun 07, 2017 | Hitachi 51F710 Rear Projection Television
No picture still have sound HELP
If you have not tried it: unplug the set and if using a cable or sat box unplug that as well---wait for a while and plug both back to see if a reboot of either cures the problem or not.
May 25, 2012 | Samsung 50 in. Plasma TV
No sound on channel 3
Maybe the cable signal is defective not your tv.the other channel is ok.if you tv has a defect all channel has affected.
Jul 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
No sound
Its not your TV, call cable company, ask them to reimburst you for the days and times, you were unable to use your cable to is fullest advantage, you should get about $4.75 a day you were unable to use ur cable after the storm
Feb 26, 2009 | RCA L32WD22 32 in. LCD HDTV
No sound: Panasonic 50" plasma
This just happened to me - I called Panasonic. Turns out it was my digital cable box - I unplugged it, turned in back on, and the sound was back.
Apr 04, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
No sound time warner cable
Time Warner Cable just sucks!!!
Feb 02, 2008 | Computers & Internet
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
50 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
